Old 02-18-2011, 01:19 AM   #526
curlysurfer
in need of a ride
curlysurfer's Avatar
Oddometer: 424
Originally Posted by Beemerboff View Post
I cant even get simple green at my local hardware store, never mind red Scotchbrite.
And they cant seem to get the prices right either, but funnily enough the mistakes are always in their favor.
I hope the new Woolies/ Lowes? stores give the business a bit of a shake up - they need it.
PM your address? I'll post 2 sheets of scotchbrite on Monday.
1962 Vespa VBB bali special 1975 BMW R75/6 resto job - collecting dust
couple of mountain bikes, 20 or so surfboards, not enough time........
curlysurfer is offline   Reply With Quote
Old 02-21-2011, 02:44 PM   #527
Firestorm
Firestorm's Avatar
Oddometer: 5,221
Here's a tip and trick, Don't sell your airhead...........
Keep it forever..........
Firestorm is offline   Reply With Quote
Old 02-27-2011, 04:19 AM   #528
ClaytonL
Oddometer: 1
Originally Posted by clang View Post
I do all my maintenance with the tool kit I carry on the bike. I have a fairly complete shop, but now I'm sure I have the tools to handle any task that arises on a trip, short of needing to order major new parts to install. Any time I ran across some tool I didn't have, I added it. Everything still fits in a small tool box -about 4" X 5" X 12"
Hey, I have read most of this thread. I really appreciate all the helpful tips provided thus far. I was wondering if you might be able to describe the contents of this tool box. Thanks again,
Clayton
ClaytonL is offline   Reply With Quote
Old 03-24-2011, 10:45 PM   #529
thevulture
thevulture's Avatar
Oddometer: 182
Clayton
This is good to look at.
http://www.advrider.com/forums/showthread.php?t=654644
“To do a dull thing with style-now THAT'S what I call art.”
Charles Bukowski
thevulture is offline   Reply With Quote
Old 04-12-2011, 10:26 PM   #530
beduboy
Oddometer: 1
R75/6 scrambler tyres
First time so please be gentle.Working in Oman[where's that I hear you say] and have a R75/6. Have been impressed with airhead scramblers and wd like to do same.Question is what are the tyres to fit a 19 in front and an 18 in rear[trail style]?Do I need to change front to an 18 in?[
Originally Posted by jtwind View Post
Here's a few tips aimed at first time airhead guys.
There are three fasteners holding your valve covers on, not just the big center nut. Can't tell you how many folks start whacking their valve covers without removeing the 10 mm nuts on the back side.
Remove and antisieze your exhaust nuts once a year. If they don't come off, DON'T FORCE, hacksaw a line or drill accross the threads and use a cold chisel to split them off. Forcing them will wreck the threads on the heads, a $125-150 repair.
Remove the battery ground wire before you remove the front cover. Failure to do so and touching the diode board can easily short out and be a $$ repair. JT
beduboy is offline   Reply With Quote
Old 04-12-2011, 11:01 PM   #531
Beemerboff
Oddometer: 2,329
If you mean street scrambler 70/ 30 tires like Avon Distanzas look the part and work great on asphalt and fine on unsealed roads/ gravel/ light sand.They list 19" fronts but dont always have stock , in Oz at least, but Tourances or Annekeys are passable if they are not
If you plan on riding in mud or deep sand go for a 50/50 tire, but most come in a 21" front and all are not very good on wet asphalt, unless you potter around like an old woman-------.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 04-13-2011, 07:12 PM   #532
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,532
I used to run TKCs when I had a 19" front. Good off and on road, got close to 4k out of em, pricey.
Old 04-14-2011, 07:39 AM   #533
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,070
I like the Distanzias on the R80 ST as well as I like the TKC 80s on the F 650. The F 650 has a 17 rear and in the USA the TKCs are readily available in the 19/17 combo. I went Distanzia on the ST because I couldn't find TKC in a 18" rear.
You may have both tires available over there. Both are good choices IMHO. And for rigorous off road sections, they can always be aired down to about 21psi without needing rimlocks for a small but noticeable improvement. A small 12V compressor will allow airing back up when returning to highway speeds for lengthy stretches.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 04-14-2011, 11:30 AM   #534
hardwaregrrl
ignore list
Oddometer: 7,532
Really? Just removed a very worn one from the ST. I think I got it at motorcycle superstore.
Old 04-14-2011, 11:36 AM   #535
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,868
google references a lot of them, but maybe not in the specific size width youre looking for.
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 04-14-2011, 08:28 PM   #536
Beemerboff
Oddometer: 2,329
If you are in Oz Barum sell the TK under their own Mitas brand ,for a good bit less than Conti charges for the same tire.
Mefo have it too, and just about split the difference.
Old 04-15-2011, 05:10 AM   #537
hardwaregrrl
ignore list
Oddometer: 7,532
Hey Mark, this is the size I was running on my rear ST wheel.
http://www.amazon.com/Continental-Tw.../dp/B000WJMXHM
Worked fine. Just too damn expensive!
Old 04-15-2011, 09:14 PM   #538
mark1305
mark1305's Avatar
Oddometer: 6,070
Thanks Jenna. I'll keep that in mind. At the rate I'm riding lately, it'll be awhile before I wear out the Distanzias.
I opened the April MOA ON to the Mileage Contest and checked FL first. I didn't finish last in the state. 4th from last. It was a bad year with the F650 parked for most of it.
On the plus side, the airhead is taking over the primary duties and it will probably remain that way.
Mark J
Merritt Island, FL
Old 04-26-2011, 01:41 PM   #539
BrianK
F'in' half ass lookie boy
BrianK's Avatar
Oddometer: 858
Originally Posted by boxerboy81 View Post
Why not, as it's relatively easy with the bits off. Soak in undiluted simple green, it'll wipe off the following day.
That's never worked for me. Nor has any other solvent I've tried. Only thing I've found to work well is a brass bristled brush in a Dremel.
BrianK is offline   Reply With Quote
Old 04-28-2011, 10:15 AM   #540
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,635
Deal!
crazydrummerdude is offline   Reply With Quote
Times are GMT -7.   It's 12:03 PM.
