Adventure Rider
Welcome, lurker!   Even if you don't post, the system can help you find the good stuff faster if you register.
Register Members Pics Search Today's Posts Mark Forums Read
Old 05-10-2007, 02:32 PM   #706
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,180
Send a message via MSN to Max Kool Send a message via Skype to Max Kool
I promise to make some pictures this weekend, ok?
Max Kool is offline   Reply With Quote
Old 05-10-2007, 03:00 PM   #707
Oni
Master of Puppets
Oni's Avatar
Oddometer: 1,760
Cool Max Kool!
Just got off phone with dealer. Think I'm pickin' mine up Memorial Day weekend.
Oni is offline   Reply With Quote
Old 05-10-2007, 03:10 PM   #708
lsellers
a DSRIDER
lsellers's Avatar
Oddometer: 1,074
Very exciting
Find out NOW at www.dsrider.com
As you walk, eat and travel, be where you are. Life can only take place in the present moment. If you lose the present moment you lose life itself.
Buddha
lsellers is offline   Reply With Quote
Old 05-10-2007, 04:20 PM   #709
91ctrk
Oddometer: 326
Whats the ready to ride weight on the X's? Seems like a nice DS bike.
91ctrk is offline   Reply With Quote
Old 05-10-2007, 06:01 PM   #710
sweetgrass
Single Track Mind
sweetgrass's Avatar
Oddometer: 50
i really like the bike, was just down at my dealer to order a part for my GS and sat on the X once again.
bad mistake, now i want one, again! but my only complaint with the X so far is the limited fuel capacity. not sure of any aftermarket fuel tank solutions but i think i would need to resolve that issue before taking this bike to baja.
sweetgrass is offline   Reply With Quote
Old 05-10-2007, 11:21 PM   #711
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,180
Originally Posted by Oni
Max
Can you take some pictures? Trying to visualize the covers and air filter setup...and it's not working. Do you think there is a greater chance of ingesting water from splashing during water crossings with the cover off? Think of any downsides to your modification?
The chance of ingesting water in crossing has not changed. The airfilter and the airbox are still completely covered. It's just the duct that's gone. But wait till the pictures, they will explain.
Max
Old 05-11-2007, 02:00 AM   #712
thumperdust
BRRRRAAAAPPP!!!
thumperdust's Avatar
Oddometer: 41
touratech will be offering some, there in new cat.
thumperdust is offline   Reply With Quote
Old 05-11-2007, 02:07 AM   #713
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,180
I've been thinking a while about welding some sort of aluminium side tank that can be bolted onto the right side of the bike. There's plenty of room there. Something like an extra 1,5 gallons would be nice.
The Touratech 16 liter tank looks too bulky for me now.
Old 05-11-2007, 09:51 AM   #714
sweetgrass
Single Track Mind
sweetgrass's Avatar
Oddometer: 50
i've looked on touratech's site and havent found any aux tanks for the X, just for the F650GS.
hopefully that will change very soon.
Old 05-11-2007, 09:54 AM   #715
sweetgrass
Single Track Mind
sweetgrass's Avatar
Oddometer: 50
that could be the ticket!!
Old 05-11-2007, 11:56 AM   #716
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,180
ok, a more pictoral description of what I did to the airbox. Once you see it you will know it's not worth the name "modification".
First you need to remove the seat:
Next we're going to remove the two 4mm hex head bolts and pull the "studs" from their bushing (grease those bushings!). This is more than enough to get access to the airfilter, no need to completely remove the side covers:
Remove the two torx 25 bolts in the front of the faux tank cover (here's where that utterly useless bitdriver I bought to get to my DR's pilot screw comes in handy):
After you've removed the faux cover we're seeing this, the air filter cover alas the inlet snarl silencer (bolts already removed):
And this is the straw the engine has to breathe through, not big izzit?
Let's remove the air filter cover and see what's underneath:
That's more like it! the airbox itself is still completely sealed, the air filter element is snugly in place and if you reinstall the faux cover all is stealth and protected from the elements:
one happy G! Runs crisper and shows more bite that stock.
now that we're making pictures anyway, I thought I'd show you my GPS mount "solution". It consists of seperate Touratech parts. One is a regular holder for my GPSMap276C, the other is some sort of barmount designed to use your GPS on the steering stem of a mountainbike. Together they look like this:
Btw, fitting those barkbusters was hell. The clutch and front brake levers were too long. I sawed them off 2cm's and when we welded the "balls" back on we found out the levers were lacquered or plastified. No ground and once we had ground they badly discolored during the welding. Now that the levers were shorter it seemed that Mr BMW found it a wise idea to lathe the inside of the bars to a size too big for the Magura kit I bought with the barkbusters, but too small for a kit that is used on steel bars. . It looks like the inside is threaded. Of course to make fitting the genuine, not yet available BMW handguards a breeze..... Why mr BMW, why?!! What's wrong with the regular Acerbis/Magura/Barkbuster/Protaper sizing?
Ok, so far this contribution.
Max
Old 05-11-2007, 12:11 PM   #717
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,180
Somewhere around 350lbs. but because of the mass centralisation it feels much lighter once riding than for example a Suzuki DR650, which weighs the same.
Old 05-11-2007, 12:13 PM   #718
jack splash
Two Sheds
jack splash's Avatar
Oddometer: 1,331
Max[/quote]
Max: Cool, I try it own mine this weekend. You don't have to put the balls back on the levers, the bark buster will prevent any issues, once you cut down the levers.
I used the acerbis pro guards and they went on with no problems.
Jack
Pressure makes Diamonds!
jack splash is online now   Reply With Quote
Old 05-11-2007, 12:20 PM   #719
91ctrk
Oddometer: 326
Thanks...lotsa places to ride in holland?
Old 05-11-2007, 12:31 PM   #720
Oni
Master of Puppets
Oni's Avatar
Oddometer: 1,760
Thanks Max!
Nice set up on the GPS too!
vB code is On
Times are GMT -7.   It's 06:09 AM.
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ADVrider 2007
