Old 01-11-2013, 11:35 PM   #3961
Aprilia
Oddometer: 702
Dynojet kit is far too rich. Their needle taper is good but main jets are way way too rich. Use their needle on 2nd clip then go with an OEM Keihin 142 main jet or if you want a bit more mileage go with a 140. Properly jetted the KLR will give you 46-50 mpg in mixed riding.
Aprilia is offline   Reply With Quote
Old 01-19-2013, 08:05 PM   #3962
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,330
I made some progress today plumbing up the Fox reservoir.
2008 KLR 705-2004 ST1300-2001 FZ1
2001 GAS GAS 321
IBA # 23,716
http://gasguysadventures.blogspot.com/
GAS GUY is online now   Reply With Quote
Old 01-20-2013, 01:16 PM   #3963
IDRIDR
Take me to the River
IDRIDR's Avatar
Oddometer: 1,432
So, I'm reading a recent Dirt Bike article on the KLR650. The author claims to have gained 7 hp (from 33 to 40) with an FMF pipe and JD jet kit. Seems that most others around here tend to disagree that such a large gain is possible.
Here's a dyno chart http://www.pbase.com/image/110004615
I'm confused
IDRIDR is online now   Reply With Quote
Old 01-20-2013, 01:59 PM   #3964
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,330
[/IMG]
I'm confused
I hate to say it, but it does seem optimistic, unless the JD Jet kit is that good.I doubt it.
I've often wondered about the Jd kit on the Klr but no one seems to have done much testing.
The Ktm guys swear by the Jd kit though.
Which FMF muffler was used in the test ?
Have you seen Patmans big dyno writeup ? He could not get 40 and had alot more mods done.
2001 GAS GAS 321
IBA # 23,716
Old 01-20-2013, 02:58 PM   #3965
XDragRacer
Oddometer: 3,092
q.v., "Fantasy Island," network TV series of the past (info on Google).
Relevant quote:
Tattoo: "De plane! De plane!"
XDragRacer screwed with this post 01-20-2013 at 03:04 PM
XDragRacer is online now   Reply With Quote
Old 01-20-2013, 03:10 PM   #3966
ejbeert
Oddometer: 50
no i did not dyno no i dont know if it is better than any other combo but i used the jd jetting( james dean) and drilled a 3/4 hole through the baffles of the stock muffler. yes i like it no down side for me and yes i have a ktm 450 exc that i used a jd jetting kit and and like it as well, no claims just smiles
ejbeert is offline   Reply With Quote
Old 01-20-2013, 03:25 PM   #3967
Jessper
Jessper's Avatar
Oddometer: 11
I recently put one of Parabellum's re-designed 1st gen klr shields on my 02 and i love it!
Plenty of wind protection and it doesnt get in the way off road or have big brackets all over the place either
Jessper is offline   Reply With Quote
Old 01-20-2013, 03:38 PM   #3968
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,287
Correct me if I'm wrong, but I think JD bought a GenII KLR, then made a needle to improve on the stocker. Almost all JD and DJ needles have a more aggressive taper than the stocker, except for the JD KLR needle. It looks like a pencil with a rounded off eraser.
Strange, but he must have a reason for it.
I run Klotz in my weed wacker and chainsaw for the smell
Yokomo is offline   Reply With Quote
Old 01-21-2013, 06:37 AM   #3969
ejbeert
Oddometer: 50
I am no expert but as i understand it the size and shape of the needle are important as well as the position of the needle to the needle jet. It appears from his web page that james dean jetting used a gen 2 bike; he provides pictures and dynographs. All I really can say is that the change woke my bike up as they say. I dont have access to a dyno nor do I take accurate gas milage figure but I usually get 49 to 50 mpg before and after the jetting. This is the second bike I used it on and am pleased in both cases.
Old 01-21-2013, 09:59 AM   #3970
Aprilia
Oddometer: 702
JD Needle kit...I use an Air/Fuel meter with wideband O2 sensor and have tuned/sniffed a number of KLR's the last few years. The DynoJet, JD and KLX needles all offer better fueling compared to the stock KLR needle. Dynojets recommendations for main jet and other changes are wrong but off the shelf JD's kit is pretty good. The KLX needle kit with either a keihin 140 or 142 main jet along with a couple other minor changes is pretty darn good too.
For those who already installed the Dynojet kit simply convert the main jet to Keihin sizing and if you have a stumble when you twist the throttle you'll need to fill in the 1/8" hole in the slide the kit has you do and redrill to 7/64ths.
Old 01-21-2013, 10:22 AM   #3971
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Location: NE PA Some... PNW Some... On HIGH ADVENTURE Most!
Oddometer: 1,776
Thumb
Yup....
Jettn Jim is offline   Reply With Quote
Old 01-21-2013, 12:47 PM   #3972
RustySpokes
Two-bit throttle bum
RustySpokes's Avatar
Oddometer: 1,065
Stock KLX 650 needle? From what year? Any more info?
RustySpokes is online now   Reply With Quote
Old 01-21-2013, 12:53 PM   #3973
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,287
Isn't the KLX needle and DJ needle more tapered, whereas the JD is exactly opposite?
Old 01-21-2013, 01:48 PM   #3974
Aprilia
Oddometer: 702
Available in "kit form' from a number of places but I'd suggest www.eaglemike.com If you want to order from your local kawi shop its part numbers; needle (N1TB #16009-1794), spacer (92143-1667) and clip (92037-1401)
I never looked at them side by side but rather through A/F graphs on my laptop. All the needles performed well I just found the KLX and JD kit worked better in real world riding. My A/F meter is portable so I can actually go out and ride the bike under real conditions vs sitting on a dyno. Granted, tuning todays supersports bikes gets a bit difficult at WOT settings as its hard to find a road long enough and clear enough for all RPM's but thats another story lol.
Old 01-22-2013, 05:46 PM   #3975
Grinnin
Forever N00b
Oddometer: 2,706
Conspicuity lights.
I shamelessly stole this idea from DrMoto in the KLR250 thread. These 1.5W LEDs are from superbrightleds.com and the pair was less than $15 shipped.
These brackets go on the upper mounts for the front wings.
And here is one mounted (you can see I added two more holes for a zip-tie around the power cord).
These are out of the way but not as shielded as it looks in the photo -- I can see them from about 45 degrees.
EDIT: This is where I got the lights: http://www.superbrightleds.com/morei...watt-led/1141/
Motorcycles are magical.
Grinnin screwed with this post 01-22-2013 at 05:59 PM
Grinnin is offline   Reply With Quote
Times are GMT -7.   It's 05:40 PM.
