Old 12-08-2009, 03:52 AM   #376
Jasper ST4
Guest
Oddometer: n/a
Originally Posted by blueeyedcrow
Gentlemen and "ladies", I'm a newbie here and am having trouble making sense of the "system".
I wanted my age and birthdate to be hidden and can't seem to edit that info, and would also like to just get comfortable in here because I see that there is a wealth of information for me re: my recently purchased "78 BMW R100/7.
If you can, please help me to get in the groove here...
Very disturbing for me not to be able to interact with my fellow inmates and also those of you who might also qualify as outpatients.
I don't see your age or birth date and don't understand what the problem is with interacting.
Old 01-17-2010, 10:30 PM   #377
WABuckeye
Sound Jumper
WABuckeye's Avatar
Oddometer: 225
What is the best way to remove the BMW roundels from the tank while preserving them at the same time?
Heat gun or hairdryer maybe? Pics would be helpful too. Thanks.
WABuckeye is offline   Reply With Quote
Old 01-18-2010, 12:41 AM   #378
Beemerboff
Oddometer: 2,350
I read somewhere that you saw them off with dental floss or whatever you call the thread you clean between your teeth with but I havent tried it.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is online now   Reply With Quote
Old 01-23-2010, 06:56 AM   #379
Mario Shi
Mario Shi's Avatar
Oddometer: 516
Originally Posted by MUTZfern
these are 10mm bolts.i use a "non-offset"10/11mm,closed end wrench.you can now tork the bolts to their proper value by inserting the 3/8" tork wrench into the 11mm side of the combination 10/11mm wrench.the square drive of the tork wrench fits perfectly into the 11mm wrench.oh,something else about the 10/11mm wrench.get the 12 point kind.since it's a non-offset wrench,you will have more"bite" when bearing down.
Great idea. However, doesn't one need a mathematical formula under these circumstances to obtain the proper torque? Does anyone know what that is?
Mario Shi
1985 CH150D
1994 R100 GS PD
1967 R60/2
1989 XL600V TRANSALP
1999 XRV750X Africa Twin
1998 XR400r - plated & electric start
1999 XR250r - plated
1998 M900
Ahhh, if it was that, then it would be it - Butt Head
Mario Shi is offline   Reply With Quote
Old 01-29-2010, 05:51 AM   #380
Eckhard
Oddometer: 1
Try here:
http://www.specialpatrolgroup.co.uk/...ue/torque.html
Eckhard is offline   Reply With Quote
Old 01-29-2010, 09:46 PM   #381
Mario Shi
Mario Shi's Avatar
Oddometer: 516
Originally Posted by Eckhard
Thanks a lot. I knew I should have paid attention while in school.
Mario Shi
1985 CH150D
1994 R100 GS PD
1967 R60/2
1998 M900
Old 01-30-2010, 10:45 AM   #382
greenslime
greenslime
greenslime's Avatar
Oddometer: 161
no airhead club here in wis.
Originally Posted by jtwind
Elmoreman, this was a neat idea, thanks for coming up with it.
Probably my best tip would be to join the Airheads. These guys are the mainstays to keeping these things on the road. The dues are only $20 a year, many join just for the Airmail monthly newsletter, Oaks tech info is worth that. The email tech list and the archives are probably the best source of airhead info out there. There is also the tech days that can give you hands on help with your airheads upkeep and troubleshooting. Good organization and good folks. JT
Not with Jeff trap running the show!!
greenslime is offline   Reply With Quote
Old 03-10-2010, 02:03 PM   #383
limeymike
Who Me?
Oddometer: 655
Buying R80/R100
What should I be looking for in the way of problems buying an R80/R100 airhead BMW? Been around motorcycles for 40+ years but not airheads. The ones I have found have around 40-75K miles, 1977-1986 ish fo years. Any tips are appreciated.
limeymike is offline   Reply With Quote
Old 03-13-2010, 09:13 AM   #384
onebadhp2
Oddometer: 134
Sounds like we have alot in common...Doing my first airhead...78 R100/7 that was sitting for 21 years in a backyard...Exhaust/carbs/topend completely rusted off and cylinders were filled with water and rusted to death...Found a bike with 17K on ebay and bought the used parts needed...Everything you need is here at Advrider...I have found great places to do business with, carb kits, topend gasket kits, rings, fuel valve rebuilding kits, ect...Mine have the Vetter fairing (AM/FM/CB) with the Sam bag set up...I ditched the fairing but will keep the bags...I'm doing a frame up rattle can rebuild and plan on using the bike as second bike transpo...The most impressive thing about BMWs is the quality of the metal/hardware used...Cleaning/wiring brushing that hardware makes it look fantastic...Bike will be done in a couple weeks...
Stage two will be electronic ignition and "old schooling" which will include blacking out the wheels, different subframe with single seat and tank painted black with white pin stripping...
Goodluck with yours and you will find some very knowledgable/helpful people willing to lend you a hand...
onebadhp2 is offline   Reply With Quote
Old 03-14-2010, 06:46 AM   #385
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,674
Originally Posted by richarddacat
emblems???
does anyone have the part numbers and size of the various BMW emblems out there?
I was looking for a couple that would fit on top of the Bing carb tops.
A Euro fits perfectly...get the German one with the eagle.
...but a Deutschmark might be even better?
boxerboy81 screwed with this post 03-30-2010 at 07:43 PM
boxerboy81 is offline   Reply With Quote
Old 04-06-2010, 08:57 AM   #386
rkatapt
Indo-Kraut
Oddometer: 261
snip
I am definitely looking into that. Is that a 2 Euro coin?
Another is the use of Rancho shock boots for gaiters. Fraction of the cost and I think they actually look better.
Here they are on my /6.
rkatapt screwed with this post 04-06-2010 at 11:24 AM
rkatapt is offline   Reply With Quote
Old 04-06-2010, 08:20 PM   #387
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,674
It's a 1euro. The 2Euro is a little bigger.
Old 04-07-2010, 08:35 AM   #388
rkatapt
Indo-Kraut
Oddometer: 261
snip
Nice it'll be the greatest $2.88 I ever spent. Now if I can just find a way to get a hold of some.
Old 04-07-2010, 10:23 AM   #389
clang
Not lost, Exploring!
clang's Avatar
Oddometer: 2,791
Try the airport currency exchange.......
Sometimes it takes a whole tank full of fuel before you can think straight.
Ride for the soul!
'06 R12GS '92 R100GS '73 R75 /5 '01 F650GS '02 F650GS Dakar
clang is offline   Reply With Quote
Old 04-07-2010, 10:52 AM   #390
rkatapt
Indo-Kraut
Oddometer: 261
I called a couple of banks and they do not do coins. Plus I want them to be of the German type.
Times are GMT -7.   It's 08:16 PM.
