06-01-2008, 11:42 PM
#76 |
Oddometer: 29
One year in the making and it took me 2 months to get those carbs to fit and work
06-02-2008, 05:06 AM
#77 |
Bavarian Murder Weapon
Oddometer: 672
Wow - fantastic job Shawn!!!
Anymore details? What sort of carbs are those - and the seat - and the batteries - etc!!!!
_________________ 2008 BMW R1200RT SE Silver - "Tonto" 1981 BMW R65 - "Seven" My R65 Cafe Project |
06-02-2008, 05:14 AM
#78 |
Oddometer: 29
Ducati monster seat and carbs, GEL jetski 20ah battery laid down.
06-02-2008, 05:22 AM
#79 | |
Oddometer: 672
what did the bike start life as? was the Ducati seat altered much?
06-02-2008, 07:41 AM
#80 |
Oddometer: 29
8 bikes there and two of them aren't even BMW's
![]() Seat had to be cut all around the front to fit the tank. I got a fram and monoshocked it from a newer bike who's engine I used as well. The wheels are R100R and had to be machined to fit. The front end is K series and oilhead brakes.
06-02-2008, 08:22 AM
#81 | |
Oddometer: 2,077
Bacon... it makes everything better. |
06-02-2008, 08:45 AM
#82 |
Oddometer: 29
No!
Its got super-bike acceleration but I had hoped it would do more to the gallon with the carbs being newer technology. If I hammer it to the red line in first and slam the throttle shut its as though the back wheel has ABS and I get a big dotted line behind ![]() If I can't get it to do 40+mpg then they will be going. Good thing is they don't pee petrol all over my feet from the float valves |
06-02-2008, 11:59 AM
#83 |
Old Enough To Know Better
Oddometer: 5,516
The stock Mikunis off of Monsters leave a lot to be desired. I had a M900 for 6 1/2 years. For about the last 4 of those, it had Kehin FCR flatslides.
Coincidentally, the FCRs improved the mpg on the M900 from about 41 mpg to just over 45 mpg. Highway or around town the same. If i were going that route on my R80, I would be looking for some Kehin FCR split singles in 39mm. (I had 41mm on the Duc.) Edit: I looked back at your vent hose arrangement - can't see for sure, but each carb need to have that hose routed in to a dead air space somewhere near the carbs. They are very sensitive to air currents and fluctuations at speed, which in turn may affect mileage and/or rideability. They shouldn't be plugged directly to each other (which it almost looks like) because of the strong internal pulses affecting the carbs with every intake stroke. They need non-turbulent free air to supply to one side of the diaphram.
Mark J Merritt Island, FL When a person asks you for advice, they don't want advice. They want corroboration. mark1305 screwed with this post 06-02-2008 at 12:06 PM |
06-02-2008, 01:25 PM
#84 | |
Oddometer: 327
The motorne cover is made of fibre glass and doesn't fit too well. The aluminium version doesn't seem to be available. We did it ourselves as cast aluminium. The seat is not a Ducati seat, this one is hand made, wider and fits perfectly to the BMW rear frame. Greetings, Rudi |
06-02-2008, 01:41 PM
#85 | |
Motorcycle Rescue
Oddometer: 427
I agree 110%%!! Beautiful job!
PhacK Quote:
"There are only two true sports: bullfighting and auto racing. The rest are simply games," Ernest Hemingway |
06-02-2008, 10:34 PM
#86 | |
Oddometer: 672
My bike will be a Frankenbeemer too I think - already have R65 frame and motor, R75/5 gearbox, K1100LT rear wheel. Will have K75S forks, brakes and front wheel, with R11** front caliper. Still up in the air about the tank - you've done a great job there - well done!
06-03-2008, 02:58 AM
#87 |
Oddometer: 29
Ta!
I used K100 yokes because I knew I wanted clipons. The 75's have a built in riser affair. The forks are 75's. I changed the stem but other people have told me I didn't need to I did it on the garage floor with a blow lamp and a lump hammer so it cost nothing and was easy enoughI don't think the steering lock would have worked if I'd used the K stem. |
06-21-2008, 11:01 PM
#88 |
Left right out
Oddometer: 738
Seen today at Road Warriors Cafe. Mt White NSW. Australia. I think it is an R65.
Me WnRn blog.....http://rossmz.blogspot.com/ "el Lobo" 2002 1200 Bandit... For sale 1971 Honda CL450 being brat'ed/cafe raced. 2009 Triumph Speedmaster. |
06-22-2008, 06:02 AM
#89 | |
Oddometer: 1,717
06-22-2008, 07:33 AM
#90 | |
HPM
Oddometer: 506
