Old 03-23-2013, 07:01 PM   #4186
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,051
Yeah, I need a REAL gps..
"Where ever you are, there you go..."
SkiBumBrian is offline   Reply With Quote
Old 03-23-2013, 07:28 PM   #4187
bdcorrigan
bdcorrigan's Avatar
Oddometer: 653
Clutch side
[IMG][/IMG]
bdcorrigan is offline   Reply With Quote
Old 03-23-2013, 07:47 PM   #4188
franklinmanklin
Oddometer: 53
Thanks, gents.
franklinmanklin is offline   Reply With Quote
Old 03-23-2013, 10:51 PM   #4189
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Location: NE PA Some... PNW Some... On HIGH ADVENTURE Most!
Oddometer: 1,814
Originally Posted by GO_OUTSIDE! View Post
Im guessing you changed the springs. How much work was involved in the rest of the swap? Did you use the klr triples? It looks like the forks have more length and rake or is that just the camera?
Here ya go... the swap in it's early stages before the HighWayDirtBike stuff, over at KLRWorld.
http://klrworld.com/forums/suspensio...itty/#lastPost
Jettn Jim screwed with this post 03-23-2013 at 11:47 PM
Jettn Jim is offline   Reply With Quote
Old 03-23-2013, 11:09 PM   #4190
XDragRacer
Oddometer: 3,298
Originally Posted by Panama View Post
Do you think the #4 washer and drilling the hole will hurt fuel milage? I am going to need every penny I can save on this trip and would hate to loose MPG.
Drilling the slide only affects throttle response; shimming the needle fuel-enriches mid-range operation . . .in my experience, any change in fuel efficiency appears marginal; if your budget depends upon a couple of miles-per-gallon around 50, you might consider whether you can afford the trip and bike at all.
Even adjusting the fuel screw out affects fuel mileage, be it ever so slightly.
That said, nothing wrong with running the carb bone stock, IMHO; my riding partner approaches 55,000 miles on his '08, totally satisfied with his carburetor as it came from the factory.
XDragRacer is offline   Reply With Quote
Old 03-24-2013, 10:21 AM   #4191
KustomizingKid
Oddometer: 678
I just got myself on the list to have a Renazco seat done up for my bike
2000 Xr650r!
KustomizingKid is offline   Reply With Quote
Old 03-24-2013, 11:55 AM   #4192
Dusty_Bottoms
Adventurer Ordinaire
Dusty_Bottoms's Avatar
Oddometer: 842
Post pics when it's done?
What's it cost?
COHVCO #7369
Dusty_Bottoms is offline   Reply With Quote
Old 03-24-2013, 12:09 PM   #4193
KustomizingKid
Oddometer: 678
Somewhere between $300-$400 depending on options, full custom job.
2000 Xr650r!
Old 03-24-2013, 09:31 PM   #4194
lost...
Guarior
lost...'s Avatar
Oddometer: 228
Originally Posted by sdd04 View Post
As Brian noted, if you ride in cooler weather, it really helps to warm the bike up properly and quickly.
Is the thermobob a huge (or much of) a detriment if I plan on riding in WARM weather? I live in central oregon, but want to spend a bunch of time in Mexico, slow speeds and hot weather, high rpms. (secondary, sandy, etc.)
thoughts?
¨Oh, did somebody wake up on the wrong side of paradise this morning?¨ -the ex, via phone
lost... is offline   Reply With Quote
Old 03-24-2013, 10:16 PM   #4195
SkiBumBrian
DualSport Crazy !!
Oddometer: 1,051
No difference good or bad in warm/hot weather...
Lets get this straight. Some people (I received a PM) see no advantage to the T-Bob, fair enough. I don't think there is enough empirical evidence one way or the other on its effectiveness. I do know that riding in my area in cool/cold weather the water never gets to operating temperature. Where I come from an engine that does not come to temp or cycles back and forth from cold to hot/ warm is cause for wear, especially in the cylinder and rings which rely on a nominal temp to do their job effectively.
The KLR has done it's job effectively for decades without a T-Bob but does that mean it cannot be improved by installing one? The choice is yours to make. I know I feel more comfortable seeing and knowing my bike comes to temp quickly no matter the outside temperature and stays there.
The choice is yours....
SkiBumBrian screwed with this post 03-25-2013 at 06:52 AM
Old 03-25-2013, 07:39 AM   #4196
KamikazeKLR
Shorty on the 650
KamikazeKLR's Avatar
Oddometer: 685
Mounting a GPS
While we were on the topic of GPS mounting, I just recently got myself a cheap little Garmin Nuvi. I am making myself a plastic dash and I would like to mount it to that in the middle. Any recommendations on how to do this? It just comes with the suction cup mount but obviously that won't hold. I was thinking maybe just drill the suction cup to the dash.
- Mel
Long Way Back
Not all those who wander are lost
2002 Kawasaki KLR650 - Big Red
KamikazeKLR is offline   Reply With Quote
Old 03-25-2013, 07:56 AM   #4197
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Oddometer: 1,814
I believe you'll find the vibration to be too bad for viewing the screen if you do this... I remember Parepin trying to mount his to the fairing with no luck, I also tried in 2010 on an Alaska trip and had too many vibes. On my aftermarket Lynx fairing I have pulled it off, keeping the unit flat against the dash. (though still not as clear as a handlebar mount)
So if you are going to try it... I'd say keep it close and flat to the dash using no arms or mounts that would amplify vibration. A Ram mount off the left handlebar works really well.
Peace,
JJ
Old 03-25-2013, 08:40 AM   #4198
KamikazeKLR
Shorty on the 650
Oddometer: 685
Peace,
JJ
I didn't think of that. Very well then, bar mount it is! I suppose RAM mount is the way to go?
- Mel
Long Way Back
Old 03-25-2013, 11:02 AM   #4199
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,862
the RAM mount on the left-hand bar of my KLR has been forcibly introduced to the planet on a number of occasions. . . . . . I've adjusted it tight enouigh that it doesn wander during normal riding, but loose enough that I CAN move it by hand, if I try . . . . . .
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance.” T.R.
bomber60015 screwed with this post 03-25-2013 at 11:12 AM
Old 03-25-2013, 01:27 PM   #4200
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Oddometer: 1,814
Thumb
Indeed ! I happen to have a spare or two lying around as well if your interested. Just let me know.
Times are GMT -7.   It's 07:41 PM.
