Old 10-02-2006, 12:44 PM   #1
KTMBill OP
KTM Billy
Oddometer: 188
Question Water in KTM hardluggage? Anyone done it..
Hey, has anyone out there fitted the little taps to their KTM hard plastic luggage for water storage? I see where the taps go (aka fuel taps) but dont see where your supposed to fill it up? Assume forced up thru the taps?
http://www.ktmtwins.com/950adventure/58507003000.html
cheers
KTMBill is offline   Reply With Quote
Old 10-02-2006, 12:50 PM   #2
Manny Fagnet
Manny Fagnet's Avatar
Oddometer: 223
cheers
No,there is a rubber grommet in the top of the pannier lining which you just take out and fill up using a little funnel or similar
Manny Fagnet is offline   Reply With Quote
Old 10-02-2006, 01:00 PM   #3
RAGrote
RAGrote's Avatar
Oddometer: 1,021
I've done it.
Heavy!!!
Works though....
5.5 vanilla with chocolate "S" suspension
RAGrote is offline   Reply With Quote
Old 10-02-2006, 01:59 PM   #4
katoosh
Catch&Release Wild Trout
katoosh's Avatar
Oddometer: 266
Seems like it would be a major bitch to clean/dry to keep mildew at bay. The tanks on my sailboat (RIP) had observation/cleaning access panels not present on Gobis.
katoosh is offline   Reply With Quote
Old 10-02-2006, 02:01 PM   #5
BLUE(UK)
BLUE(UK)'s Avatar
Oddometer: 3,423
I've done it and use em often.They work perfectly ok.
BLUE(UK) is offline   Reply With Quote
Old 10-02-2006, 02:26 PM   #6
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,475
Normal sterilising tablets should keep the mould at bay if you're worried. I keep my Camelbak mould-free by storing it in the freezer, but that's probably not practical for panniers :)
uk_mouse is offline   Reply With Quote
Old 10-02-2006, 03:44 PM   #7
scottr
scottr's Avatar
Location: Pedernales R., Tx Hill Country (Ihadthisavatar1st)
Oddometer: 1,768
Bluhduh
Either you are single of your wife is a saint. If I so much as ASKED to put my camelback in the freezer it would only add to my ever mounting and unpayable debt to 'that woman'.
scottr is offline   Reply With Quote
Old 10-02-2006, 05:01 PM   #8
Gregg Wannabe
Just killing time
Gregg Wannabe's Avatar
Oddometer: 2,402
You're married to my wife?
Gregg Wannabe is offline   Reply With Quote
Old 10-02-2006, 05:12 PM   #9
El Diablo
Mama I'm goi'n fast!
El Diablo's Avatar
Oddometer: 747
On the inside there are the rubber inserts. Last time I transported ice which turned in to water it took me a while to drain it.
El Diablo is offline   Reply With Quote
Old 10-02-2006, 07:33 PM   #10
jonnyboy
jonnyboy's Avatar
Oddometer: 9
i use my left one for for wine ( easy to fill from a wine box!! ) the right is for water. does not seem to effect the taste of the water (or wine).
jonnyboy is offline   Reply With Quote
Old 10-03-2006, 12:07 AM   #11
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,475
Either you are single or your wife is a saint. If I so much as ASKED to put my camelback in the freezer it would only add to my ever mounting and unpayable debt to 'that woman'.
She's got more camelbaks than I have! It must be a bit like shoes, you can't wear the same one for running and trail riding
Old 10-03-2006, 04:16 AM   #12
inte
neophyte serendipity
inte's Avatar
Oddometer: 2,738
Yep.
Use them through a 118-deg run through Arizona ... heavy, but sure was a great feature ... just high enough that it can even serve as a running-water defacto shower.
I found easiest way to fill is oddly enough by using a camelback - just pull the bite valve off & the hose fits perfectly in the fill hole - pull both rubber gromets off as the 2nd one allows air to escape while filling.
cheers
Sum, ergo Cogito, ergo Dubito pullus.
http://blog.motorrad-adventure.com
Twitter: @adventurephotog
Instagram: @adventurephotog
inte is offline   Reply With Quote
Old 10-03-2006, 05:00 AM   #13
KTMBill OP
KTM Billy
Oddometer: 188
Laugh Wow - we're all at it!
Thanks guys,
I particularly like the Wine example - now was it on the left or the right? Hell of a way to get blathered (english word) while travelling thru the Western Sahara....
Fully loaded, with a pillion, and hard luggage AND water - wow, need a bigger bike!
I'm thinking on putting two little flags horizontally on my front crash bars to remind me of the fat arse behind me ( the luggage, not the chick on the back!). I keep attempting filtering - then realising at the last minute that I'm fully laden with the luggage!! I'm sure there's a few stories on here about incidents of that nature!!
Sahara - here I come....
Old 10-03-2006, 05:52 AM   #14
Louge
silence of the limbs
Louge's Avatar
Oddometer: 1,554
They served me well on the road for 6 weeks making coffee, Gatorade / milk from powder, dinners and Jetboil / pan cleanup. I used my pan to fill the front plugs.
http://www.advrider.com/forums/showthread.php?t=142173
Enjoying your dinner after finding THE perfect lake front campsite at dusk ... Priceless!
My pillion was at home, no dessert for me.
Just how deep do you believe?
Will you bite the hand that feeds?
Nine Inch Nails
Louge is offline   Reply With Quote
Old 10-03-2006, 08:10 AM   #15
jonnyboy
jonnyboy's Avatar
Oddometer: 9
luggage and taps being used as intended!!
jonnyboy screwed with this post 10-03-2006 at 08:15 AM Reason: to big a jpg to fit resized
Times are GMT -7.   It's 05:27 PM.
