Old 03-22-2013, 09:17 PM   #4171
Wansfel
50 yrs on 2 wheels
Wansfel's Avatar
Oddometer: 1,324
I carry about a 12 inch crescent wrench and I also run a 16 and carry a 14 and 15, but the only place I would consider using the smaller sprockets is in a true single track or extreme 4X4 trail where I have to go extremely slow due to BIG rocks etc. Never seen the standard backwoods road yet that the 16 couldn't handle.
Originally Posted by Panama View Post
Thanks Guys,
I will leave the stock chain on for now and pack the spare.
I will flip the front sprocket and see if that helps with the rubbing of the chain.
So you guys pack a longish lever to remove and re install the CS nut?
I know I want the 16 for the interstate and the 14 or 15 for central america back roads.
BOM 2015 ADV Thread
BOM 2015 Blog
Wansfel is online now   Reply With Quote
Old 03-23-2013, 01:01 AM   #4172
XDragRacer
Oddometer: 3,215
Hi guys I drilled out my carb air screw plug and the screw was less than 1/4 turns out.
I turned it to 1 full turn out and now it can start with no choke, and can wheelie without popping the clutch.
My question is what setting should the screw at for a stock bike with 8000 miles, stock, needle setting, stock air fileter, stock pipe.
- Thanks
Men say the "stock" setting is inordinately fuel-lean, in consideration of emissions testing. Clymer lists "1-3/8 turns" out as standard; however, I doubt this setting is optimal.
Many, doubtless, might differ, but . . . 1.75 turns out works for my neo-stock Generation 1 KLR650; slide drilled 7/64" and one # 4 washer shimming needle (as in, "22-cent mod").
And, as always, . . . YMMV!
BTW, I believe the fuel screw dominates the air/fuel mixture around idle, and is significant only up to 1/4 throttle, but--some believe its influence remains a major one across the entire rpm spectrum, "from DC to daylight!"
XDragRacer screwed with this post 03-23-2013 at 01:07 AM
XDragRacer is online now   Reply With Quote
Old 03-23-2013, 04:20 AM   #4173
D_A
D_A's Avatar
Oddometer: 1,280
This page is good background info: http://www.gadgetjq.com/keihin_carb.htm
D_A is offline   Reply With Quote
Old 03-23-2013, 04:25 AM   #4174
ThomasVolomitz
New Old Stock
ThomasVolomitz's Avatar
Oddometer: 4,419
Yesterday my I asked my mechanic to install the Thermbob and check valves. Three of the valves were out of spec and the bike has 4,200 miles.
https://m.facebook.com/dualsportdelinquents
Still Riff Raff
ThomasVolomitz is offline   Reply With Quote
Old 03-23-2013, 05:01 AM   #4175
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,051
That's normal for the 4K checkup, now they will be fine for 3 times that far as long as your mechanic does his job right.... If you ride in cold/cool weather a Thermo Bob is a wonderful thing.....
"Where ever you are, there you go..."
SkiBumBrian is offline   Reply With Quote
Old 03-23-2013, 05:18 AM   #4176
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Location: NE PA Some... PNW Some... On HIGH ADVENTURE Most!
Oddometer: 1,789
Thumb
Excellent diagram!
Thanks Guys,
I just use the one of my MotionPro spoons like this.
27mm, under 10"long and 3.5oz
Jettn Jim is offline   Reply With Quote
Old 03-23-2013, 07:45 AM   #4177
Panama
Oddometer: 127
Do you think the #4 washer and drilling the hole will hurt fuel milage? I am going to need every penny I can save on this trip and would hate to loose MPG.
Panama is offline   Reply With Quote
Old 03-23-2013, 08:39 AM   #4178
KamikazeKLR
Shorty on the 650
KamikazeKLR's Avatar
Oddometer: 682
What's a Thermobob and what are the benefits of it
- Mel
Long Way Back
Not all those who wander are lost
2002 Kawasaki KLR650 - Big Red
KamikazeKLR is offline   Reply With Quote
Old 03-23-2013, 09:18 AM   #4179
SkiBumBrian
DualSport Crazy !!
Oddometer: 1,051
It's a bypass for the cooling system. It bypasses the radiator until water comes to temp. In cool temps water never gets to operating temps when at speed causing alot of thermal cycling. Theory is reducing this cycling will extend engine life by avoiding cylinder warpage and wear....
Old 03-23-2013, 09:22 AM   #4180
sdd04
Location: The Ozarks....SW MO, NW AR-great place to play!
Oddometer: 843
As Brian noted, if you ride in cooler weather, it really helps to warm the bike up properly and quickly.
sdd04 is offline   Reply With Quote
Old 03-23-2013, 11:21 AM   #4181
KamikazeKLR
Shorty on the 650
Oddometer: 682
Cool. Thanks for the info, guys.
- Mel
Long Way Back
Old 03-23-2013, 02:15 PM   #4182
GO_OUTSIDE!
dirty hippie
GO_OUTSIDE!'s Avatar
Oddometer: 288
Originally Posted by Jettn Jim View Post
Makes her the bike I want... no more noodle forks! Had Intiminators in the stockers with a brace for 30,000mi or so, that made them way better than stock. This is just waaay better than that. For what I do. YRMV
Im guessing you changed the springs. How much work was involved in the rest of the swap? Did you use the klr triples? It looks like the forks have more length and rake or is that just the camera?
Thank you!
Now Go Outside!
GO_OUTSIDE! is offline   Reply With Quote
Old 03-23-2013, 05:34 PM   #4183
franklinmanklin
Oddometer: 53
I have an '09. My kids got me a RAM mount for my Garmin. Can someone post up a picture of the ideal handlebar mounting location? Cables, wire, instumentation and etc are all in the way.
franklinmanklin is offline   Reply With Quote
Old 03-23-2013, 06:04 PM   #4184
SkiBumBrian
DualSport Crazy !!
Oddometer: 1,051
Here is where I mounted mine.
Old 03-23-2013, 06:51 PM   #4185
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,455
I generally put my GPS on the clutch side of the handlebars, similar to Brian's setup.
Puts it a little closer to your face (easier to see), and a bit easier to mess with on the road.
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is online now   Reply With Quote
Times are GMT -7.   It's 09:02 AM.
