Old 08-25-2006, 02:53 AM   #1
Cutter OP
Girivek
Cutter's Avatar
Oddometer: 508
Send a message via Yahoo to Cutter
Bluhduh R1100GS Transmission Problems
Anyone give me any info regarding the fabled transmission failures of the 95 GS's? Oddly enough I've got about 7500 original miles on mine and I'm kinda freakin' about the possibility of a surprise lockup some where some place, sometime..........
"There is no vice more painful than that of luxurious habits"
Cutter is offline   Reply With Quote
Old 08-25-2006, 06:46 AM   #2
AntonLargiader
AntonLargiader's Avatar
Oddometer: 3,460
Lockup isn't likely at all. Some (OK, a lot of) info on my website on the 5-speed oilhead trannies.
http://www.largiader.com/tech/oiltrans/
Old 08-25-2006, 07:37 AM   #3
Stonewall
The Wild
Stonewall's Avatar
Oddometer: 1,796
Transmission
I have a 95 GS. I bought used 2.5 years ago with 19K on it. At 24 K I had a the trainsmission problem. Their was a problem with the bearings in the transmission in the 95, which can be repaired with the Quite Bearing Kit. Mine started clicking like my drive shaft was hitting something. I have talked to a lot of 95 owners with over 100K who have never had a problem with theirs. Be sure you add the Hard Parts are you will break it.
Stonewall, That Guy From
Improvise, Adapt, or Overcome .
For "THE BEST COOLER MADE FOR MOTORCYLCE RIDING" Look Here
http://www.advrider.com/forums/showthread.php?t=252781
http://stonewall.smugmug.com/
3rd Annual WMRS Ride III in Bishop, CA Ride Report 07
http://www.advrider.com/forums/showthread.php?t=254807
4th Annual WMRS Ride IV Ride Report 08
http://www.advrider.com/forums/showthread.php?t=369576
Stonewall is offline   Reply With Quote
Old 08-25-2006, 11:10 AM   #4
jonzn
Oddometer: 80
Just replaced mine on my 95 GS. Bought an M94 trans from Beemerboneyard.com that had been rebuilt/upgraded by Bruno's Machine Shop up in Ontario. Shifts like a dream now.
Mine started the "jumping thing" in 5th gear at about 40K miles. Put up with it till 47K miles when it began to do the "jumping thing" more frequently than I wanted to put up with and I was planning on a long trip.
Tom Cutter at Rubber Chicken Racing is another guru for rebuilding these transmisssions.
Hope that adds to your knowledge base.
jonzn
jonzn is offline   Reply With Quote
Old 08-25-2006, 11:31 AM   #5
matey peeps
Bead Buddy
matey peeps's Avatar
Oddometer: 3,287
A good used trans from an RT or other R1100 will also work. My 96 wears the M97 trans from a 99RT. There's a few salvage yards that specialized in BMW parts.
Your $5 ticket to the buttery goodness that is Smugmug - t7Ut8i5M4CRzY
matey peeps is offline   Reply With Quote
Old 08-26-2006, 10:53 AM   #6
Yo. I'm Bow.
arm chair
Yo. I'm Bow.'s Avatar
Oddometer: 71
Thumb redline heavy
redline heavy in the tranny, and preload before shifting makes my 95 r/1100 shift smooth as butter S.B
dlanlod
Yo. I'm Bow. is offline   Reply With Quote
Times are GMT -7.   It's 10:37 PM.
