Old 07-02-2013, 04:24 PM   #4831
WildmanSam
WildmanSam's Avatar
Oddometer: 96
Originally Posted by Lappeman View Post
You want the ultimate mirrors...http://www.doubletakemirror.com//
i just installed some today and while the mirrors and ram mounts are of high quality, the split clamp perch assembly is CHEAP AS **** . chinese pot metal at best. one of the bolts was partially stripped off the bat and then another one snapped in two when i tightened it down. I'll be going to the hardware store to buy four new bolts to replace them all.
WildmanSam is offline   Reply With Quote
Old 07-03-2013, 02:32 PM   #4832
wparkinson
Gear Whore
wparkinson's Avatar
Oddometer: 2,071
685.... all I can say......
Sent from my SCH-I535 using Tapatalk 2
wparkinson is offline   Reply With Quote
Old 07-03-2013, 06:11 PM   #4833
jack mountain
bottom of the pile
jack mountain's Avatar
Oddometer: 5,100
Originally Posted by CA Stu View Post
Honda XR650-L factory mirrors bolt right up, have similar dimensions, and come with a weight on the bottom of the stalk that reduces the vibrations in the mirror to darn near zero.
Love mine. Better than the rubber isolators from dual star I had before.
"So what you gonna do when the money's gone..."
jack mountain is offline   Reply With Quote
Old 07-26-2013, 09:30 PM   #4834
0theories
Oddometer: 297
Been making some changes to the bike.
Here she is after phase one:
Enthusiastically skeptical...
KLR650, WR250x
Oregon to Panama RR (Guatemala actually...)
KLR Build Thread
0theories is offline   Reply With Quote
Old 07-26-2013, 10:11 PM   #4835
PacificPT
Oddometer: 982
Looks like a good start, black on black...
2000 KLR650
There's roads and there's roads and they call, can't you hear it? Roads of the earth and roads of the spirit. The best roads of all are the ones that aren't certain. One of those is where you'll find me till they drop the big curtain. Bruce Cockburn
PacificPT is offline   Reply With Quote
Old 07-26-2013, 10:18 PM   #4836
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Location: NE PA Some... PNW Some... On HIGH ADVENTURE Most!
Oddometer: 1,776
Thumb
Yo dude... NICE looking bike since we met in Enterprise last year!
Jettn Jim is offline   Reply With Quote
Old 07-26-2013, 10:21 PM   #4837
PacificPT
Oddometer: 982
Just looked at the fairing and light set up you are using, very nice set up.
2000 KLR650
Old 07-26-2013, 10:38 PM   #4838
haydenslides
K.Flotto
haydenslides's Avatar
Oddometer: 95
Anyone recognize these pannier racks? Just got them and am wondering what brand they are and wjat boxes might fit them...
Sent from my SCH-I510 using Tapatalk 2
haydenslides
'00 ZRX1100
'77 Yamaha XT500
'02 Kawasaki KL250 Super Sherpa
'74 Honda CT70 - the original adv bike
port angeles, washington, usa
haydenslides is offline   Reply With Quote
Old 07-28-2013, 10:39 AM   #4839
0theories
Oddometer: 297
Thanks Jim! Your bike was a big inspiration to my build
KLR650, WR250x
KLR Build Thread
Old 07-28-2013, 12:57 PM   #4840
El Brad
Leave it long on top
El Brad's Avatar
Oddometer: 447
They are Happy Trails "Northwest" racks.
Don't think they make them anymore, believe they were a "Givi"
mount.
" THE TRUTH IS, IF WE HADN'T DECIDED
TO BE YOUNG FOREVER, WE'D BE OLD "
El Brad is offline   Reply With Quote
Old 07-28-2013, 02:16 PM   #4841
bdcorrigan
bdcorrigan's Avatar
Oddometer: 647
Is the T-mod 1/4" tubing, correct?
bdcorrigan is offline   Reply With Quote
Old 07-28-2013, 02:49 PM   #4842
XDragRacer
Oddometer: 3,100
Not size-critical IMHO; just has to connect to the tee tightly enough not to fall off; 1/4" ID sounds about right.
XDragRacer is offline   Reply With Quote
Old 07-28-2013, 06:56 PM   #4843
Lappeman
He's Down Again!
Lappeman's Avatar
Location: Lappe, ON Coldest, wettest place...well not quite!
Oddometer: 2,286
Oil Seepage..
Hey Guys, I'm out on a trip currently and developed an oil leak thru the seepage hole in the bottom of the water pump cover, which means the oil seal in the cover is leaking...not bad right now but my question is, will it continue to get worse and have to be replaced or will I be able to manage it by adding oil every once in awhile. Have 12,000 or so kms to cover yet.
Thanks for the input!
Lappeman
Photos http://s891.photobucket.com/profile/Lappeman
Youtube http://www.youtube.com/channel/UCB-w...7m3yBQA/videos
2003 KLR 650 Alaskan Adventure
2007 YZ250F Blue Death
Lappeman is offline   Reply With Quote
Old 07-28-2013, 06:57 PM   #4844
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Oddometer: 1,776
Thumb
Awesome Brother.. Glad Desiree' could inspire:)
Old 07-28-2013, 07:43 PM   #4845
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,793
I believe that you are fortunate in that the area is not under oil pump pressure. The oil seal/waterpump seal is not in the cover, but behind the water pump impeller which is under pressure. You will need a new seal, 2 new O rings and probably a water pump gasket.
You dont tell us where you are? I personally would change that seal out as soon as possible particularly if you are having to add oil and if you are near to somewhere that it can be done or do it yourself. You might be OK, but a back-up plan if it gets progressively worse would be in order
Tsotsie is offline   Reply With Quote
Times are GMT -7.   It's 09:20 AM.
