Old 06-29-2013, 07:07 AM   #4801
GO_OUTSIDE!
dirty hippie
GO_OUTSIDE!'s Avatar
Oddometer: 282
Originally Posted by sandalscout View Post
Don't misunderstand, I'm not saying you can't run them, and I have a large one on my own bike.
However, on the Xt250, I used to own one, I recall several folks having problems with the smaller models not flowing enough when the tank got below about 1/2 full. The KLR650 drinks more, so it's understandable that it too could suffer the same problem.
I suppose it is a possibility and wont take much effort to eliminate. Ill replace the entire fuel line with a piece of clear line i have left over so i can still watch for fuel flow.
Thanks for all the replies.
Thank you!
Now Go Outside!
GO_OUTSIDE! is offline   Reply With Quote
Old 06-29-2013, 08:38 AM   #4802
wparkinson
Gear Whore
wparkinson's Avatar
Oddometer: 2,071
Almost Done....
Well I am about there... Just got the 685 kit installed and got the bike back together.... I have made a few more modifications... I haven't fired it up yet but I am chomping at the bit to do so... I got family coming this weekend so I can't get to it this weekend...
Untitled by sky_soldier_82nd, on Flickr
Its not a 100% yet but almost there.....
WP
wparkinson is offline   Reply With Quote
Old 06-29-2013, 08:51 AM   #4803
fleshpiston
fleshpiston's Avatar
Oddometer: 612
WP
Lookin good man!
SRX600
SRX250
SR500
KLR650
fleshpiston is offline   Reply With Quote
Old 06-29-2013, 10:11 AM   #4804
kwoody101
Every day adventurer
kwoody101's Avatar
Oddometer: 22
Did ya paint the tank to match the the dinner table and chairs in the back ground....Happy 4th..
kwoody101 is offline   Reply With Quote
Old 06-29-2013, 10:23 AM   #4805
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,051
Now you know why I don't take pictures in my garage, the same people that look through your medicine cabinet when they go to the bathroom...
"Where ever you are, there you go..."
SkiBumBrian is offline   Reply With Quote
Old 06-29-2013, 11:17 AM   #4806
Dusty_Bottoms
Adventurer Ordinaire
Dusty_Bottoms's Avatar
Oddometer: 842
What's that chain guard from? Is that stock Gen 2?
COHVCO #7369
Dusty_Bottoms is offline   Reply With Quote
Old 06-29-2013, 11:27 AM   #4807
kwoody101
kwoody101's Avatar
Oddometer: 22
I'm sure I'll be able to see ya smiling all the way from here on your maiden run
Old 06-29-2013, 11:54 AM   #4808
wparkinson
Gear Whore
wparkinson's Avatar
Oddometer: 2,071
Well the chain guard is from a DRZ that I got a while back from Ebay by mistake... and wanted to put it on the KLR... So I got another swing arm and took it to my local welding shop. I had a friend that took lots of pics of how it was attached to his DRZ... I took the Swing arm, Chain Guide, rear wheel and the pics to the shop.
They got it done but I wasn't real happy with their work. I figured that a professional welding shop would have done a better job. I use to weld aluminium for a living...if I had the equipment I could have done it myself and done just as good or better a job then what they did.....
It is what it is... F it... Its done...
WP
Old 06-29-2013, 03:20 PM   #4809
RustySpokes
Two-bit throttle bum
RustySpokes's Avatar
Oddometer: 1,102
I just listed a bunch of Gen 1 Parts in the flea market.
http://www.advrider.com/forums/showthread.php?t=899738
RustySpokes is online now   Reply With Quote
Old 06-29-2013, 09:15 PM   #4810
Lappeman
He's Down Again!
Lappeman's Avatar
Location: Lappe, ON Coldest, wettest place...well not quite!
Oddometer: 2,466
Back to fuel flow...
How does the fuel flow out of the tank if it is a vacuum system? I turn my petcock on and no fuel will flow until you start the bike and then it flows. I see a number of posts where they say the fuel flows on gravity...have they gutted the petcock or something along that line?
Thanks for any replies
Lappeman
Photos http://s891.photobucket.com/profile/Lappeman
Youtube http://www.youtube.com/channel/UCB-w...7m3yBQA/videos
2003 KLR 650 Alaskan Adventure
2007 YZ250F Blue Death
Lappeman is online now   Reply With Quote
Old 06-29-2013, 09:49 PM   #4811
SkiBumBrian
DualSport Crazy !!
Oddometer: 1,051
Yep. Vacuum line opens diaphragm valve for fuel. You can gut the sticker or get a petcock for a 660 Raptor
Old 06-30-2013, 04:48 AM   #4812
Lappeman
He's Down Again!
Lappeman's Avatar
Oddometer: 2,466
I see, so they're making it into a gravity feed system. Thanks!
Lappeman
Old 06-30-2013, 06:52 AM   #4813
DesertDuster
Old Pueblo Rider
DesertDuster's Avatar
Oddometer: 194
It is a gravity feed. The vacuum petcock shuts off the flow when the engine is not running or, hence, the loss of vacuum.
By the way, when open full throttle riding into a strong headwind on the freeway (80 mph) will cause the bike to feel like it is starving for gas, which I have attributed to the vacuum diaphram.
I haven't gutted my petcock because I like having the vacuum shutoff.
dd
DesertDuster is offline   Reply With Quote
Old 07-01-2013, 07:32 PM   #4814
chuggins143
chuggins143's Avatar
Oddometer: 130
I disabled the vac fuel cutoff on my 09 with no issues no matter how full the tank is... Google, "KLR hurricane mod" and you'll get several write ups on how to do it. Never had an issue on mine so it sounds like you have a vent issue.
Good luck!
C
09 KLR 650, blue... Done the Doo!, Thermo-bobed!, LED driving lights, aux fuse box, HID high beam, gel battery, custom racks, tool tube, de-Californicated it, moved main fuses to side cover, relocated plate, PVC mod, Hurricane mod, bypassed the side stand switch...
RIP - 95 Honda VFR750 (the most vulgar shade of yellow I could find in the book!)
chuggins143 is offline   Reply With Quote
Old 07-01-2013, 08:02 PM   #4815
fatboy
Oddometer: 313
Good luck!
C
Lots of folks toss the vac petcock cuz it's a possible point of failure. Manual works just fine. It all sounds too complicated to me. Just burp the tank if you think it's a vacuum lock. Extra key in cap and pop it open when the engine sputters. If Engine revs back up then you got a vent problem. -FB
fatboy is offline   Reply With Quote
Times are GMT -7.   It's 02:54 PM.
