09-18-2006, 11:44 AM
#16 |
Dirty_Sanchez
Oddometer: 2,094
Loctite Guru Checking In...
NYC GS- I'm Adventure Rider's resident Loctite Factory Rep working out of south Louisiana.
243 is an oil tolerant medium strength blue threadlocker. When I say "Oil Tolerant" I'm not talking about the material's ability to stand up to oily environments when inservice. Any cured threadlocker does this, so there's still nothing special about it. When Loctite says 243 is "Oil Tolerant" we are referring to the materials ability to work and cure properly on "As Received" threaded fasteners that are already lightly oiled to prevent rust. 243 isn't as picky when used on slightly oily threaded fasteners as 242, 248, or 2440. I don't know about everyone else, but I won't paint car with oily handprints on it because surface prep is king. Most any of us would remove all surface contaminates before we paint a car or reinstall a bolt if we're working in our shop. In short, always clean and degrease fasteners before reassy.-especially if we're using a threadlocker. Use 242, 243, 248 (the Stick), or 2440 (Primerless). They'll all do the job-each with a different twist. Dirty
No, really, the mustache means I love you. '09 KTM 250SXF for Sale, take a look: http://advrider.com/forums/showthrea...7#post21410167 |
09-18-2006, 11:52 AM
#17 | |
Lurker
Oddometer: 241
Sweet
Sweet. That is excellent information and I really appreciate it. I can feel a little better about the 242 now! THANKS! -- Jason |
09-18-2006, 12:47 PM
#18 | |
Ignostic
Oddometer: 13,839
Here is another.
Kronreif Trunkenpolz Mattighofen LC4 640 Its not so much staying alive; its staying human that counts. |
09-18-2006, 12:56 PM
#19 | |
Lost in the woods
Oddometer: 354
Techie.
Reality does not always develop in a way we expect it to. |
09-18-2006, 02:43 PM
#20 | |
love what you do
Oddometer: 19,441
Just tryin' to give somethin' back, brutha. From the discussion last week, I had errantly assumed that the two styles of bolt/washer were interchangable. Looking at the schematic again, though, it's clear that it's dependant on whether ones countershaft is threaded internally (Version 1) or externally (Version 2, with the tabbed washer). I'll be swapping for a 15T as soon as I put a parts order in, so I suppose I ought to check which style I have and add the requisite bits to the tally, eh? ![]() Perhaps you could add a note about this to the chain/sprockets index article?
Nate in N.E. Yes, I have a Dakar problem -- that there are 50 weeks of the year without Dakar! ![]() They don't expect you to finish. That's why it's the Dakar. -- PPiA Get your sweet Pyndon DakARTwork here Pyndon '13
07-12-2008, 05:20 PM
#21 | |
Oddometer: 6
Loctite
07-12-2008, 07:33 PM
#22 |
Fagarwe tribal member AL
Oddometer: 303
Stock gearing
nyc gs
You may find in time that you switch back to the stock 16 gearing. I changed mine to a 15 tooth for about a year and then went back to the 16 tooth. The 16 works much better if there is any open road riding and I have done some tight off road with this 640 torque monster and it's not much of a problem. JMHO
07-12-2008, 11:56 PM
#23 | |
Oddometer: 902
I am kind of thinking of adding 2 teeth on the back and keeping the 16 tooth up front. Kind of splitting the difference and see how that feels. Any thing other than tight trails, which I don't do much of with this bike, I kind of like the stock gearing also. |
05-11-2009, 10:05 PM
#24 |
Oddometer: 1,235
OK, it's been a year since this has been on the first page, it's spring, and I'm doin' some annual updates the ol' 2000 LC4E. One thing I'm trying to do is get the gearing right. My conclusion is that it can't be done with the ratio width on these five speeds. I ran the stock 16:42 for one year and liked it generally for distance travel so long as I kept speed at 75 mph or below for long periods. Much above that and my ass got a good vibrating and starts to feel funny (in a bad way) after a while. However, when I get on single track and the tight stuff or climbing hills I get stuck between a too low first and a too high second.
I changed to 16:45 and all is good off road but it dropped my top comfy highway speeds by about 5 mph which I feel is too limiting. So now I'm thinking the best compromise is back to 16:42 for most road work, 15:42 for off road, and throw in a 17:42 and the bigger chain guard for long distance work. All this switching around makes a new bolt and washer each time unworkable. I read Creeper's and other's advice reccomending a new bolt and washer each time, and the reasoning make sense, but the service manual does not mention the need. I'm gonna go with fresh 243 each time, proper torque, and changing the bolt and spring washer once a season. I'll let you know if my theory ends up being flawed. |
05-11-2009, 11:09 PM
#25 |
BITD/Rallye
Oddometer: 5,306
im sure if you look you could find the spring washers cheap... I reused one for about 2yrs though
Thanks for the 2013 support: DUNLOP, BELL HELMETS, Kriega USA, Carbon-pro.com, Ride 100% Goggles, Renazco Racing, Sidi/Motonation, Acerbis USA,KLeN, FMF, Mx1west,,Masters paint and body, Magura , motolab ,and Freedom Cycle |
05-12-2009, 06:43 AM
#26 | |
Oddometer: 1,235
05-12-2009, 07:04 AM
#27 |
RubberNecker
Oddometer: 1,695
This is the other CS arrangement. A nut with a tab washer, rather than the bolt with the spring washer, and from the parts list from Liferider's posted about his leaky O-ring, you can see the splined washer. I'll be taking mine off as well, as I have the same leak as Liferider. . . . though you'd never know it. I washed it pretty good yesterday.
edit: this thread is 2 years old??? Oh well, at least there is a good picture of the 'other' countershaft arrangement. The information out there really only refers to the bolt. I'm pretty sure this style will not back off or loosen up. ![]()
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI B-Rod screwed with this post 05-12-2009 at 07:09 AM |
05-12-2009, 07:35 AM
#28 |
ADDvrider
Location: Wisconsin..Hot,Cold and everything in Between
Oddometer: 5,168
since I'm in the same situation..however I'm going from 15/45 to 16/42 cause it's waaaay too slow for any roadwork...and first gear is unusable at this gear ratio..I've got to ask..is there any benefit to using the rubber washer CS sprocket versus the non rubber one?
CADVR 6 CENTRAL RALLY 6 "THE SOUND OF AWESOMENESS" Cannonshot's Central Rally GPS Routes Tracks and Info HERE!! ![]() Official Central Rally Website: Sign up and Ride Hard too! |
05-12-2009, 01:15 PM
#29 |
Ignostic
Oddometer: 13,839
bonebag, I hear the rubberized CS sprocket was for drivetrain noise reduction, but who knows?
![]() b-rod, taking that arrangement on and off would also lead to fatigue eventually eh? Bending the tabs back and forth. Plus the spring washer is supposed to transmit some amount of force onto the sprocket to help keep the CS sealed, while also giving the CS the ability to move laterally (I am guessing). I don't know why KTM switched, and if there were any other changes to go along with the change. sparrowhawk, I would think of the CS bolt and spring washer fatigue would relate more to the number of times it is stretched and released, not the time on the bike. Is there a way to easily measure fastener stretch, or is that only something the engineers do? Maybe an easy way to check the spring washer's resiliency?
05-12-2009, 01:33 PM
#30 |
Oddometer: 1,235
Ruduced function of the bolt and spring washer are likely related to the number of times the parts are installed and removed. A CS sproket would only be on the bike until the chain is worn so there shouldn't be any problems from simply too much use. I've no idea if the bolt is a fancy stretch type or not. Many modern cylinder head bolts are like that. Torque the head bolts according to instructions and dispose of and replace if ever removed. I wouldn't expect there is a cost effective way to test either the bolt or spring. KTM used to sell the washer and bolt seperate. Now they come as one part (#59033034044).
I think around 2003 the 640s transitioned to the nut and washer shown in B-Rod's post. None of the other shaft parts were changed so I think the function of the spring washer was simply to keep the bolt in place. The new washer is soft (not spring) metal and available seperately for about $5 US. I would suggest a new one after a couple of uses. It works like a cotter key and will fatigue if bent too many times. Sparrowhawk screwed with this post 05-12-2009 at 01:42 PM |
