Old 08-05-2012, 06:27 AM   #5641
Antti
Antti's Avatar
Oddometer: 186
R1100GS, 690 Enduro, R80G/S project bike.
Antti is offline   Reply With Quote
Old 08-05-2012, 07:45 AM   #5642
Geoffster
Fool - Born This Way
Geoffster's Avatar
Oddometer: 1,373
Originally Posted by mike,p View Post
What are you guys getting out of your chain life? Thx
My experience is that the stock aluminum Sun-Star rear sprocket is shot in 6k-9k miles depending on care, and that's the end of your first chain.
I'm at 10k on an RK with steel sprockets and expect to get AT LEAST another 10k. (That's with Ed's cleaning/lubrication method using kerosene and 30 weight. He gets 40+k on the street!)
Somewhere around here Walter reported on his chain/sprocket life ...
Consider this before arguing with me:
You're an idiot if you argue with a fool!
http://www.flickr.com/photos/geoffster/sets/
Geoffster is offline   Reply With Quote
Old 08-05-2012, 08:32 AM   #5643
aprilian
Can I change this?
aprilian's Avatar
Oddometer: 466
appologies in advance...
I searched this and the other g650x thread and could not find the post that I know I have seen.
My handlebars twisted slightly in the top clamp. I put together a 2 foot extension bar and went at the left nut from below - no luck budging it. The right one is blocked by a metal tang when wheel is straight ahead on my lift table.
Absolutely no info on handlebar clamps in the CD service CD.
Can someone point me to the post with the "how to" for this fix.
PS Taking the bike to display it in an italian motorcycle show today
There is no such thing as bad weather, only inadequate clothing.
aprilian is offline   Reply With Quote
Old 08-05-2012, 09:11 AM   #5644
kito
Oddometer: 278
hi I have fitted a bigger rad on my bike after getting fedup of the fan coming on all the time . when it arrived they have given me 2 new filler caps were you put the coolant in . 1@ 0.9 bar 1@ 1.3 and i have the OEM 1@ 1.5 bar .what is the reason for this ? is 1 better than another ? so which 1 should I be using while touring round south america ?
kito is offline   Reply With Quote
Old 08-05-2012, 01:48 PM   #5645
The Jester
The Jester's Avatar
Oddometer: 848
Not sure about the caps but I suppose that the higher rated cap will withstand a greater pressure and therefore greater temperature before boiling over. I'd be interested to hear more about your rad though, especially if it can be had cheaply. It doesn't look like it is the same one that the same of the UKGSer guys had made, was that by Pace or something I think?
Life is not a rehearsal!
The Jester is offline   Reply With Quote
Old 08-06-2012, 04:46 AM   #5646
kito
Oddometer: 278
hi yes my new rad is the pace one also but the newer version with the ali guard on it . the ali also helps with the cooling as it acts as a heat shunt if you like . now I can ride without the fan on all the time.
Old 08-06-2012, 07:56 PM   #5647
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,453
Just saw your post. It sounds like you may have actually bent the bolts or the washers under the bolts, so post up a pic of your situation. The one of the right side of the top triple clamp requires you to put the bars at full lock left to get to the bolt.
From your PM, here's my answer so people can find a possible answer in the future:
When trailering, do not attach the tie-down straps to the handlebars. Attach them to the fork tubes, just above the lower triple clamp.
The quick way to straighten things out is to just push the bars back into place using the steering stops on the bike or bracing the front wheel against something. The right way is to loosen up the bolts underneath the top triple clamp and the bar clamps, straighten things out, then tighten it all down again.
tbarstow is offline   Reply With Quote
Old 08-10-2012, 01:58 PM   #5648
ridepjride
Migrant
ridepjride's Avatar
Oddometer: 329
New owner checking in.
ridepjride is offline   Reply With Quote
Old 08-10-2012, 02:20 PM   #5649
slide
A nation in despair
Oddometer: 21,122
Did you fashion that aux fuel tank?
Why be born again when you can just grow up?
slide is offline   Reply With Quote
Old 08-10-2012, 03:39 PM   #5650
ridepjride
Migrant
ridepjride's Avatar
Oddometer: 329
Yes, mounted to side rack using aluminum plate and P-shaped clamps from hardware store.
Old 08-10-2012, 04:39 PM   #5651
azgsa
Apathetic
azgsa's Avatar
Oddometer: 1,367
That was a quick mod, you just rode that homefrom TedShred's last night, right?
Arizona Adventure Riding Group
azgsa is offline   Reply With Quote
Old 08-10-2012, 05:36 PM   #5652
ridepjride
Migrant
ridepjride's Avatar
Oddometer: 329
Yup, wanted to take a ride this morning and had to extend the range with what I had in the garage.
ridepjride screwed with this post 08-10-2012 at 05:46 PM
Old 08-19-2012, 08:22 PM   #5653
ridepjride
Migrant
ridepjride's Avatar
Oddometer: 329
I've a question for those with the Hepco & Becker rack. There are 2 threaded holes on the right subframe leg where the lower rack bracket bolts on. The lower hole is 8mm but the upper one is 5mm. Its purpose from the factory is for securing the wheel well plastic shield, and doesn't seem to be large enough to provide a solid mount for the rack.
When you installed your rack, did you maintain the smaller bolt or did you drill/tap for an 8mm bolt?
Old 08-19-2012, 09:37 PM   #5654
DrWatson
Oddometer: 469
g650x-c clutch lever pivot bush
posted same on x-c link. Can anyone assist?
has anyone ever replaced this bush?
The BMW part number on many sites is correct part number however the part BMW have supplied doesn't fit. We (the dealer and I) have tried ordering it twice now. Apparently they have discussed it with BMW Australia and Germany and can't work it out.
The G650X-C has a brass or bronze coloured bush in the clutch lever and pivots on a bolt like most levers do. the part they are supplying is a plastic similar bush however the bolt has no hope in hell of going through it.
I have verified a mates X-C is also the same as mine.
The newer G650 models have the same part number and the black plastic bush is correct for those bikes because the pivot bolt is a narrower bolt.
Bloody bad service when BMW are asking me to pull it apart take photos and measurements for them!
Love any assistance
thanks.
DrWatson is offline   Reply With Quote
Old 08-25-2012, 02:06 PM   #5655
ridepjride
Migrant
ridepjride's Avatar
Oddometer: 329
Keeping the thread alive....Bear Valley Road this morning.
Times are GMT -7.   It's 02:19 AM.
