Old 05-18-2013, 06:56 AM   #4636
tommu56
tommu56's Avatar
Oddometer: 1,386
Originally Posted by XDragRacer View Post
Do you mean, "3.25 X 21?" No problem! Got 'em on both KLR650 and KLR250.
Yep 21"
Did it help handling?
My old one cupped and I should have flipped it a couple thousand miles ago
fat fingered on a droid
tommu56 is offline   Reply With Quote
Old 05-18-2013, 06:58 AM   #4637
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,021
Originally Posted by tommu56 View Post
Yep 21"
I need to flip my front 705,thanks for the reminder,and get that patched tube outta there.
What would you do if you weren't afraid?
Bobcat Goldthwait is my mentor.
8lives is offline   Reply With Quote
Old 05-18-2013, 08:40 AM   #4638
sandalscout
blah blah blah
sandalscout's Avatar
Oddometer: 2,266
Originally Posted by afk40 View Post
hi guys/ im reading Doohickey all th etime,,, what is it, an do i need to get it done, i have a c5 wi 17k miles on it, whats the pros an cons of having it done an not... sayin that i really dont know what it is, cheers
Start with these.... they should contain everything you need to know as to WHY you should replace the lever, and how.
http://www.klrworld.com/index.php?op...144&Itemid=227
http://www.klr650.marknet.us/doohickey.html
sandalscout is offline   Reply With Quote
Old 05-18-2013, 05:27 PM   #4639
judjonzz
Beastly
judjonzz's Avatar
Oddometer: 2,010
I miss ordered and got a 3 1/2" wide front tire has anyone tried to fit it on?
It's a Kenda 270 that is what's on there now but 3"
TOM
The wider kenda is a 3.25, not 3.5. It is not as common as the 3.00. In theory, it might give a little better flotation in sand, at the expense of slightly slower steering, but in practice, you probably will not notice a difference.
For deMille, young fur-henchmen can't be rowing.
judjonzz is offline   Reply With Quote
Old 05-19-2013, 07:25 AM   #4640
GO_OUTSIDE!
dirty hippie
GO_OUTSIDE!'s Avatar
Oddometer: 288
Originally Posted by 8lives View Post
I just went and got some gas resistant gasket material,took the tank off the bike,took the 4 screws out of the back of the petcock,took out spring and diaphragm,cut gasket to fit,Drilled 4 holes in the gasket,bolted it back together,cut some of the old vacuum hose stuck a small bolt in 1 end of each plugged carb plugged petcock and its done.Don't tell anyone else but it was about 2.00$ in parts and about a half an hour,or you could do the Raptor petcock,oh and make a note to turn fuel off when motor not drinking fuel.
Any idea how much to add to the main tube to get an extra gallon of reserve?
Thank you!
Now Go Outside!
GO_OUTSIDE! is offline   Reply With Quote
Old 05-19-2013, 09:19 AM   #4641
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,021
Nope,I used my stock petcock,if Im in the middle of nowhere I fuel at 200 miles or when I see a pump otherwise I go until I hit reserve and look for gas.
Old 05-20-2013, 08:25 PM   #4642
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,051
Picture of a useless hunk of metal. Had a purpose back in the day when you used to kickstart your bike, now it is just something to break, leave you stranded or throw a broken spring into your valve train. Plus the sucker is noisy.
Remove at your convenience!
"Where ever you are, there you go..."
SkiBumBrian is offline   Reply With Quote
Old 05-21-2013, 06:13 AM   #4643
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,021
You and I must discuss this,I think this needs to be done to mine!
Old 05-21-2013, 07:23 AM   #4644
SkiBumBrian
DualSport Crazy !!
Oddometer: 1,051
Bring your exhaust cam over, I will remove it for you....
Old 05-21-2013, 08:01 AM   #4645
GO_OUTSIDE!
dirty hippie
Oddometer: 288
You are getting better gas mileage than i am. If i see 200 miles between gas sations i have just spent 30 miles riding in a panic.
Thank you!
Now Go Outside!
Old 05-21-2013, 10:13 AM   #4646
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,021
Just puttin around I get 53mpg,freeway 46 or less sometimes alot less.
Old 05-21-2013, 10:14 AM   #4647
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,021
Next time it's out Ill let ya.
Old 05-21-2013, 11:51 AM   #4648
pappionabike
pappionabike's Avatar
Oddometer: 29
dyno jet
I realize this topic has been done to death on here but am in need of help and i've slogged through hundreds of pages looking for a simple answer.
I'm riding an 09 with the top of the airbox drilled out with 5 - 1'' holes, I have a two brothers slip on with the P2 tip. I bought a dynojet kit and followed all instructions for the stage 2 kit and the bike ran like crap, convinced i was way overfueling i went down to the stage one settings and things definately got way better the bike is now rideable at least and seems to have pretty good power all through the range (i think i may have lost a little top end but I did't buy a klr for wide open speed anyway so no biggie)
I still seem to have an excesive amount of popping on decel and was wondering what you guys would suggest to try to remedy this as in smaller jet again? or shim under needle? I've been thinking about going back to the stock jet and needle and just doing the .22 cent shim mod to give it a try. maybe I should just stop whining and put up with the popping and banging lol
any help would be appreciated
cheers.
frustratedinchamissbay
pappionabike is offline   Reply With Quote
Old 05-21-2013, 11:59 AM   #4649
_ransom_
Oddometer: 11
cheers.
Read this in another forum, not sure if it helps..."If it pops and backfires on deceleration you will need to remove and cap off the airpump under the right side air scoop. It is pumping air into the exhaust header to get it hot enough for the cat to work properly. When you take of the factory exhaust they have a tendency to backfire on deceleration." (http://www.klrforum.com/showthread.php?t=9375)
_ransom_ is offline   Reply With Quote
Old 05-21-2013, 12:27 PM   #4650
pappionabike
Oddometer: 29
thanks, i think its going to be back to the stock jet and shimmed needle on the weekend just to give it a try
Times are GMT -7.   It's 09:07 PM.
