Old 09-13-2006, 10:08 PM   #1
firerigger OP
Trauma waiting to happen
firerigger's Avatar
Oddometer: 810
Broken centerstand blues..
So I was trying to put the trusty Sixdays up on the centerstand tonight, when I heard a "pah-ting!" On inspection, I discovered that the left threaded stud on the centerstand had broken off. This is not good. Anybody have a spare centerstand they'd be willing to sell? Or suggestions on a repair plan? Thanks.
"The eyes are the groin of the head.."
"I never fail...sometimes I succeed in finding out what doesn't work."
Current rides:
'04 KTM 450 EXC
'07 Triumph Tiger 1050
'07 Triumph Daytona 675
Gone but not forgotten:
'00 KTM LC4-E Sixdays
'06 KLR 650
'06 DL-1000
Save yourself (and me!) money at SmugMug: Coupon code YE2eMDKcBDhGY
firerigger is offline   Reply With Quote
Old 09-13-2006, 10:09 PM   #2
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Drill it out, put in a shoulder bolt.
Ta Da.
C
So... how's tricks?
creeper screwed with this post 09-13-2006 at 10:15 PM Reason: Added a pic...
creeper is offline   Reply With Quote
Old 09-13-2006, 10:24 PM   #3
firerigger OP
firerigger's Avatar
Oddometer: 810
Ta Da.
C
Yeah, I've been looking at it and that would probably work. I just have to find the right bolt.... That could take some doing.
Current rides:
'04 KTM 450 EXC
'06 KLR 650
'06 DL-1000
Old 09-13-2006, 10:35 PM   #4
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,205
Go to Canada.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 09-14-2006, 06:35 AM   #5
boxermoose
Now fully goosed
boxermoose's Avatar
Oddometer: 2,847
Lowes stocks some shoulder bolts.
Mine broke this summer and with some carefull hand drilling thru the old studs (leaving the old stud bosses intact to act like a bushing) I replaced with good old grade 8 bolts and nylock nuts.
OK so far - I'd have used the shoulder bolts if i knew they were easy to get outside of an industrial supply house here in the US to save time and trouble
Sometimes you get the ABAT....and sometimes the ABAT gets you
boxermoose is offline   Reply With Quote
Old 09-14-2006, 07:56 AM   #6
bigtaters
Strommer
Oddometer: 48
I drilled mine out and replaced it with a grade 8 bolt. It's held for a few months now with no problems, even loaded down during a recent trip up the Blue Ridge Parkway. I'm going to have to look around for a shoulder bolt - that looks like a better way to go.
bigtaters is offline   Reply With Quote
Old 09-14-2006, 08:03 AM   #7
fire_strom
fire_strom's Avatar
Oddometer: 1,258
kroegers has a surprisingly good bolt selection.
scott
Officially motor free
9 cycles with pedals
fire_strom is offline   Reply With Quote
Old 09-17-2009, 04:15 PM   #8
Riversage
Riversage's Avatar
Oddometer: 12
shoulder bolt
Unfortunately I find myself with this problem now too. Anyone know what size of shoulder bolt is needed?
Man, will you just please kindly dig it?
Riversage is offline   Reply With Quote
Old 09-17-2009, 06:45 PM   #9
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,617
make sure the frame hole is not ovaled out and measure it
wrk2surf is offline   Reply With Quote
Old 09-18-2009, 12:22 AM   #10
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,730
mine broke on a ride in 2005... a ride with creeper mr. shoulder bolt himself actually... i popped in a little m8 bolt i had in my tool kit and it worked fine. so fine i forgot about it. it still resides in the stand years (and two owners) later.
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 09-18-2009, 10:07 AM   #11
XR650L_Dave
Oddometer: 3,724
Shoulder-bolt central:
http://www.mcmaster.com/#shoulder-bolts/=3opix1
I hear there may be some issues getting stuff from them into canada, though.
Dave
XR650L_Dave is offline   Reply With Quote
Old 09-18-2009, 06:19 PM   #12
meat popsicle
Ignostic
Oddometer: 14,205
Dave
I can't even remember why I posted that bit above.
Old 08-10-2010, 04:04 PM   #13
Johnny Bouncewell
Surly
Johnny Bouncewell's Avatar
Oddometer: 161
Yo! I've got this problem and need to revive this thread dudes...
So I just bought a 97 620 RXC for peanuts and have been going through it finding all the things wrong with it. First thing I noticed was the centerstand not passing the swingarm. So...a bit of digging and I found the right pivot on the stand nearly half way worn through and the frame mount totally ovalized. To get by, I fabbed a little collar that wrapped around the worn pivot but I will need to do something more substantial before too long. Though I am a bit embarrassed to say so, I ground down a little bit of the foot to help with clearance...I really wanted to ride the beast!
Is it safe to drill out the ovalized frame mount and replace the pivot to a larger shouldered bolt? I'll try and get some pictures up tomorrow. Thanks to those who are wiser than I.
weasels are ripping my flesh
Johnny Bouncewell is offline   Reply With Quote
Old 08-11-2010, 12:11 PM   #14
XR650L_Dave
Oddometer: 3,724
Depends on how much metal is left around it.
You could have the hole welded and re-drill it.
Dave
Old 08-15-2010, 04:47 PM   #15
Cigar Mike
Too Old and Too Slow
Cigar Mike's Avatar
Oddometer: 1,461
Without being familiar with the model and how much of a tab is present? It may be possible to enlarge the hole enough to place the appropriate size nut in place and weld it to the tab. Now if you do not have access to a welder, it may not be such a good idea.
Cigar Mike
When in doubt, give it Gas!
Cigar Mike is offline   Reply With Quote
Times are GMT -7.   It's 02:17 PM.
