Old 09-04-2006, 02:22 PM   #1
meat popsicle OP
Ignostic
meat popsicle's Avatar
Oddometer: 14,244
Why Clean Your Bike
Now I would not say that I am Mr. Clean. (leave him alone YFF!) I understand how easy it is to let cleaning slide; you could be riding right? Or how about a siesta in the hammock... it doesn't seem as important as chain tensioning or other periodic maintenance, but that is a mistake.
Why? Because cleaning your bike, and I mean thoroughly - get down on your hands and knees and try to get into all those places your fingers can't quite push the rag, or start disassembling until you can - like I was typing, a good cleaning will force you to thoroughly inspect your bike and you will see things that you would not ordinarily notice. Not only that, but a clean bike is much easier to check than a dirty one. Your detection rate will improve, once all that dirt is out of the way.
Here is my example, and start of a search for information on a potential issue. I was down on my knees, when I noticed what looked like oil spray directly behind my kick starter shaft. I got curious and layed down on my back and found this:
See it? No? OK, how about a crop:
Yes, a drop of oil hanging from the bottom of my kick starter.
So now, that I know there is a potential issue - leaking kick starter seal? - I can do something about it. If I had not been down there cleaning my bike I might have ended up with a bigger problem, which usually happens in BFE.
Oh yeah, in case you didn't notice, I am soliciting information on potential sources of that leak. I would think that the kick starter shaft is a likely culprit, so I cleaned it up thoroughly in order to monitor it.
Here is the assembly:
Two seals are listed:
#17
Item #: 0760223270
SHAFT SEAL RING 22X32X7 BSL
Quanity On Diagram: 1
Cost Each: $7.25
Item #: 58038022000
CU-SEAL RING DIN7603-12X18X1,5
Cost Each: $1.50
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 09-04-2006, 02:34 PM   #2
CaptTurbo
CaptTurbo's Avatar
Oddometer: 1,099
It's a good thing your bike was dirty or that oil wouldn't have soaked into all that dirt making the problem easy to spot. Keeping your bike clean is just wreckless and irresponsible!
CaptTurbo is offline   Reply With Quote
Old 09-04-2006, 03:15 PM   #3
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Me - m - ories... like the cor - ners of my mind, misty water color me - m - ories... of the way we were.
So... how's tricks?
creeper is offline   Reply With Quote
Old 09-04-2006, 06:24 PM   #4
motostyle
\/ The MAN - R.I.P. \/
motostyle's Avatar
Oddometer: 186
"Why? Because cleaning your bike, and I mean thoroughly - get down on your hands and knees and try to get into all those places your fingers can't quite push the rag, or start disassembling until you can - like I was typing, a good cleaning will force you to thoroughly inspect your bike and you will see things that you would not ordinarily notice. Not only that, but a clean bike is much easier to check than a dirty one. Your detection rate will improve, once all that dirt is out of the way."
I broke into a cold sweat when I read this. For a second, just a second in time, I was 17 again and my dad was yelling at me to clean my VW so i could see if any oil was leaking from somewhere new.
motostyle is offline   Reply With Quote
Old 09-04-2006, 07:17 PM   #5
BlitzBike
LC4 Pilot
BlitzBike's Avatar
Oddometer: 800
#17
Item #: 0760223270
Cost Each: $7.25
Item #: 58038022000
Cost Each: $1.50
Welcome to the club...mine looks exactly like that but, you know why I ain't gonna fix it? Because if its leakin now when I barely ever used my kicker-- then it will just do it again after i fix it. Timing site glass weeps too.
BlitzBike
BlitzBike is offline   Reply With Quote
Old 09-04-2006, 08:27 PM   #6
meat popsicle OP
Ignostic
Oddometer: 14,244
poopy schmoopy icky yick
- Mrs. Popsicle
Old 03-25-2009, 07:06 PM   #7
Mr. Ray
Chemically Enhanced
Mr. Ray's Avatar
Oddometer: 3,633
this thread eluded me until now. It makes a lot of sense. I love it.
It's about this big.
http://www.roadtofermentation.blogspot.com
Mr. Ray is offline   Reply With Quote
Old 03-25-2009, 08:13 PM   #8
meat popsicle OP
Ignostic
Oddometer: 14,244
Since this thread got unearthed, I am quoting my favorite reply.
And while my fingers are rattlin' away, I might as well say one (other) thing that might contribute to lack of cleaning, and maybe maintenance too: The Disposable Culture.
Old 03-25-2009, 09:33 PM   #9
bongodave
Join my cult!
bongodave's Avatar
Oddometer: 41,883
Great article, and well said. I've fixed so many things just by fiddling with them!
How many people do you know who will ditch a car when it starts to give them problems? It's like replacing it is a smarter move than fixing it. That's not always true. You can make a decent living buying appliances with just one little problem and reselling them.
Cubans are still driving cars from the 50s. A little care and some elbow grease go a long way.
Freedom without regulations that protect the general good is nothing more than anarchy by the rich. -R-1150-RS
Corporatism walking hand in hand with patriotism .... just as deadly as religion. - Icewalker
if you depend on lies and misinformation to support your belief system, you need a better belief system. - Dances With Roads
bongodave is offline   Reply With Quote
Old 03-25-2009, 09:51 PM   #10
Zerodog
Oddometer: 1,233
Mine has that same drip. I need to do the deal myself. I believe mine is leaking from the little one inside the shaft.
Zerodog is offline   Reply With Quote
Old 03-25-2009, 09:55 PM   #11
meat popsicle OP
Ignostic
Oddometer: 14,244
You saw Creeper's link eh?
http://www.advrider.com/forums/showthread.php?t=156231
ps - mine stopped or really, really slowed down all by it's lonesome...
Old 03-26-2009, 04:38 AM   #12
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,852
Why Clean Your Bike
Why Clean Your Bike
exactly
plugeye is offline   Reply With Quote
Old 03-26-2009, 05:26 AM   #13
banshee8989
AKA: Fartman
banshee8989's Avatar
Oddometer: 841
Looks to me if you ride a KTM cleaning is essential. . After 15 years of abuse on a Honda the thing has never sprung a leak.
But seriously cleaning and inspecting is important and not just on dirt bikes. I wish we could get cage drivers to do the same thing.
We have the best congress money can buy
banshee8989 is offline   Reply With Quote
Old 03-26-2009, 05:34 AM   #14
Grootseun
Thumpin around
Grootseun's Avatar
Oddometer: 87
I had some intermittent Idling probs on my 06 Dakar. I decided to have a look see, couldn't see anything under the dirt
Cleaned the rocker cable thingy assembly (technical term) and voila problem solved.
Now the bike has to wait till sumthin else packs up before i clean it again...
Practice randon acts of intelligence
and senseless acts of self-control
Grootseun is offline   Reply With Quote
Old 03-26-2009, 06:26 AM   #15
meat popsicle OP
Ignostic
Oddometer: 14,244
Originally Posted by plugeyes
Why Clean Your Bike
exactly
You can lead a horse to water, but you can't make him drink.
Times are GMT -7.   It's 09:07 PM.
