Old 12-27-2006, 02:16 PM   #31
R.Markus
Damage Addict
R.Markus's Avatar
Oddometer: 1,145
I have the stock KTM aluminum bash plate on mine. It cracked from vibration (I'd like to say it was from riding hard, but it wasn't) in less than 2000 miles. The crack runs from the right side just behind the sport where KTM is cut into the plate and runs to the oil drain plug hole.
I would venture a guess as to say that the free hanging area behind the rear mounting bolts vibrated and caused the area to fatigue.
I am thinking of having it rewelded and modified to prevent it from happening again (because I'm cheap).
I'll take a picture of it when I get off work tonight.
The beatings will continue until morale improves.
R.Markus is offline   Reply With Quote
Old 12-27-2006, 05:09 PM   #32
planetmike
planetmike's Avatar
Oddometer: 119
First Pic
Originally Posted by PackMule
Thanks. Take a whole bunch of pics, and post them up to this thread.
Ram1000 -- Can you post some pics of the Utah Sports plate and its mounting?
PackMule,
Here's a photo of the Flatland plate out of the box. Note the reinforced bulge located where the spin-on filter would be. I'll send more photos of it once I have time to put it on, but my first impression is that its worth the dosh.
Oh, it is by far improved in thickness compared with the KTM plate.
planetmike is offline   Reply With Quote
Old 12-27-2006, 05:14 PM   #33
planetmike
planetmike's Avatar
Oddometer: 119
I'd also add that aluminum fatigues easier than steel. So if you or anyone has had to bend or bang the KTM plate back into shape, this can only be done a limited number of times, and with each time, the plate is weakend.
Old 12-27-2006, 05:21 PM   #34
Disquisitive Dave
Not so wise fool
Disquisitive Dave's Avatar
Oddometer: 457
Here we go: SW-MOTEC aluminum skid plate in place on a '96 RXC 400.
Left side
Right side.
Bottom
The old plastic plate and mounts.
The aluminum plate didn't match up with the previous "half moon" mount thingys. It came with it's own. A long bolt holding the engine to the frame granted access to swap them out.
More bigger photos here.
Now about that oil leak... It's coming from behind the flywheel on the main crank... looks like an engine teardown might be in my future...
Disquisitive Dave is offline   Reply With Quote
Old 12-27-2006, 05:40 PM   #35
PackMule OP
love what you do
PackMule's Avatar
Oddometer: 19,460
Mike -- thanks for the pic. Keep us updated through the installation process!
Dave -- I'm liking that plate. A lot. Looks like the contender, at the moment. Was the mounting hardware incl. as part of the plate price, or did you have to order it seperately? Can you get an oil change done with it in place? (assuming it doesn't all just leak out...)
j/k
Nate in N.E.
Yes, I have a Dakar problem -- that there are 50 weeks of the year without Dakar!
They don't expect you to finish. That's why it's the Dakar. -- PPiA
PackMule is offline   Reply With Quote
Old 12-27-2006, 05:41 PM   #36
ram1000
ram1000's Avatar
Oddometer: 1,833
It mounts using pre-bent brackets around teh frame and bolted from the plate up into the bracket. All the aftermarket plates I have seen use this method.
ram1000 is offline   Reply With Quote
Old 12-27-2006, 06:12 PM   #37
planetmike
planetmike's Avatar
Oddometer: 119
Nice plate but I want to be clear that I'm looking for a plate to protect a LC4 Adventure and in particular, protect the area where the spin-on filter is. Not sure the Utah plate will do this.
Old 12-27-2006, 06:31 PM   #38
mars
Starbucks anyone?
mars's Avatar
Oddometer: 1,900
Originally Posted by Loadedagain
creeper is a wanker. as usual the wanker is correct. i do have a carbon skidplate that is very well made (thanks matey peeps btw.).
when it came time to run the alcan 5000 i removed it and installed the oem ktm plate on my 2002 640. i do trust the carbon piece, but the properties of carbon fibre don't make it too useful after one good hard hit. aluminium on the other hand can sustain many hits without weakening.
loaded opinion? run carbon for bling. run aluminium if you want to run hard without changing out your skid plate.
did you ever post a report about the Alcan?
mars is offline   Reply With Quote
Old 12-27-2006, 08:14 PM   #39
ram1000
ram1000's Avatar
Oddometer: 1,833
They have a plate specifically for the LC4 with oil filters on the frame. This one is for the SXC and SMC models with no oil filter at that point. I don't know how much they look alike. I like the UTAH plate because it is brake bent at multiple locations following the frame around the engine. I cut the aluminum side plate down on the left side of teh motor to match the right side for looks. It was about an inch higher when I got it.
Old 12-27-2006, 10:17 PM   #40
R.Markus
Damage Addict
R.Markus's Avatar
Oddometer: 1,145
I took a picture of the crack in mine. You can see it fatigues right behind the strong atrea where it attaches to the frame and where the verticle part of the plate ends. That flat area just sticks out to the rear and vibrates.
Old 12-27-2006, 10:58 PM   #41
Disquisitive Dave
Not so wise fool
Oddometer: 457
Mounting hardware was included. I used a single part number on my order.
I'm pretty sure that one could do an oil change without removing the plate. i.e. there's enough space for tools. However I'm leery about the plate catching the oil on its way out, leading to a huge mess... I haven't been inclined to leave it on to find out. It's easy enough to take off.
Old 12-28-2006, 07:50 AM   #42
Beez
Given to fly
Beez's Avatar
Oddometer: 5,796
Great thread
Could you guys post the thickness of your skidplates please?
I think I remember reading in the RFS forums that Flatland skidplates were thicker than most others.
Beez is offline   Reply With Quote
Old 12-28-2006, 09:23 AM   #43
Disquisitive Dave
Not so wise fool
Oddometer: 457
The sw-motec plate specs claim 3 mm. My scale concurs.
Old 12-28-2006, 11:33 AM   #44
planetmike
planetmike's Avatar
Oddometer: 119
In metric, Flatland is approx 4.76 mm thick.
OK, just to add to the confusion. I see that the famous Sommer's of DE has a carbon cover just for the spin-on oil filter. Use this under your existing plate should work for Adventures.
http://download.ktm-sommer.de/SP_PDF...II_038-045.pdf
Old 12-28-2006, 03:11 PM   #45
Beez
Given to fly
Beez's Avatar
Oddometer: 5,796
I just measured the thickness of the aluminum skidplate from KTM and it is 1/8" thick. Not sure what that is in metric but I think it is 3mm.
Times are GMT -7.   It's 02:00 PM.
