Old 09-25-2011, 11:12 PM   #586
Mallard
insert joke here
Mallard's Avatar
Oddometer: 65
New addition for Haynes Manual - The DSBCP
I have a tip, to be used in the event you purchase a bike with an unknown history (lets for arguments sake just say a BMW R65 mono).
1) Put bike in neutral on center stand.
2) Loosen rubber gatier between gearbox and drive shaft. Recommend removing only the forward clamp that secures the gaiter.
3) Gently pry back gaiter.
4) Count the number of bolts used to secure the drive shaft flange to the gear box. You can slowly rotate the drive shaft by rotating the rear wheel with your free hand, to aid in the counting procedure. The correct number of bolts is 4 (four). If you get to eight, you probably have the correct number of bolts, but have gone around twice.
Signs that you should have conducted the drive shaft bolt counting procedure (DSBCP) sooner:
1) banging noises
2) rattling noises
3) people staring at you and pointing as you ride past
4) an overwhelming feeling of dread
5) removing the rubber gaiter between gearbox and drive shaft and having two stripped bolts fall onto the exhaust collector box, one bolt still half in and holding onto the drive shaft flange for dear life, one bolt MIA (never reinstalled by PO).
N.B. Signs 1, 2, 3, and 4 may relate to issues not related to the need to conduct the DSBCP.
The above DSBCP is not listed in the Haynes repair manual, however I suggest it is a 'one spanner' task for anyone who has watched five or more episodes of Sesame Street.
The DSBCP is recommended to anyone who hasn't actually seen the four bolts with their own eyes and is just assuming no PO could be that profoundly stupid.
Mallard screwed with this post 09-25-2011 at 11:17 PM
Mallard is offline   Reply With Quote
Old 09-26-2011, 02:53 AM   #587
Zebedee
Zebedee's Avatar
Oddometer: 845
Originally Posted by Mallard View Post
... [clip] ...
... [clip] ...
Point 5 sounds like a lesson learned in the school of hard knocks ... bugger, eh?
Hopefully the jungfrau didn't set you back too many beer tokens.
John
The perverse must persevere
Zebedee is offline   Reply With Quote
Old 09-26-2011, 04:11 AM   #588
Zodiac
loosely portrayed
Zodiac's Avatar
Oddometer: 31,764
Originally Posted by green hell View Post
check to see if there is a parker hannifin distributor around you, or a similar hydraulics fab shop.
good idea, thanks.
Black Shadow of Vincent, falls on a Triumph line
I've got my motorcycle jacket but I'm walking all the time...
Zodiac is offline   Reply With Quote
Old 09-28-2011, 06:05 PM   #589
DeutschMark
Full Tilt Boogie
DeutschMark's Avatar
Oddometer: 344
Zodiac, if you buy one of those H-pipes let us know how your bike runs. I'd be interested if you have any power loss.
89 BMW R100RS
97 Suzuki DR440
And away we go!
DeutschMark is offline   Reply With Quote
Old 09-28-2011, 06:23 PM   #590
Zodiac
loosely portrayed
Zodiac's Avatar
Oddometer: 31,764
will do, but it might be awhile - i ordered it from Motobins in UK, never ordered from them before but they never responded to my emails re the order - not expecting it to be here all that quick is all but maybe I'll be pleasantly surprised.
Being there's going to be 2 cross pipes, I'm hoping it's not a big change from the collector box.
Old 09-28-2011, 07:01 PM   #591
DeutschMark
Full Tilt Boogie
Oddometer: 344
I've had good luck with their service. When I overhauled my transmission, the parts were here in a week and a half all the way from England.
89 BMW R100RS
97 Suzuki DR440
And away we go!
Old 09-28-2011, 07:01 PM   #592
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,220
One of the more astonishing things about Moto-Bins is the parts arrive faster than if you had ordered them from the states. This used to be the case, it's been years since I ordered from them.
disston is online now   Reply With Quote
Old 09-28-2011, 07:29 PM   #593
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,040
[QUOTE=Zodiac;16959141] but they never responded to my emails re the order -
I have always had a return email confirming my order.
_____________________________________
"There's a fine line between a shearing and a skinning"
RecycledRS is offline   Reply With Quote
Old 09-30-2011, 05:51 AM   #594
Zodiac
loosely portrayed
Zodiac's Avatar
Oddometer: 31,764
I did get that, but emailed them a question and never got a repsonse - (regarding my order) - no worries, sure it'll be here soon.
Old 10-04-2011, 06:06 AM   #595
Mallard
insert joke here
Mallard's Avatar
Oddometer: 65
Rollers (from a roller bearing) in an R80 sump
Is it possible for a bearing to let go and drop a couple of rollers (not balls) into the sump (noticed during first oil change)?
I somehow repressed this unhappy memory and have been riding the R65 (mono) about for the last few months. Don't really want to fire the old girl up again until it's figured out.
It couldn't be as silly as the PO using the sump as a parts tray and then refitting it with bits still in there. It's not like there was a torque wrench in there too.
Old 10-04-2011, 06:23 AM   #596
Beemerboff
Oddometer: 2,350
The only roller bearings in the motor are the needle rollers on the valve rockers, so it isnt a big job to check if everything is OK there.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 10-04-2011, 06:36 AM   #597
Mallard
insert joke here
Mallard's Avatar
Oddometer: 65
Thank you Beemerboff,
Just found something Andy Gadget (post #14) wrote about it here:
http://www.advrider.com/forums/showthread.php?t=673944
Are you thinking along the same lines?
Old 10-04-2011, 08:58 AM   #598
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,220
There is a good bit of info on Anton Largiader's site:
http://www.largiader.com/tech/rockers/
It may be that the damage is from the rocker blocks being too loose but I think it happens to even well spaced rockers after the miles and heat take their toll. You can sometimes get good deals on a set on ebay but most of them are being sold by breakers and are over priced. Well, maybe it's not over priced but they are expensive. I want cheap and have bought sets for less than $50. If the rest of the system is good then replacing the bearings is a good, but expensive, option. Sorry it is a proprietary bearing and only available at your friendly dealer.
Old 10-04-2011, 02:03 PM   #599
Mallard
insert joke here
Mallard's Avatar
Oddometer: 65
Thanks Disston,
Looks like Moto-bins have the rocker arm needle bearings for 8.50 pounds each.
The last paragraph on Anton's site there is interesting too (not relevant to my mono application, but) - "Every style can be easily upgraded one level" - /5 to 74-75, /6 to 76-84, 76-84 to 85 on.
Mallard screwed with this post 10-04-2011 at 03:27 PM
Old 10-04-2011, 02:14 PM   #600
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,220
Yes. I am using /7 rockers, I think they are, on my /6. Works. Thank you Anton. BTW he is also on this site so you will hear his stuff first hand. There are a number of full time mechanics here and Anton is one of those. He has a BMW repair shop.
Times are GMT -7.   It's 06:41 AM.
