Old 09-13-2006, 10:27 AM   #1
MF1A OP
Ride with the Wind
MF1A's Avatar
Oddometer: 267
Cry overheating on the road (lc4)    please help
Hello guys.
i'm on the road again, on a long trip around my country, and i'm having problems of overheating, i'm discarting posible issues like air on lines, coolant leaks, water pump issues, problems on the rads, but everything is perfect, so i was wondering, maybe the thermostat is close (or wathever the thermostat do when runs out), so any of you guys had removed the thermostat of your lc4? is any issues i should know about?, please remember i'm on the road, i have only basic tools, and no chance of buying new stuff for at least 1 more week.
all the info i can get is more than wellcome
thak you guys
Hi My name is Matimoto and i'm an DAKARholic! El MatiMoto
MF1A is offline   Reply With Quote
Old 09-13-2006, 12:09 PM   #2
PackMule
love what you do
PackMule's Avatar
Oddometer: 19,460
Originally Posted by MF1A
Hello guys.
thak you guys
Do the rads get hot to the touch when the bike has been running for a bit? This would indicate that there is indeed coolant flowing through them, and the thermostat is most likely not stuck shut (or at least not completely).
When you say the bike is overheating, is it puking coolant out the overflow? Or is the temp light coming on? You had wired a fan, right? Is it still working?
Hope you can get this sorted.
Nate in N.E.
Yes, I have a Dakar problem -- that there are 50 weeks of the year without Dakar!
They don't expect you to finish. That's why it's the Dakar. -- PPiA
PackMule is offline   Reply With Quote
Old 09-13-2006, 01:30 PM   #3
bmwktmbill
Traveler
Oddometer: 5,049
Can you beg or barrow a meat or candy thermometer and check the actual coolant temp. That would tell a lot.
Bill in Tomahawk, WI.
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill screwed with this post 09-13-2006 at 02:44 PM
bmwktmbill is offline   Reply With Quote
Old 09-13-2006, 01:53 PM   #4
Zerodog
Oddometer: 1,233
Are you sure your waterpump is OK? One day my bike got hot riding around town. I had low coolant from a bad waterpump seal. The bearings in the pump had seals that were starting to melt. It got that hot in there! Fixed it and now the bike runs cool again.
Zerodog is offline   Reply With Quote
Old 09-13-2006, 02:25 PM   #5
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,206
One link from the index that may or may not help:
http://www.advrider.com/forums/showthread.php?t=58804
Sorry, but I have not seen any guides to replacing the thermometer. I swear I have seen some discussion about testing it... one test is to let the bike heatup - wait, what bike do you have and is there a temp gauge? is the temp gauge reliable? meaning, is there a fan? and if there is a fan, does it come on?
One other method here:
http://www.advrider.com/forums/showthread.php?t=41674
Others from a quick search:
http://www.advrider.com/forums/showthread.php?t=41003
http://www.advrider.com/forums/showthread.php?t=47506
http://www.advrider.com/forums/showthread.php?t=57870
http://www.advrider.com/forums/showthread.php?t=137779
http://www.advrider.com/forums/showthread.php?t=131720
http://www.advrider.com/forums/showthread.php?t=96094
http://www.advrider.com/forums/showthread.php?t=88551
http://www.advrider.com/forums/showthread.php?t=71131
some possibilities for additional info:
http://www.advrider.com/forums/showt...ght=thermostat
http://www.advrider.com/forums/showt...at#post2172394
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle screwed with this post 09-13-2006 at 02:39 PM
meat popsicle is offline   Reply With Quote
Old 09-13-2006, 03:31 PM   #6
MF1A OP
Ride with the Wind
MF1A's Avatar
Oddometer: 267
finally i decided to go with it, i'm very far from any place where can i buy some spare parts for the cooling system, (this small town only has a ciber cafe as the super main atraction), so i decided to invest more time to find the real problem, i still think that the thermostat runs out because is the only part of the cooling system i hadn't replace ( i found that the upper hose from the thermostat is hot to the touch, but the lower hose, a smaller one is not tht hot only a little warm) , the water pump fine, no coolant leaks, so what the heck i'm going to disassemble the thermostat and see what happens
ps: thanks for the help guys i really apreciate
Old 09-13-2006, 07:06 PM   #7
DC950
Microadventurer
DC950's Avatar
Oddometer: 2,873
once you pull the thermostat out, you can check to see if it works by putting it in a pot with water and heating it up. You'll see it open if it is working. It would be great to have a thermometer - maybe a restaurant will let you borrow one and their stove - but if not, at least you can tell if it opens by the time it boils.
If you really doubt it works, leave it out, but remember it will take a lot longer for the bike to warm up.
Good Luck!
God. Family. Motorcycles. Guns. Music. Books. Dogs. Beer. Baseball. Work. That about covers it.
DC950 is offline   Reply With Quote
Times are GMT -7.   It's 01:55 PM.
