Old 05-27-2013, 12:49 PM   #4681
judjonzz
Beastly
judjonzz's Avatar
Oddometer: 2,010
Originally Posted by SkiBumBrian View Post
. I wanna try a 16 or possibly a 17 just for kicks. I think when mountain riding is over this year I will give it a shot...
Everybody has to figure it out for themselves. There is some natural variation in power output among bikes. The more powerful examples will probably pull the taller gear more happily.
What I did on my last chain and sprocket change is switch to 16/45, just a tad taller than stock. (16/46 is almost identical to stock, but 46t sprockets are hard to come by, unless you are in Australia.) With this setup, a drop to 14t on the chainwheel gives nice low gearing for offroad.
For deMille, young fur-henchmen can't be rowing.
judjonzz is online now   Reply With Quote
Old 05-27-2013, 01:29 PM   #4682
GO_OUTSIDE!
dirty hippie
GO_OUTSIDE!'s Avatar
Oddometer: 282
free petcock fix
I have been screwing around with the petcock for long enough that I finally said "That's it, this has been going on long enough!".
I have tested and adjusted and removed orings to no avail. This weekend I took the petcock out and removed the diaphram completely. I replaced the parts with a piece of gasket material, sealed up the hose and nipple and now she flows gas like she is supposed to.
While I was in there I cut the main fuel tube and added a bit of gas line to raise it 3/4" in the tank. I dont know how much extra fuel that adds to my reserve but all I needed was an extra 15 miles to feel comfortable. I think between that and removing the mouse nest from the airbox (I really should clean the filter more often), I have my extra reserve range.
Those make shift clamps were later removed when the assembly wouldnt fit into the tank. The hose isnt coming off without an act of violence. I did have to "clearance" the petcock opening some to get the extension in.
Also, dont try to use the gutted vacuum diaphram as a gasket. it will leak and if your like me, you will be late for work.
Thank you!
Now Go Outside!
GO_OUTSIDE! is offline   Reply With Quote
Old 05-27-2013, 06:15 PM   #4683
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,022
I just gutted mine and went with gas resistant gasket material,so far so good no leaks!
What would you do if you weren't afraid?
Bobcat Goldthwait is my mentor.
8lives is offline   Reply With Quote
Old 05-28-2013, 05:13 AM   #4684
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Location: NE PA Some... PNW Some... On HIGH ADVENTURE Most!
Oddometer: 1,791
Thumb
Originally Posted by astrolump View Post
earlier in the week I installed the the gen 1 rad guard sent to me by John at JNS for testing here in south Florida on my 04....
man what a nice piece of work...
it is still in the raw...no powder coat. those little circles are not really there between the intersections of the grid...its an optical illusion that happens in person too.
installation was very simple. i removed my seat and tank because i have the happy trails rad guard on this bike....but i don't think you would have to if you don't have one. though i may be mistaken.
installing the guard took all of 5 min. fit was good as soon as i realized i needed to bend the little tab that held the old crappy mesh guard out of the way...then the JNS unit went right on and the holes lined up. the long hex head bolt is included with a flat washer..which i did not use on account of my other rad guard. also included was a small tube of red locktight.
it fits fine with my tubular rad guard and IMS tank. please ignore the foam insulation...it is there to seal the air gap with the IMS tank for a bit better cooling efficiency when the fan is on. also, i do not run with the IMS tank front mounts installed...i think they are unnecessary and slow down trailsdie repairs.
and here she is all buttoned back up....
i like the look of it...i think i like it in natural finish too.... it is very stout and should do a fantastic job of protecting the radiator from frontal impacts.
i did not get a chance to ride today. as soon as i can i will update with a ride report and let you know if there is any effect on cooling.
my 04 runs in spec even on the hottest days...so i should notice any negative impact on cooling.
update:
today i rode in traffic at 86F and 61% humidity. no increse in engine temp according to the stock guage...then upon my return home I left the bike to idle at 1400rpm until the fan cycled on and then for about 6 min more...the needle stayed steady just right of center well below the red.
i think i will be getting one of these for all my klr's
Very nice piece of work! I was looking for one last year when I put the new Myler Supercool Rad on my bike. I think I'll pick one up asap! Thanx for posting this up.
Jettn Jim is offline   Reply With Quote
Old 05-28-2013, 07:02 AM   #4685
VikB
VikB's Avatar
Oddometer: 784
Walking around my KLR last week I noticed some front tire damage on my KLR... Michelin T63 with less than 2K kms on it. But a lot of that mileage was on gravel logging roads that are known to shred tires. I had hoped to run this tire until the end of the year, but instead I ordered a replacement that should be here today.
I liked the T63 so far so I ordered a 2nd one. I'll see how long that one lasts.
safe riding,
Vik...
www.klr650blog.com
I didn't done the doo!
VikB is online now   Reply With Quote
Old 05-29-2013, 07:37 AM   #4686
OKlr
25mph gate inpector
OKlr's Avatar
Oddometer: 857
its a shame you had to replace a tire with so much tread left.
OKlr is offline   Reply With Quote
Old 05-29-2013, 03:26 PM   #4687
pappionabike
pappionabike's Avatar
Oddometer: 29
Originally Posted by Jettn Jim View Post
Throw a KLX needle in the thing, clip on about the second notch and a 140 or 142 main, then go like hell!
I ordered the klx kit from eagle mike, I haven't seen the needle yet so was curious how many notches it has? 2nd notch from which end?
pappionabike is offline   Reply With Quote
Old 05-29-2013, 03:33 PM   #4688
WildmanSam
WildmanSam's Avatar
Oddometer: 98
eagle mike's kit comes with the clip already installed on the "2nd" notch. i believe it's 2nd from the end though. (the end that's away from the needle's point)
WildmanSam is offline   Reply With Quote
Old 05-29-2013, 03:36 PM   #4689
pappionabike
Oddometer: 29
Cool2
Great thanks. I have a pile of work to do on my baby this weekend
Old 05-30-2013, 07:27 AM   #4690
OKlr
25mph gate inpector
OKlr's Avatar
Oddometer: 857
i've done the .22 mod to my bike and it runs great with a modified factory exhaust and no toil filter. If i do the klx kit from eagle mikes and remove the snorkel will it be a problem that my slide is already drilled, or do you drill it when you do the klx needle also?
Old 05-30-2013, 08:38 AM   #4691
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,051
Drilling the slide is just a personal preference. No performance difference, just quicker throttle response. Works just fine with the KLX kit.
"Where ever you are, there you go..."
SkiBumBrian is offline   Reply With Quote
Old 05-30-2013, 11:16 AM   #4692
ParaMud
ParaMud's Avatar
Oddometer: 628
It would help if you used a tire tube instead of stuffing the tire with marshmallows.
08 wr250r
04 xt225
ParaMud is offline   Reply With Quote
Old 05-31-2013, 06:39 AM   #4693
Farkle_Adict
Oddometer: 90
I think it is a great idea. Tasty snacks while changing a flat.
Farkle_Adict is offline   Reply With Quote
Old 06-01-2013, 08:53 AM   #4694
VikB
VikB's Avatar
Oddometer: 784
Yup. I'm Bummed. But I'd rather damage stuff because I'm using it than have it be perfect and sitting in my driveway.
Hopefully the replacement lasts longer.
Turned out to be a hard sharp bit of plastic that was deep in the tire.
Oh well. New tire installed. I'd rather spend $100 now than thousands later including some hospital bills...
safe riding,
Vik...
www.klr650blog.com
Old 06-01-2013, 10:49 AM   #4695
Dusty_Bottoms
Adventurer Ordinaire
Dusty_Bottoms's Avatar
Oddometer: 834
Nice looking ride man! The black & white works great. That top box is unique. You get thirsty much?
COHVCO #7369
Dusty_Bottoms is offline   Reply With Quote
Times are GMT -7.   It's 03:13 PM.
