Old 10-09-2011, 11:44 AM   #601
Zodiac
loosely portrayed
Zodiac's Avatar
Oddometer: 31,746
Originally Posted by DeutschMark View Post
Zodiac, if you buy one of those H-pipes let us know how your bike runs. I'd be interested if you have any power loss.
Installed them today, first thing is that there's virtually no difference in sound while running, the H pipe is about as quiet as the collector box. Second is I notice no difference in power, feels identical but haven't been at top highway speeds yet.
Of course the bike lost what feels like 20lbs, and my collector box was pretty rusty/minor holes etc - I was able to finally see the backside and bottom of my transmission, and clean the area. Much sleeker look.
One thing I noticed is that all the stock BMW gaskets I bought really didn't fit from the years of cooked on old gaskets. I had to cut the 2 rears down to slip them in the cans. The fronts (soft gaskets) didn't fit at all, so I used a bit of red gasket sealant. So far no backfires.
I'm sold on Moto-bins, they're quick.
Black Shadow of Vincent, falls on a Triumph line
I've got my motorcycle jacket but I'm walking all the time...
Zodiac is offline   Reply With Quote
Old 10-09-2011, 08:02 PM   #602
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,577
Originally Posted by Zodiac View Post
I did get that, but emailed them a question and never got a repsonse - (regarding my order) - no worries, sure it'll be here soon.
If you replied to the order confirmation, I think that's an automated response and maybe a reply to that is something that isn't seen? You can reply direct to Damien from a link on the front page, just remember to include the order number. They get back to inquiries very quickly ime.
boxerboy81 is offline   Reply With Quote
Old 10-22-2011, 09:12 AM   #603
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
How-to: Neimann keys and key codes
Neimann keys decoded
So, I had this key and needed a new seatlock: no key code, just the key. Searched the internet and it came up with the information: There are 5 cuts in equal distance from the key stop, the deepest is a 1, no cut is a 5. See a couple of examples hereafter.
Addendum thanks to Kenny from Huntsville, AL (email Kenny directly)
... I took my cylinders out and measured the actual spacing between "tumblers" at 2.68 mm and the distance to the first cut is 3 mm.
The "tumblers" are only 0.67mm thick and the slots that they ride in are 0.90 mm so there is quite a bit of flexibility and slop if you use a round file. Now i was able to fine tune the key by fitting it to the cylinder and making adjustments--it's perfect. I used SR61N blanks but had to file off the hump of the big key stop to make them work.
Also you may be interested to know that if you measure the distance from the rail slot on the reverse side (seen in your pictures key 4 and 5) to the bottom of the "cut", the distance is an even value: Codes 1,3, and 5 are 1.0, 2.0 and 3.0 mm, and Codes 2 and 4 are 1.5 and 2.5 mm from the rail edge to the correct "cut depth" for that particular Code number. ... The measurement is easy using an outside-measuring caliper.
http://stephenbottcher.net/BMW/keys.htm
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 10-23-2011, 10:44 AM   #604
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,070
That is priceless info, SB.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is online now   Reply With Quote
Old 10-26-2011, 12:13 AM   #605
darklight79
scaffold builder
Oddometer: 426
Originally Posted by W8EJO View Post
Anyone know of an off the shelf (NAPA, etc) replacement that will fit the R90S gas tank. Prefer chrome, non-locking.
What color is the tank?
darklight79 is offline   Reply With Quote
Old 10-26-2011, 06:00 AM   #606
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,719
Why does it mater what color the tank is?
I've never heard of a generic gas cap that fits that gas tank. Then again there are many wonderful and strange things in this world that I'm not familiar with, so don't give up hope just yet.
Old 10-26-2011, 12:32 PM   #607
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Originally Posted by Mallard View Post
Thanks Disston,
Looks like Moto-bins have the rocker arm needle bearings for 8.50 pounds each.
The last paragraph on Anton's site there is interesting too (not relevant to my mono application, but) - "Every style can be easily upgraded one level" - /5 to 74-75, /6 to 76-84, 76-84 to 85 on.
Actually, the /5 can be upgraded two levels. I can do the mod for anyone that wants.
There are three ways to do it, I like the simplest way.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 10-26-2011, 05:38 PM   #608
JohnLocke
JohnLocke's Avatar
Oddometer: 195
Black
JohnLocke is offline   Reply With Quote
Old 10-31-2011, 08:33 AM   #609
coastranger
Oddometer: 429
ive been interezted in those also. any change in carb settings ? Of course to loose 20 lbs is always a plus
coastranger is offline   Reply With Quote
Old 10-31-2011, 08:38 AM   #610
Zodiac
loosely portrayed
Zodiac's Avatar
Oddometer: 31,746
I seem to recall someone mentioning that older gas caps from Lincolns (60/70/80's) work but just here-say on my end.
Old 10-31-2011, 08:40 AM   #611
Zodiac
loosely portrayed
Zodiac's Avatar
Oddometer: 31,746
No changes in carb settings, runs great - but not much heavy riding to test these days, busy planning a sneak attack on the front end soon....
Old 10-31-2011, 03:18 PM   #612
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,635
Just a little unrelated trick:
Sometimes the oil filter is hard to get out. Most of the time, for me anyway, a magnet gets it.. but on the barn-finds, the filter is usually stuck a littler harder. Then it dawned on me, a paint can opener:
Worked perfectly.
crazydrummerdude is online now   Reply With Quote
Old 11-01-2011, 10:55 AM   #613
camgregus
riding gently now
camgregus's Avatar
Location: on the banks of the mighty mississippi, AR side
Oddometer: 3,006
Believe it or not, I found a oil filter remover just for airheads on ebay....
It is a cool airhead motor beer bottle opener too. Sold me!!!!
got to get it on the good foot
camgregus is offline   Reply With Quote
Old 11-01-2011, 01:52 PM   #614
mark1305
mark1305's Avatar
Oddometer: 6,070
Now that you say that, paint can openers look to be bottle openers too.
I just looked at the three I have in the garage and the handles are all identical and look like bottle openers. I'll have to buy a bottle or two of good beer to test them on.
Mark J
Merritt Island, FL
Old 11-01-2011, 06:45 PM   #615
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,864
Thats actually on purpose, if you know painters
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Times are GMT -7.   It's 11:20 AM.
