Old 03-02-2013, 10:52 PM   #5731
velofleche
Oddometer: 24
parts for x bike?
Can anyone tell me does this forum have a location just for x bike spares and parts? Much obliged, sorry if i'm in the wrong spot! Cheers
velofleche is offline   Reply With Quote
Old 03-03-2013, 05:24 AM   #5732
Bli55
Oddometer: 364
Royal Tiger, ohh yes yes!!!!!
Massive thank you to you!!!!
Any more pics?
Bli55 is offline   Reply With Quote
Old 03-03-2013, 06:52 AM   #5733
alpi
alpi's Avatar
Oddometer: 76
Yes, there's this thread that contains a spreadsheet.
'07 G650 XCh (and '04 recumbent bike)
alpi is offline   Reply With Quote
Old 03-03-2013, 09:33 AM   #5734
Royal Tiger
Pz VI B, Sd Kfz 182
Royal Tiger's Avatar
Oddometer: 1,379
Any more pics?
Just of her in various states of being torn down. I plan on posting a thread about all the changes when I'm done.
2013 Yamaha XT250 * 2012 Kawasaki Ninja 250 {SOLD} * 2007 BMW G650X XChallenge {SOLD} * 2005 BMW R1200ST {maybe FOR SALE} * 2003 Yamaha PW80 {FOR SALE}
Royal Tiger is offline   Reply With Quote
Old 03-03-2013, 09:44 AM   #5735
slide
A nation in despair
Oddometer: 21,122
Help me find a picture!
It's of a cool sticker set, and I'm pretty sure it was on an X-challenge or x-moto.
A black backrgound it was with fading blue squares/cubes, something like:
Please, I've been searching for hours and can't find it again!! :
Why do you think there is a pic here? I dn't see it
Why be born again when you can just grow up?
slide is offline   Reply With Quote
Old 03-03-2013, 12:05 PM   #5736
velofleche
Oddometer: 24
Thanks for the spread sheet link. But what i'm searching for is used parts and accessories that fit the 'X' bikes. If anyone can guide me that direction, i'd be most obliged!
Old 03-03-2013, 02:29 PM   #5737
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,556
http://advrider.com/forums/forumdisplay.php?f=53
Just the regular "Parts" section of the Flea Market. You can only see the flea market while you're signed in.
Marc
07 XChallenge
Butters is offline   Reply With Quote
Old 03-03-2013, 07:05 PM   #5738
red neckerson
Lifetime novice
Oddometer: 95
I've searched quite a bit...maybe using less than ideal keywords, I don't know, but has anybody fabbed a removable cargo plate (Caribou style) to adapt larger loads to the Tourtech / genuine BMW small tail rack? Something simple and flat or shallow basket-ish? TIA
Still slow after all these years...
2007 BMW G650X Challenge
2000 Honda XR250R
1986 Honda XR250R
1980 Yamaha DT125
1986 Yamaha YZ80
1995 Harley 1200 Sportster
red neckerson is offline   Reply With Quote
Old 03-07-2013, 02:55 PM   #5739
Royal Tiger
Pz VI B, Sd Kfz 182
Oddometer: 1,379
Any more pics?
I just added a few more in my new thread on her:
http://www.advrider.com/forums/showthread.php?t=868707
Old 03-14-2013, 04:42 PM   #5740
Bli55
Oddometer: 364
I'm preparing to install oil temperature gauge, who knows for sure which direction does the oil flow?
Pipe 9 which runs under the engine - returning to tank or feeding the engine circuit?
Old 03-15-2013, 11:58 AM   #5741
Bike#8
Location: Socal=Mt. Laguna & Palomar Mtn.> Now in Idaho Yea!
Oddometer: 173
Remove the dipstick while the engine is running. Shine a light into the tank and you can observe the oil flow returning to the tank. Memory is vague regarding direction, so best to check for yourself.
Now: 2013 Honda CB1100
Then: BMW XMoto, Suzuki SV1000S, Honda 919, BMW XChallenge, Honda FT500, Suzuki GS650E, Yamaha XT500, Kawasaki 500 H1, Yamaha DT175, Suzuki TM125, Suzuki TS100.
Bike#8 is offline   Reply With Quote
Old 03-16-2013, 08:24 AM   #5742
Bli55
Oddometer: 364
Impossible!
Both tubes enter all the way down in the lowest "growth" of the tank, and you can only see so far through the filler neck...
Old 03-16-2013, 02:23 PM   #5743
DESERT SCORPION
SINGLE TRACK
DESERT SCORPION's Avatar
Oddometer: 124
Hot Oil
The parts fiche calls hose #4 the oil return line. I assume this means return to the tank. The long metal line is called the inlet line. Again I assume this means engine inlet (or supply). One might be able to verify this with the heat from the oil returning to the tank from the hot engine. I would try this. From cold, start the engine and feel the heating effect at the two elbows near the bottom of the oil tank during warmup. The one that warms up first and that gets the hottest is the return line from the engine to the tank. Good luck.
THE SCORPION
DESERT SCORPION is offline   Reply With Quote
Old 03-16-2013, 02:59 PM   #5744
Bli55
Oddometer: 364
Oh,of course!!
The simplest things are often the most genious...
The fiche is what also confused me, because part 4 is called return hose...However if would be more logical that the scavenger pump picks up at the bottom of crankcase, which is where pipe 9 goes...
It seems pipe 9 gets warmer first, but access is v. restricted, so hard to tell exactly.
Bli55 screwed with this post 03-16-2013 at 03:35 PM
Old 03-16-2013, 08:41 PM   #5745
Bike#8
Oddometer: 173
Impossible!
You are right. I saw the inflow when I was refilling the tank after a oil change. I did check today and saw oil spitting into the tank from the top tube.
Times are GMT -7.   It's 04:39 PM.
