Old 06-04-2014, 02:12 PM   #961
JMforPres
JMforPres's Avatar
Oddometer: 446
I love how you lowered the back-end for that low-rider look.
Jon
R100GS
R1150GS
R1150RT
77 R100RS
"I picked up a nice burlap thong. It makes me feel pretty." - BluRidgeRider
JMforPres is offline   Reply With Quote
Old 06-05-2014, 12:49 AM   #962
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,236
Yeah - he must have installed a track to made sand riding easier.
Originally Posted by WU7X
Could you replace the offending tubing with some aluminium tubing with a similar ID?
I tried that. Had issues with heating the gas from the hot transmission.
Old 06-23-2014, 10:05 AM   #963
hmmmm90s
hmmmm90s's Avatar
Oddometer: 34
Cheap Trick -- Best Trick -- Rustoleum Spray Bedliner
I'll admit I didn't think of this one myself, but I have to vouch for its efficacy (and its cheepnizz).
I have been slowly going through my 1975 R90S to make it useful for every day NoVA combat commuting -- its a bit better suited for cut-and-thrust, lane splitting and an occasional shoulder run than -- ehem -- my larger bike.
This is a low budget project, so I've done my best to work with what I already have, where possible.
I have had a set of mid-80s vintage touring cases sitting on a shelf, but they were -- a little rough.
The bike had taken a slide resting on one of them, the forward corners were ground away from touching them down in curves, and they were generally beat from being bonked off of the pipes -- yellow paint! -- that many DC parking areas use to mark off bike parking areas. In short, they were mechanically functional but UUUUUUUgly.
I remember an inmate claiming this stuff was the bomb, and whoever you were buddy, you were right!
After 5 minutes with a palm sander, about 20 minutes masking the cases off, and about 90 minutes to apply two coats and re-install the lids, I'm ecstatic.
Other than the limitation of my own skills with a spray can -- I got one run -- the Rustoleum brand spray bedliner is the bomb -- these cases look GREAT!
http://1drv.ms/1jJvrWO
I can see this stuff working well for a number of moto uses -- beat lower fairings, side covers, etc -- anyplace where black looks good (Black looks good EVERWHERE -- I'm a biker, 'member?) and where some resistance to bumps and scrapes is needed, this is the hot ticket.
ADVRider is the gift that keeps on giving.....
g.
greg shamieh boof # 93 k-whiner # 83 jefferson, maryland
shamiehg@comcast.net
2000 K1200LT --- "darkside"
75R90S -- "esssss"
73R75/5 -- "mojo"
hmmmm90s is online now   Reply With Quote
Old 06-24-2014, 10:41 AM   #964
Malindi
Zen Adventurer
Malindi's Avatar
Oddometer: 5,420
g.
75R90S -- "esssss"
73R75/5 -- "mojo"
Looks perfect! Nothing wrong with it!
Back in YVR after riding around the world for 2 years. www.nohorizons.net
Malindi is offline   Reply With Quote
Old 07-11-2014, 07:54 AM   #965
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,930
H4 bulb funkiness
That last couple of weeks, when I turned the switch ON prior to starting, the headlight didn't come on.... but then did, once I started the bike. I thought, hmm, odd, but thought no more about it....
...until one night after being at a friends for a cookout, the light did not come on... at all. I rode home in the dark, using blinkers to alert cars to my on the much-deserted streets (and caught hell from the wiser-half!)....
I thought it was a relay, switch, whatever, but thought it odd that the blue bright-indicator DID come on when the switch was on HI. Did some basic testing, found full juice at the headlight plug: BOTH hi and low beams were burned out! Filaments looked good, but a resistance test confirmed a both-burned-out bulb. There was a bit of white-ish around the base of the perfectly good looking bulb.
Got a new bulb, and realize that the old bulb was probably original, vintage 1984, and a lot better built than the new one!
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 07-11-2014, 09:10 AM   #966
TDL028
man of leisure
TDL028's Avatar
Oddometer: 390
same thing happened to me-- of course after re-wiring, testing, cursing and almost starting over.. i tried a new bulb and it worked perfectly.. the old bulb looked perfect!?!
My '84 R80 overhaul:
http://www.advrider.com/forums/showt...errerid=297067
Frame Hoops: Gasolineheaven.etsy.com
Instagram: too_many_projects
Gasoline_Heaven
TDL028 is online now   Reply With Quote
Old 07-11-2014, 09:36 AM   #967
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,930
Yes, the 'look' of it can be quite misleading, that is why I used my multimeter to check whether the filament was continuous... even though it looked good, it was in fact nfg. New bulb: perfect!
Loving the 80ST
Old 07-11-2014, 10:18 AM   #968
685
Scarred Adventurer
685's Avatar
Oddometer: 1,001
Probly oughta let BMW know, they'll want to issue a recall. ..
To post images. Go to http://postimage.org/ and do what they require. Copy it to clipboard (there's a box.) Paste the link (right click on the mouse, then left click 'Paste'.) Voila you got an image!
685 is offline   Reply With Quote
Old 07-11-2014, 05:37 PM   #969
RagerToo
vroom vroom
Oddometer: 303
Dat mean SixEightFive! since dat made in america bike has a few issues this week.
'80 R100RS but nekkid
Some folks still insist on going to a gun fight with a popsicle stick sharpened on the driveway.
RagerToo is offline   Reply With Quote
Old 07-29-2014, 11:17 PM   #970
RagerToo
vroom vroom
Oddometer: 303
broken kill switch 'knob'
As a stopgap repair for a switch of most any kind that has a plastic knob that operates the switch. Find a suitable screw or other metal object, hold it in some pliers and heat it with a small torch. For instance, a soldering iron torch and quickly shove it into what remains of the plastic knob.
I snapped off the turn signal switch lever on my car. The entire assembly is plastic, including the lever and no glue seemed to work. The switch assembly is US$160. Ouch. I used a 4 inch long (patio) deck screw to make a 'new' lever and slipped a piece of Tygon fuel hose over it.
No, it ain't pretty.
Old 08-22-2014, 07:53 PM   #971
shootmymime
Oddometer: 24
How do you guys clean the oxidation and road dirt and grime from 33 years off my bike?
shootmymime is offline   Reply With Quote
Old 08-22-2014, 08:37 PM   #972
JMforPres
JMforPres's Avatar
Oddometer: 446
I don't and call it patina.
Jon
R100GS
R1150GS
R1150RT
77 R100RS
Old 08-22-2014, 09:34 PM   #973
685
Scarred Adventurer
685's Avatar
Oddometer: 1,001
Clay bar may restore the paint's shine. To get the oily dirt off and the ever present sheen of gear oil, I use Awesome Orange degreaser from Dollar Tree. Get a sprayer and squirt it on, agitate with a brush and rinse it off with water.
Works really well for me.
Old 08-22-2014, 09:49 PM   #974
Merlinzen
Oddometer: 121
hey guys
I just had a little "off"...
New back tyre [tire] fitted this morning.
Left my driveway and turned onto the street and the back end stepped out on me and I low sided it before I knew it.
What is collective wisdom these days to get rid of the slippery stuff that's on them when they're new?
Sandpaper?
Brake cleaner?
Bloke who fitted it said "just take it easy first 100Km or so"
I've never had any problem any other time in the past.
This one is a Metzler, if that makes a difference.
Merlinzen is offline   Reply With Quote
Old 08-23-2014, 08:01 AM   #975
685
Scarred Adventurer
685's Avatar
Oddometer: 1,001
Originally Posted by Merlinzen View Post
hey guys
Sandpaper?
Brake cleaner?
I'm too lazy to take sand paper to a new tire. A gravel road will do the same thing. And take it easy for the first 100Km or so.
Times are GMT -7.   It's 09:07 AM.
