Old 12-28-2006, 06:47 PM   #46
PackMule OP
love what you do
PackMule's Avatar
Oddometer: 19,484
Other KTM plate failures?
Anyone else had a failure in the KTM plate like RMarkus?
Mark, any chance you had an impact behind that point that led to the crack? Doesn't seem like there'd be enough weight astern of it (unless there was a lot of mud or clay or something) to cause a vibration fatigue...?
Nate in N.E.
Yes, I have a Dakar problem -- that there are 50 weeks of the year without Dakar!
They don't expect you to finish. That's why it's the Dakar. -- PPiA
PackMule is offline   Reply With Quote
Old 12-28-2006, 07:08 PM   #47
Ruffus
Dirty Old Mudder
Ruffus's Avatar
Oddometer: 4,100
if it was covered in mud, it probably wouldn't have cracked from vibration, you need to jam something in there to absorb & prevent it from vibrating, a piece of rubber, high density foam?? something, same vibrations you feel in your handlebars & footbegs will go to the plate & a little unsupported overhang will get high freqency vibrations & eventually crack
We spend our lives chipping away at our ignorance :wisdom by Dakez
Friendship is like peeing your pants, everyone can see it, but only you
can feel the true warmth.: wisdom by ??
Reverse Darwinism...he's only alive because he's to stupid to die. : wisdom by AZRamjet
06 Husky TE510
Ruffus is offline   Reply With Quote
Old 12-28-2006, 07:54 PM   #48
ram1000
ram1000's Avatar
Oddometer: 1,838
Mine cracked out of the mounting holes twice before I replaced it.
ram1000 is offline   Reply With Quote
Old 12-28-2006, 08:27 PM   #49
mars
Starbucks anyone?
mars's Avatar
Oddometer: 1,919
If any one would like to part with the cheap plastic 96 LC4 chain guard, I am looking for one.
mars is offline   Reply With Quote
Old 12-28-2006, 08:39 PM   #50
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
At about 4,000 miles my '03 cracked on the left side, just where the side plate (w/logo) meets the bottom plate at the rear. Welded it up and it's been good for 3,000 miles since...
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 12-28-2006, 08:43 PM   #51
PackMule OP
love what you do
PackMule's Avatar
Oddometer: 19,484
Fatigue failures in non-KTM plates?
Interesting.
Anyone else have fatigue failures on the non-KTM aluminimum plates?
Nate in N.E.
Old 01-11-2007, 10:50 PM   #52
R.Markus
Damage Addict
R.Markus's Avatar
Oddometer: 1,145
I just got my skid plate back from having it rewelded...we'll see how long it lasts.
I'll just be happy getting rid of the noise it made when it vibrated.
The beatings will continue until morale improves.
R.Markus is offline   Reply With Quote
Old 03-07-2008, 10:56 AM   #53
R.Markus
Damage Addict
R.Markus's Avatar
Oddometer: 1,145
I just ran across this old thread and thought I'd update it...
The repair only lasted about 200 miles before cracking again in the same spot.
I had a small triangular piece of aluminum welded to extend the vertical part of the plate a bit farther back past the area that keeps cracking. It's worked well for the past year.
Yes, the bike is filthy.
R.Markus screwed with this post 03-07-2008 at 11:55 AM
Old 03-07-2008, 11:02 AM   #54
PackMule OP
love what you do
PackMule's Avatar
Oddometer: 19,484
Good idea!
Nate in N.E.
Old 08-29-2008, 01:39 PM   #55
R.Markus
Damage Addict
R.Markus's Avatar
Oddometer: 1,145
My skid plate cracked again on the opposite side recently...
I had it welded the dsame way as the other side...
Old 11-09-2008, 08:00 PM   #56
Kapp555
Better to be Offroad!
Kapp555's Avatar
Oddometer: 671
anyone see any good deals on skid plates recently? sales etc?
Kapp555 is offline   Reply With Quote
Old 11-09-2008, 08:25 PM   #57
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,260
If you need a cheaper skidplate then why not try a KTM poly-resin piece? See first page of this thread for more info. Pretty cheap skid, but I haven't shopped around...
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 11-09-2008, 08:35 PM   #58
Kapp555
Kapp555's Avatar
Oddometer: 671
Must be blind cant find them for the lc4..maybe they discontinued?
Old 11-09-2008, 10:23 PM   #59
meat popsicle
Ignostic
Oddometer: 14,260
Here is one source:
http://www.ktmcyclehutt.com/ktmstore...ture_parts.htm
just shy of $70... shop around.
Old 01-18-2009, 08:57 AM   #60
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
My OE plate has finally terminally shit the bed. Too cracked to deal with. Went with one of these from Flatlands Racing. Very beefy...
http://flatlandracing.com/Merchant2/...ry_Code=24-KTM
Chris
1943 BSA M20WD
Times are GMT -7.   It's 05:21 PM.
