Old 09-03-2006, 09:05 AM   #1
jaydee1445 OP
Footpeg Crash Tester
jaydee1445's Avatar
Oddometer: 4,090
$3 odometer mode switch
I did not like the looks of the KTM tripmaster switch and really hated the price$$$, so I made my own.
Get momentary pushbutton switch from radio shack, drill hole in switch housing, and hook to brown and brown yellow wires in switchmaster connnector AN/4.
I drilled my hole to far left and couldn't get nut to fit so I siliconed it in place. Drill your hole as close to the outside to use nut that comes with switch.
Button will cycle through the trip functions, would need second button to reset.
jaydee1445 is offline   Reply With Quote
Old 09-03-2006, 09:27 AM   #2
radiowazee
Golewahz???
radiowazee's Avatar
Oddometer: 421
Very smart looking install... are the control wires already run to the left handgrip, or did you have to run wires back to the tripmaster unit?
When I'm not rockin' @ radio.wazee I'm screamin' around Denver on my:
- 2006 KTM 950 LC8 Adventure-S GO!!!!!!! **Sold**
- 2003 BMW K1200RS **Sold**
RALLY PAN-AM RIFF RAFF '08, '09, '10 EXTREME Member
radiowazee is offline   Reply With Quote
Old 09-03-2006, 09:43 AM   #3
TipOver
TipOver's Avatar
Oddometer: 405
Too Late
Jaydee, you posted this 2 weeks too late for me. I just installed a tripmaster. Good Post...
Do you beleive that you can re-zero a function using another button? That feature isn't available with the tripmaster. You can only scroll the trip 2 function up or down. You have to reset using speedo controls.
TipOver is offline   Reply With Quote
Old 09-03-2006, 10:20 AM   #4
Skinner
Mr.KTM
Skinner's Avatar
Oddometer: 5,754
I love this idea! Thanks!
You might be an ADVRider if:
You recognize your friends by the sound of their mufflers.
http://www.meetup.com/Chicagoland-Du...torcycle-Club/
www.jimstarwaltteam.com
Skinner is offline   Reply With Quote
Old 09-03-2006, 04:47 PM   #5
KTMDAD
KTMDAD's Avatar
Oddometer: 361
Thanks for this post, I was just going to plop down the $$ for the KTM switch, yours even looks better.
Where do you wire the switch into? Any pictures of were it plugs into.
KTMDAD is offline   Reply With Quote
Old 09-03-2006, 05:22 PM   #6
jaydee1445 OP
jaydee1445's Avatar
Oddometer: 4,090
DOOH!! how did I post in thumpers?
The conector is tie wraped under inst. cluster. I belive it is rectancluar with four wires,brown, br/yellow, yellow, gr/red. Brown wire is ground but tested around 5v with my volt meter. Must have been reading sensor voltage???
I played around jumping the wires and the only function I could make work was cycling through the functions no reset The odometer cycles to next function when ground is applied then removed.
Hey tipover could you test the output of the tripmaster so we can figure how to do the other functions?
Old 09-03-2006, 06:25 PM   #7
alpiv
Sr. nOOb
alpiv's Avatar
Oddometer: 2,173
I like!
Now for the info on reset---
Who has it?
Creeper?
alpiv is offline   Reply With Quote
Old 09-04-2006, 06:25 AM   #8
jaydee1445 OP
jaydee1445's Avatar
Oddometer: 4,090
Woke up lastnight thinking about how tripmaster works. Buttons two and three increment trip two up and down. I bet grounding the yellow or the gr/red while in trip two will work. Humm!!!!!!!!! where to mount more switches????
Old 09-04-2006, 08:17 PM   #9
Two Dot
Two Dot's Avatar
Location: So Cal (winter) Montana (summer) NC (spring&fall)
Oddometer: 566
I Love it!!!!
Great job with the report...
Now get busy and give us some details... how did you route the wire? ect...
I have always wanted this but didn't like the KTM part.
Thanks.
03 640 Adventure
05 950 Adventure "S"
Two Dot is offline   Reply With Quote
Old 09-05-2006, 04:53 AM   #10
jaydee1445 OP
jaydee1445's Avatar
Oddometer: 4,090
Originally Posted by Two Dot
I Love it!!!!
Thanks.
I just ran wire next to factory harness w/ zip ties. Use black zip cord, blends in good,you can see it in the pic. Solder wire to switch and crimp conectors pushed into factory plug.
Old 11-29-2008, 12:54 AM   #11
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,894
Cool2 More work
Brilliant - I went and did the same (Brn + Brn/yell wires) and it scrolls through the modes.
If you short the other two wires against the Brown in Trip 2 it will either increase or decrease the Km's (or miles if your that way inclined). A toggle switch would suit that little beastie for a cheap tripmaster.
Its off to the electronics shop now to see the nerds for another toggle and were done. I'll chuck up a pic when im done.
Pete640 is offline   Reply With Quote
Old 11-29-2008, 02:45 AM   #12
braaap!
waiting for the big one
braaap!'s Avatar
Oddometer: 2,493
the oem switch block toggles the trip and sets increments up or down... no remote trip reset function
neat solution though jaydee!!
braaap! is offline   Reply With Quote
Old 06-11-2010, 01:27 AM   #13
Valters
Oddometer: 4
Hi,
I have 640 Adventure R 98`. I want to make a tripmaster switch on the handlebar, but from my tripmastercome out just 3 free cables: blue, grey and violet. They all are in one connector. Any ideas?
Valters is offline   Reply With Quote
Old 06-11-2010, 06:02 AM   #14
Valters
Oddometer: 4
In Touratech.de I find that:
Violet is UP
Grey is DOWN
Blue is ''ground''(-)
But how it works?
Violet+Blue=? up ?
Grey+blue=?
Times are GMT -7.   It's 03:18 PM.
