03-16-2013, 01:23 PM
#5746 |
SINGLE TRACK
Oddometer: 84
Hot Oil
The parts fiche calls hose #4 the oil return line. I assume this means return to the tank. The long metal line is called the inlet line. Again I assume this means engine inlet (or supply). One might be able to verify this with the heat from the oil returning to the tank from the hot engine. I would try this. From cold, start the engine and feel the heating effect at the two elbows near the bottom of the oil tank during warmup. The one that warms up first and that gets the hottest is the return line from the engine to the tank. Good luck.
THE SCORPION |
03-16-2013, 01:59 PM
#5747 | |
Ev.
Oddometer: 69
The simplest things are often the most genious... The fiche is what also confused me, because part 4 is called return hose...However if would be more logical that the scavenger pump picks up at the bottom of crankcase, which is where pipe 9 goes... It seems pipe 9 gets warmer first, but access is v. restricted, so hard to tell exactly. Bli55 screwed with this post 03-16-2013 at 02:35 PM |
03-16-2013, 07:41 PM
#5748 |
Location: Socal=Mt. Laguna & Palomar Mtn.> Now in Idaho Yea!
Oddometer: 156
You are right. I saw the inflow when I was refilling the tank after a oil change. I did check today and saw oil spitting into the tank from the top tube.
Now: 2007 BMW XMoto Then: Suzuki SV1000S, Honda 919, BMW XChallenge, Honda FT500, Suzuki GS650E, Yamaha XT500, Kawasaki 500 H1, Yamaha DT175, Suzuki TM125, Suzuki TS100. |
