Old 07-01-2013, 09:17 PM   #5761
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,429
Originally Posted by SchillerM View Post
What does the clutch lever sensor do? Since adjustable levers seem to be difficult to find for clutch I was wondering about replacing the whole perch. That would mean no sensor though... But I am confused on what it would even do on such a "dumb" bike..
Matt
You won't be able to start the bike unless it is in neutral.
tbarstow is online now   Reply With Quote
Old 07-01-2013, 10:19 PM   #5762
Erik RS
Three Wheel Maniac
Erik RS's Avatar
Oddometer: 457
But it's easily jumpered
Three Wheel Fever forever
Xtankteam™
Proud sponsor of the Sibirsky Extreme Project
Erik RS is offline   Reply With Quote
Old 07-01-2013, 11:34 PM   #5763
john_aero
john_aero's Avatar
Oddometer: 1,173
done bit work to bike last night
still cant sort out the headder hitting shock
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 07-02-2013, 12:05 AM   #5764
Pine Sol
Pine Sol's Avatar
Oddometer: 499
have been experimenting, wanted to lower my foot pegs, i stand 6'10", and standing on the pegs even with my bars raised 2" with Rox risers still wasnt enough.
first i installed scheffelmeiers' skid plate, as i needed to know, how far down i could go. i clamped a straight edge across the back of the skid plate and then measured how much more i could extend my hard parts, sketched out a design, first made it out of 10mm wood, and then when the design was good, i made them out of 10mm ali. for now, i just painted them back, but if they work out, will see about getting them anodized. i know the pics dont show, but the finished brackets are 1mm higher then the bottom of the skid plate
Pine Sol is offline   Reply With Quote
Old 07-05-2013, 02:51 AM   #5765
Pine Sol
Pine Sol's Avatar
Oddometer: 499
spark plug cap?
hello,
i was in the garage tonight, trying to figure out how to pull the cap off of the spark plug. i figure there has to be a trick, better to ask a (what some might think is a) silly question, then to break something trying to find out..
and is there a trick to remove the outside plug? rather then pulling off the air box
thank you
Old 08-17-2013, 03:47 PM   #5766
Akita Man
Optional
Akita Man's Avatar
Oddometer: 114
Considering a used low mile 650 xchallange I found.
I've owned an xr 650 r. Wisconsin is a difficult place to make a bike street legal...so I sold it. Loved it otherwise. Missed estart however.
I was considering a xr650l as they are plentiful in good used shape.
2 questions:
1. How is the xchallange for bigger riders (I am 6'4")?
2. How does the xchallange stack up against an xr650L?
Same weight similar geometry. Air vs liquid cooled newer components on the BMW by 20 years
The bike I found has 5500 miles and is asking $5600. Very clean no Carole's. non abs.
Bikes in my life:
2013 BMW GS Adventure, 2003 XR650R, 2004 KTM Adventure S GO!!!!, 1997 BMW R1100RS ,2004 WR450F,2007 Triumph Rocket III, 2004 WR450F, 2001 Indian Scout, 2004 Triumph T-Bird Sport, 1987 Honda VF1000R
Akita Man is offline   Reply With Quote
Old 08-17-2013, 06:26 PM   #5767
August West
Wharf Rat
August West's Avatar
Oddometer: 552
Originally Posted by Pine Sol View Post
hello,
thank you
You can buy a puller from a dealer. The caps are the coils and, apparently, can be damaged if removed incorrectly. This would be quite costly.
August West is online now   Reply With Quote
Old 08-18-2013, 09:04 PM   #5768
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,429
2 questions:
It will blow the XR away. It is a tall bike, so it should fit you well.
Old 08-19-2013, 04:40 AM   #5769
MizzouRider
MizzouRider's Avatar
Oddometer: 1,775
2 questions:
I'm 6'5" and love it. I have a ohlin shock on the back that adds to its height. Perfect for me. The distance from seat to footpegs seems long, so your knees aren't too bent either. (Good for a old guy.) seat concepts can change the seat over to something you can sit on all day for minimal $$ and quick turn around. I also added a X-Tank, gives it X2 the range..
I may have spent a bit less than $5600, but its been a few years. Not sure how many of them are up for sale though..
IBA#32778 2008 R1200GSA 2007 G650XChallenge
No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..)
MizzouRider is offline   Reply With Quote
Old 08-19-2013, 03:37 PM   #5770
2wheeldog
Adventourer
2wheeldog's Avatar
Oddometer: 18
More on the TT tank
I just put on about 2000k on XC after a couple of years of other bikes. tons of fun!
Put some serious wear on a pair of michelin T63s. both surprisingly good on pavement, the front not so good on gravel trying to have fun.
I wish that I thought of doing a Doc Watson on my XC. Some of the issues to deal with if you opt for the approved method: figuring out how much fuel is left when the reserve light is on. I think its maybe its a half-tank warning. Otherwise you can close off the valves and carry 10K of gas on your front wheel. Not happy with the handling of that, so I leave them open. 2: Its a huge hassle. Don't even use the crappy hose that comes with the tank.
If the Doc's method works like my Safari tank on the 450, all the fuel in the aux tank is gone when the fuel light comes on.
New tangent: Anyone found Silicone rad hoses?
Anyone have a radiator hose fail?
Originally Posted by DrWatson View Post
if you haven't already mounted the TT tank to your bike, don't pipe it the TT way (drilling holes in the original tank etc). Instead run the TT tank to a T piece (mine has quick disconnects near the front and accessible, then a T piece sitting above the oil filter area out of the way, this then goes though a size converter and into the original tank air intake. works great.
this way if you hole a tank, you dont loose all the fuel. just turn the tap off on the holed side. it also sucks all the fule through as it goes to the rear making the weight stay low and rearward as it goes.
reserve will be either the same or more depending on the stop/starts etc. going from memory, i think i have got up to about 90km on reserver but normally it is 50km on the original tank.
If you want to have a deliberate larger reserve, then leave one of the TT taps shut. as long as it doesnt tip over you should get a decent bit of the lobe holding fuel depending on terrain/bumps.
2wheeldog is offline   Reply With Quote
Old 08-26-2013, 12:54 PM   #5771
transworld
Oddometer: 10
Clutch problem?
Hello,
I have been trying to troubleshoot a loss of power when my 2009 xcountry gets hot.
I commute on the bike, and in the hot summer, after being stuck in traffic for a while, the bike always starts acting up. No power, delay in acceleration.
I now suspect a dragging clutch, which is kind of early since I have only 10,000 miles on the bike.
Now, since last week, i have a metallic humming noise on acceleration that started last time i had the loss of power symptoms. Noise disappear when i pull the clutch lever. Difficult to say where it comes from while riding.
I guess my question is, would it be possible the noise would come from the clutch?
The oil I have been using is Castrol 4T 10w40 (http://www.pepboys.com/product/details/9484300/)
Let me know what you think, thanks!
transworld is offline   Reply With Quote
Old 08-26-2013, 01:08 PM   #5772
slide
A nation in despair
Oddometer: 21,122
I think you mean a slipping clutch where the entire power of the engine isn't transmitted to the rear wheel. If so, you should sense the engine is revving too fast for any road speed achieved.
Why be born again when you can just grow up?
slide is offline   Reply With Quote
Old 08-26-2013, 01:30 PM   #5773
transworld
Oddometer: 10
Yes sorry, slipping!
Do you think it could be the source of the noise i am hearing?
Thanks.
Old 08-26-2013, 04:11 PM   #5774
slide
A nation in despair
Oddometer: 21,122
Thanks.
I suppose, but you need to answer if you think the engine is making less power or if the engine is revving more than you think it should for any given speed and gear.
Old 08-26-2013, 04:56 PM   #5775
transworld
Oddometer: 10
Yes, getting worse and worse. New clutch plates are in the mail, but after the noise started, i wondered if the problem was something else.
I have trouble finding the origin of the noise while riding with an helmet.
Feels like coming from airbox but who knows...
Times are GMT -7.   It's 09:06 AM.
