Old 10-28-2008, 05:16 PM   #46
Wylie
Back in the saddle again
Wylie's Avatar
Oddometer: 2,234
Rotella T baby!
I started to look into the oils and colder temps and came up with a synthetic answer.
http://autos.yahoo.com/maintain/repa...ques120_1.html
And then there are all the claims by a compAmsy not often mentioned here because of the relentlessness of the marketing they do.
Okay so I'm not Super Man. I'm just the jack of many trades, master of some yet to find and as the world turns that would only be for a matter of time.
Okay, screw it, stop the world I'm getting off.
Wylie screwed with this post 10-28-2008 at 05:26 PM
Wylie is offline   Reply With Quote
Old 10-28-2008, 08:13 PM   #47
G.Kennedy
G.Kennedy's Avatar
Oddometer: 1,850
Originally Posted by Tuff Tunica
..........., 660 kit, rally cam,.........
Curious where you sourced these two items???? I thought they were unobtainium in the States.
My '02 is about to pass 25,000 miles ... running perfectly, but I am considering tearing down this winter and doing valves, cambearing and chain ... figure if I am in there I will do the rings. But .. if I could make it a 660 ...hmmm
I would like your thoughts on the 660 .... fyi ... still using a BST here, not sure if 660 and BST go together.
'00 R1100RT
'05 525EXC
'08 Hypermotard
IBA#11791
G.Kennedy is offline   Reply With Quote
Old 10-29-2008, 05:28 AM   #48
Tuff Tunica
Moto-Skiveez creator
Tuff Tunica's Avatar
Oddometer: 692
Can't help with the BST compatability question, as for the parts try this http://www.ktmax.de/indexa.htm. And YES as far as I know they are unobtainable in the states. But you can get them abroad and have them sent. Let me know if you need more info.
Tuff Tunica is offline   Reply With Quote
Old 12-26-2014, 06:58 PM   #49
AdventureDave
MMMMM Bundy!
AdventureDave's Avatar
Oddometer: 737
625 SXC oil cooler
I thought I would revive this old thread and see if anybody has come up with anything creative for adding an oil cooler to a 625 sxc, LC4 or 640 ADV? I have the Australian delivery model with the oil in the frame, so I already have the 1.9 litres but keeping it cooler and adding another few hundred mls would be good.
After searching it seems that Setrab and Jagg have the best 'bike suitable' oil coolers to start from. The 660 rallye nav tower mounted is over $1000 so isnt really a sensible option.
Does the twin air model connect easily to the LC4 motor?
All input, thoughts, meanderings are welcome.
Cheers
David
AdventureDave is offline   Reply With Quote
Old 01-05-2015, 11:25 AM   #50
Rockgarden Bob
Rockgarden Bob's Avatar
Oddometer: 216
Cheers
David
I'm also looking for an oil cooler for a 2004 625 SXC, I'll post if I find something. Been wondering if the Twin Air will work.
Bob
http://www.ironmandualsport.com
Rockgarden Bob is offline   Reply With Quote
Old 01-05-2015, 01:26 PM   #51
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,253
... I already have the 1.9 litres but keeping it cooler and adding another few hundred mls would be good. ...
You may be going overboard wanting to add more oil capacity. It looks like the 660R has an oil cooler, but that's for racing. Do we mere mortals need it?
That said my 03 640A was able to overheat when running slowly (traffic jam) in hot (HOT) weather - Tennessee summer. Some thoughts on that issue:
My fan comes on when the bike is already damn hot - seems late. There is a different thermostat switch that some put on their bikes to make the fan come on earlier. Others wired a manual override switch to the dash.
There is room for a second fan on the other radiator (at least on the 640A). Wiring a second fan to come on with the first (or manually) is probably the best option.
If you really need to stay cooler then there are aftermarket radiators that are higher efficiency than the stock KTM units. Pricey, yes, but this will keep your bike cooler for sure.
If you have higher efficiency radiators you could then use a higher efficiency coolant (Water Wetter, Evans, or liquid Sodium?) but remember that your temp gauge is calibrated to the stock setup - you'll need a new temp monitoring setup (CHT or EGT is better than coolant temp anyways).
And/or you could connect an oil cooler; una mas:
http://www.advrider.com/forums/showthread.php?t=74910
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 01-06-2015, 05:02 AM   #52
AdventureDave
MMMMM Bundy!
Oddometer: 737
Thanks Meat. I dont race, not even close, but I do live in subtropical Queensland and my bike can overheat in traffic on a hot day. I have just fitted the second fan and changed to the lower temp thermostat and yes they do make a difference but I am concerned about doing desert trips or low speed sand in the still weather. Combine that with gear for camping and I thought a cooler may help. It is surprising how many bikes come standard with an oil cooler.
I'll take what you said on board and maybe rethink... I maybe overcomplicating things.
Cheers
David
Times are GMT -7.   It's 07:52 AM.
