Old 01-11-2009, 03:42 PM   #226
Gimmeslack
furthur
Gimmeslack's Avatar
Oddometer: 2,499
Welcome !
http://www.advrider.com/forums/showthread.php?t=919
Looking forward to seeing it
"If you hold a cat by the tail, you learn things you cannot learn any other way."
Twain
Gimmeslack is offline   Reply With Quote
Old 01-12-2009, 09:55 AM   #227
Dirtyboydeadly
AKA. Shineyboydudley
Dirtyboydeadly's Avatar
Oddometer: 528
ok here it goes
First pic is the project bike as i bought it
its now a bare frame working from the ground up.
Braced Swiging arm as i know some people want good pics of it I thought i'd help out
Dirtyboydeadly is offline   Reply With Quote
Old 01-12-2009, 11:55 AM   #228
Caddy82rats
Caddy82rats's Avatar
Oddometer: 1,190
It seems not to be electrical welding ?
If I'm true, why ?
Caddy82rats is offline   Reply With Quote
Old 01-12-2009, 01:24 PM   #229
Dirtyboydeadly
Oddometer: 528
I asked the same. I could of mig welded it but if u start making holes in the swinger all the oil will get out.
Its been brazed
Old 01-12-2009, 01:43 PM   #230
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,584
Originally Posted by Dirtyboydeadly
Its been brazed
That it has !
You going to paint or powder coat ?
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 01-12-2009, 01:52 PM   #231
Dirtyboydeadly
Oddometer: 528
This one has been sold to my m8 over the rd.
When i get my one back it will be blasted allong with the frame wheels and sub frame.
Wheels will be sprayed silver, frame swinging arm and sub frame will be sprayed metallic black.
Old 01-14-2009, 11:07 AM   #232
CurlyMike
Formerly SaddleSoar
CurlyMike's Avatar
Oddometer: 1,008
Side stand spring
Can I get the side spring for my side stand for my /6 at a hardware store. Does anyone have an extra one they can measure for length? I heard the ones at/from BMW are much stronger than generic ones. Can I use a brake spring from the auto parts place?
Thanks.
Giving the horses and the wife a break from riding...
CurlyMike is offline   Reply With Quote
Old 01-14-2009, 03:30 PM   #233
dam0nd0g
dam0nd0g's Avatar
Oddometer: 14
Why bother reinforcing the swing arm? Is it weak?
dam0nd0g is offline   Reply With Quote
Old 01-15-2009, 09:12 AM   #234
Dirtyboydeadly
Oddometer: 528
Ive only done it for looks but they do flex
Ive also braced the frame for the same reason.
I didnt ride it as it wasnt safe when i bought it so wont know and differance with the bracing whrn its all together
Old 01-19-2009, 04:42 PM   #235
outfit
outfit's Avatar
Oddometer: 661
This car air filter fit's straight into plastic housing (post 1981 airhead's), once you have cut the old one out. It is a FRAM CA5205.
I have been using this for the last 15 yrs and many 1000's of mile's with no problem's what-so-ever. They cost a 1/4.
Safe riding Karl.
outfit is offline   Reply With Quote
Old 01-19-2009, 05:25 PM   #236
RandyB
Oddometer: 5,072
Safe riding Karl.
That's certainly easier than sectioning a Toyota truck filter. Good on ya.
I've been shot, cut, burned, blown up, fired, busted, promoted, reprimanded and decorated. What are you going to do? Ban me?
Blessed be the Lord my God, who prepares my hands for war and my fingers for battle. Psalm 144:1
RandyB is offline   Reply With Quote
Old 01-27-2009, 07:25 AM   #237
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,581
Is it just me, or is the shackle for the rear axle horribly bent? It doesn't look straight at all in this photo.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 01-27-2009, 09:32 AM   #238
Caddy82rats
Oddometer: 1,190
I'll hope it's an ilusion, as the shape is parallel on the whell side and not outer side (genuine)
Old 01-29-2009, 11:18 PM   #239
yamadude
lost platoon
Oddometer: 9
so I recently started on an r80gs project and I seem to recall something about the charging light being an issue... like if the bulb goes out it doesn't charge. Is this true and if so how can it be fixed? I was thinking of putting a volt meter on can I just eliminate the light?
yamadude is offline   Reply With Quote
Old 01-29-2009, 11:35 PM   #240
Zebedee
Zebedee's Avatar
Oddometer: 836
Seek and ye shall find ... clicky
All you ever wanted to know, but were afraid to ask - specifically the first link in the first reply explains all regarding the charging (gen) light “fix”.
HTH
The perverse must persevere
Zebedee screwed with this post 01-29-2009 at 11:40 PM
Zebedee is offline   Reply With Quote
Times are GMT -7.   It's 01:26 AM.
