Old 12-16-2014, 11:37 AM   #1
IslanderXJ OP
Oddometer: 11
XR650L Swingarm/Chain Slider?
My swingarm is currently fighting a losing battle with my drive chain, the wraparound slider is toast.
I've been trying to find a replacement, preferably something better than factory.
Looks like the xr250r, xr600, and XR650L all share the same slider.
Here's what I've found:
Factory: Wears quickly, made of rubber, same price or more then aftermarket
MSR: Rave reviews, long lasting, discontinued. MSR switched manufacturers, now uses TM Design Works
TM Design Works: Doesn't make one
UFO: Bad to mediocre reviews, but available.
Acerbis: Rave reviews, long lasting, discontinued. No leads on alternate.
Help?
IslanderXJ is offline   Reply With Quote
Old 12-16-2014, 11:45 AM   #2
mcma111
mcma111's Avatar
Oddometer: 12,403
Suck it up tootsie and buy the OE part.
SLIDER, CHAIN
52170-MN1-681
$35.64
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-16-2014, 12:00 PM   #3
Ulyses
Ulyses's Avatar
Oddometer: 1,086
If you are in a pinch and/or want to make one really cheap, you can just cut up an old cutting board or some hard nylon sheeting and pop rivet it on your swingarm...
It's loud, but it works.
Ulyses is offline   Reply With Quote
Old 12-16-2014, 02:31 PM   #4
IslanderXJ OP
Oddometer: 11
I'd rather bend up and bolt on a strip of UHMW than bolt that junk back on. Guess I'll be adding that to the chain roller project. Off to McMaster!
SLIDER, CHAIN
52170-MN1-681
$35.64
Old 12-16-2014, 03:09 PM   #5
alvincullumyork
I wish I was cool
alvincullumyork's Avatar
Oddometer: 1,779
I would stick with the stock slider. The chain roller sounds cool though. Post up whatever you come up with it. I'll be interested as I can't go back to a stock slider and am stuck using Ulyses method (more specifically his actual cutting board is still the bottom slider.)
How to ride your XR650L to South America: http://advrider.com/forums/showthrea...2#post19932112
If you're in my area on a ride and need a place to crash, a hot meal, or some beer let me know. 913 260 7873
On a one man mission to stop people from buying boring bikes (cough cough klr)
alvincullumyork is offline   Reply With Quote
Old 12-16-2014, 03:20 PM   #6
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,780
Don't forget to slot for the little key where it wraps around the radius that keeps the guide from moving fore and aft. Heat gun is a little more elegant than oxy acetylene like I used.
katbeanz is offline   Reply With Quote
Old 12-16-2014, 03:32 PM   #7
alvincullumyork
I wish I was cool
Oddometer: 1,779
Got pics of yours?
Old 12-16-2014, 03:59 PM   #8
katbeanz
katbeanz's Avatar
Oddometer: 7,780
Originally Posted by alvincullumyork View Post
Got pics of yours?
Sorry, I just used a trashed OEM and traced with a sharpie, it was fiddly using the original mount holes. 14 tooth front probably made the original wear faster. There was an Arkansas DS ride I wanted to do and not enough time for one to ship.
Old 12-16-2014, 05:13 PM   #9
Ben99r1
Ben99r1's Avatar
Oddometer: 3,067
I ordered a tusk one from rockymountain.com two years ago. Still working fine and it was about $19-$20.
Ben99r1 is offline   Reply With Quote
Old 12-16-2014, 05:26 PM   #10
IslanderXJ OP
Oddometer: 11
Tusk! I forgot about them!
Old 01-05-2015, 10:14 PM   #11
IslanderXJ OP
Oddometer: 11
I made one out of a 3/8 thick cutting board, worked great till I tried to install it in 35* weather the night before a trip to Johnson Valley. Bent it up with a heat gun, with the little slot and everything. Cracked dead center of the bend, said screw it, installed it anyway. Also installed MSR rollers into the rear chain guide, front lower chain slider, and added one where the chain guard use to mount.
Put and 200 miles on it all offroad in the desert silt/sand. Worked great, almost no wear, very quiet.
When I got back home my buddy pointed out that the cutting board was polypropylene not polyethylene and that's why it snapped.
I ordered a 1/4" thick piece of UHMW Polyethylene that should work perfect and be a little easier to cut, form, and install.
I'll get picks of the prototype up tomorrow.
IslanderXJ screwed with this post 01-05-2015 at 10:22 PM
Times are GMT -7.   It's 10:57 PM.
