12-17-2007, 08:12 PM
#76 | |
IOR Veteran
Oddometer: 1,892
...its the best paint scheme that has ever been or ever will be on an Adv...-AussieRob |
12-17-2007, 08:40 PM
#77 |
Oddometer: 237
I paid $100 shipped. It included throttle assembly, cables, adapters for manifold and air box, and clutch perch with hot start lever. I think I got a decent deal. I found it on SM forum.
04-02-2008, 08:17 AM
#78 |
Oddometer: 21
My katie is a 2004 640 LC4 Enduro with the "high flow head", it had the standard BST and a SR-Racing silencer. Apart from subideal wheelie and jump performance it ran quite well. I got a used FRC 41 on ebay in top condition last fall, which someone had run on his supermoto competition bike and had it installed and tuned by Griesser (KTM dealer in Rosenheim, Germany who does a lot of sport bike preparation). They also put the bike on a dynamometer. It has now 59,2 hp at 6585 revs and 68,8 Nm at 5510 revs. Much more important for me than the paper performance is the way the bike now reacts to every "twist of the wrist" now, the bike is lots more fun to ride now than with the BST. I can really recommend this kind of setup and the new LC4 has lost its chance to be bought by me. But- if you spend the money on a flat slide carb, you should also spend the money for setting it up using a dynamometer.
04-02-2008, 08:30 AM
#79 |
Oddometer: 1,573
I switched to a FCR41 from BST on my duke II.
lots more torque and response and BETTER MPG. so far I've gone 110 miles on the main tank. on the rejetted BST I would need reserve before 100. the FCR is easier to start. I never use the choke. just press the e-start and it starts right away. if it's really cold I'll twist the throttle. |
04-02-2008, 09:00 AM
#80 | ||
Ignostic
Oddometer: 13,872
Everyone knows that a pumper carb will give you better instantaneous throttle response than a constant velocity carb, but those who say the difference is "night and day" probably have one of the following issues at play: 1) poorly tuned and/or maintained BST/LC4 2) lack of throttle/clutch control I am not trying to take a dig at you, I for sure have issue #2 and might have some of issue #1 , just trying to be clear for the folks trying to use this thread to decide what carb is best for them. I base my statements on the posts of people such as loisu (who started this thread - did you read Post #1?) in his How to wheelie the LC4 thread and creeper's posts on the subject. HERE is one very nice and brief post by a guy who has both a BST-equipped LC4 and a FCR-equipped LC4 (with full Akropovics exhaust). Good points in there for people to chew on as they decide what they want. For me the BST's muted throttle response helps minimize my throttle/clutch control issues so that I keep on truckin', whereas with a FCR-equipped RFS bike I got into all sorts of trouble. Sure you can learn to deal with the better throttle response, and probably even kick ass with it, but I have never felt held back by the BST. If you do, and you do not have the issues noted above then perhaps you should upgrade (note that creeper did for a very specific set of reasons). Just make sure you are spending the dough for the right reasons. Quote:
Kronreif Trunkenpolz Mattighofen LC4 640 Its not so much staying alive; its staying human that counts. |
04-02-2008, 10:45 AM
#81 |
Oddometer: 21
meat popsicle, you are completely right, of course. It always depends of what you want to get out of your bike. For good mileage I ride my Diesel VW Golf TDI, which runs 100 km on 5 l, something which the LC4 can never achieve by far. I wanted a "nervous" bike which reacts to every move ov my right hand and i like it that way just fine. As unsuspected goodie the mileage of my flat slide carburetted LC4 seems not to have changed much from the BST, but this is not yet my definitive opinion, as I didn`t drive so much with it since the carburrettor change. I don´t mind cv-carbs in principle, have driven them a lot in british cars, but for a sports/fun/dirt bike I prefer the pumper type. But each to his/her/its own. I wouldn`t have changed, if i wouldn`t have gotten the flat slide carb at a bargain price.
04-02-2008, 12:20 PM
#82 |
Ignostic
Oddometer: 13,872
Prost madmac
04-02-2008, 01:09 PM
#83 | |
Oddometer: 44
04-03-2008, 01:32 PM
#84 |
Oddometer: 21
@JSL:
It`s worth a try (Diesel). When i flew with the good old GAF(German Air Force) = Luftwaffe with C 160 Transalls into Africa in the 80`s, the locals used to siphon of the 20 liters of kerosene, which remained in the filler tube to the high wing and filled it into their mopeds. Somehow they ran on that stuff. Mileagewise my katie used with the BST between 4,5 l and 6 l/100 km. I don`t know how much that is in american units (was it furlong per fortnight or something like that?). |
03-31-2009, 01:42 PM
#85 |
wheelie addict
Oddometer: 554
Fcr 40
Hey there,
It's been a while. There's an opportunity to buy a KEIHIN FCR 40 carb. The guy who's selling it says he got it for his HUSABERG as a bonus gadget (probably a used carb that someone wanted to get rid of). I'm wondering if anybody here thinks it's a good move to get this carb. It isn't expensive but I have no idea how it's jetted and whether I can assume it's similar to an FCR39 or 41 ? Thanks in advance for help. Losiu
KTM 640 - The wheelie monster Husqvarna TE 250 - The little beast Husqvarna 333R - The ...umm..... how do I put it.... |
03-31-2009, 03:43 PM
#86 |
Oddometer: 1,138
Losiu - I suspect the Keihin FCR40 is really an FCR39. Every time I've measured the inlet it's been 1mm larger in diameter than advertised. That is, an FCR39 measures 40mm and an FCR35 measures 36mm.
Good luck. |
03-31-2009, 03:48 PM
#87 |
Ignostic
Oddometer: 13,872
loisu, the man who says the BST is good enough, at least for third-gear wheelies, is now eyeballing an FCR...
What's up man? The only thing I can think of is the tradeoff with size (39 gives more low-end grunt/41 gives more high end zing - if the rest of the engine/exhaust is setup to maximize the effect) so the 40 should be somewhere between the two eh? I am sure you can find hits on "FCR40" with Google; here's a quickie: http://www.thumpertalk.com/forum/arc.../t-158741.html |
03-31-2009, 11:11 PM
#88 |
wheelie addict
Oddometer: 554
Thanks DJchan and Meat,
My BST-powered beast with the open LeoVince is always ready to do 3rd gear wheelies but the price on the FCR is pretty good. From discussing carbs on this forum and from other places on the internet, I know that an FCR 39 would be better for me than a 41. I don't like having to rev the bike high to get tons of power. I'm not into speed. I'll look into this carb and we'll see. Maybe I'll be looking at fitting it on my wheelie beast soon :) Losiu
04-01-2009, 05:49 AM
#89 |
NWGS's pwner!1!!1!
Oddometer: 19,006
If you are able to drop an e-mail to the boys at Sudco, with specifics about the model 'Berg the FCR is on right now, they should be able to tell you if it will work with your LC4.
04-01-2009, 08:22 AM
#90 | |
Molon Labe
Oddometer: 6,287
Chris '03 KTM Adventure 640 '43 BSA M20WD |
