Old 01-30-2009, 03:58 AM   #241
Sucks2drive
Sucks2drive's Avatar
Oddometer: 3,479
Originally Posted by homerj
Lace replacement cables along side the current cables and zip tie them together. Cover the ends with duct tape. If a cable snaps mid ride you just have to swap the ends and you're back on the road.
Im gonna agree....and add to your tip.
Wrap the ends of the cables in Saran wrap FIRST! this stops the adhesive from the duct tape gumming up the cable when it gets old and heated by say the weather or the engine. I speak from personal frustrating experience here!
as another tip also...... when removing old cable to fit a new one. tie some really strong cord ( paracord is what i used) to the old cable and then gently feed old cable out...... to replace new cable attach the cord to nipple .. and pull through. this way the routing will always be correct! (damhik)
Sucks2drive is offline   Reply With Quote
Old 02-07-2009, 08:54 PM   #242
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,605
The bottom left bolt that holds the gearbox on my G/S has an allens head. My allens wrench bottoms out on the shift lever and it's hard to get out. Replaced it with 13mm hex head and keep a 13mm ratcheting box end on the bike. Replaced the airbox bolts with 13mm also, that ratcheting box end makes them a heckuva lot easier to get out too. In fact, replace every 8mm bolt you can with a 13mm and it'll make life easier.
5/8" Nylon plugs at the local hardware store are a perfect fit to plug the emissions plumbing holes in the airbox.
If you install the Enduralast alternator you won't have a diode board in your alternator cover anymore. Put a tupperware box in there and stash parts in it.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 02-12-2009, 12:40 PM   #243
pjcr12
Stercus accidit
pjcr12's Avatar
Oddometer: 801
Charging light
Originally Posted by yamadude
so I recently started on an r80gs project and I seem to recall something about the charging light being an issue... like if the bulb goes out it doesn't charge. Is this true and if so how can it be fixed? I was thinking of putting a volt meter on can I just eliminate the light?
Yes, that's right. The bulb is crucial to the standard charging circuit; I've heard of some people fitting a suitable resistor in its place, but then you'd have no warning light on start up....I've never had one fail though
pjcr12 is offline   Reply With Quote
Old 02-19-2009, 12:36 AM   #244
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
Motorrad Elektrik has exactly the fix for that. Something like $3.50 only.
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 02-19-2009, 04:32 PM   #245
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,040
Use a 1watt 330 ohm resister in parallel with the lamp. You will still have all the functions of the lamp and still generate if the lamp fails.
RecycledRS is offline   Reply With Quote
Old 02-20-2009, 09:59 AM   #246
TopDogDave
Manly, NSW, Australia
TopDogDave's Avatar
Oddometer: 164
making the brake pedal bigger for use with enduro boots
When using enduro boots on long offroad trips I found it virtually impossible to use the rear brake pedal since the boot cannot flex forward against the carb inlet manifolds - so cannot depress the pedal enough.
To get around this I fabricated an outwards extension to the pedal so I can actuate it duck-foot fashion outside of the carb area.
Works well and can be bolted off if required later.
'90 R100GS PD - large
'94 XR600R - medium
'73 BSA B50MX - small
TopDogDave is offline   Reply With Quote
Old 02-20-2009, 08:47 PM   #247
channelcat
channelcat's Avatar
Oddometer: 176
did he say EZ Pull Throttle springs?
well, I'm back flogging my springs for Airheads with Bing CV carbs.
Makes long distance easy, and finessing the front brake through turns a gas.
Lots of Airheads use 'em, cause they work real good.
www.bmwthrottlesprings.com
channelcat is offline   Reply With Quote
Old 02-21-2009, 02:09 AM   #248
TopDogDave
TopDogDave's Avatar
Oddometer: 164
+1
I have these springs and they're brilliant on long rides over dirt where you don't want a fixed 'cruise control' thingy....anytime else for that matter....TDD
'94 XR600R - medium
Old 03-14-2009, 07:33 PM   #249
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,136
Appeal the the Old Skool Brain Trust
Enduralast Alternator Question:
Where'd you guys hang the regulator/rectifier unit on your R100GS?
Old 03-14-2009, 07:58 PM   #250
RandyB
Oddometer: 5,072
For cryin' out loud, buy his springs. They really are great.
I've been shot, cut, burned, blown up, fired, busted, promoted, reprimanded and decorated. What are you going to do? Ban me?
Blessed be the Lord my God, who prepares my hands for war and my fingers for battle. Psalm 144:1
RandyB is offline   Reply With Quote
Old 03-14-2009, 08:39 PM   #251
Readymeal
Oddometer: 113
i bolted it on an aluminum plate and straped the plate against the battery (i have an Odyssey PC-680 though which is slightly higher but half the size in width)
hope this help
94 BMW R100GSPD
79 Suzuki GS750 black 4 in 2
81 Yamaha XT 540
Readymeal is offline   Reply With Quote
Old 03-15-2009, 06:56 PM   #252
Beemerboff
Oddometer: 2,329
Over here in Oz where it can get real hot they can be a problem unless they can be mounted out in the wind somewhere - they produce a bit of heat themselves and dont like getting too hot.
They are troublesome on VFRs and hard to relocate- I have mine fixed to a heatsink with conductive paste , and have a big PC cooling fan blowing over it, which has solved the problem.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 03-16-2009, 10:07 AM   #253
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,864
If you guys blow a charging light on a GS, you can sub in one of the other dashboard lights temporarily (I like the high beam option the best,) to keep your system charging. Dont think too much about the wattage
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 03-22-2009, 02:22 AM   #254
davorallyfan
Commonist
davorallyfan's Avatar
Oddometer: 16,285
I dont want to start a fire in this thread.
I dont want to start a fire in this thread but I want more giddy-up for my R80 G/S PD.
I know extracting significant extra HP out of these things aint easy.
I'm thinking if there was one engine mod I want to do it would be this.
I know its a bit exy.
What have been peoples experience with the Siebenrock power up kits for the R80 G/S?
I'm thinking of just doing this one engine mod.
Am I on the right track?
Do they deliver the extra performace as claimed?
7th Day Adventourist.
Re-incarnated
Terrafied
I have learnt a lot from my mistakes. I am heading out to make a few more.
davorallyfan is offline   Reply With Quote
Old 03-22-2009, 04:39 AM   #255
Beemerboff
Oddometer: 2,329
Everything i have read suggests that they perform as advertised.
I bored my R75/7 out to 900 , and if it makes anything like the difference that that made it would be the best bang for the buck you will get.
The claim that it is plug and play stacks up too - I didnt have to change anything else when I bored the 750 - the carburation etc was fine.
Times are GMT -7.   It's 10:37 PM.
