Old 10-11-2006, 07:01 PM   #1
buffallodan OP
buffallodan's Avatar
Oddometer: 1,709
Aftermarket Parts List for TE-610
Since we have limited availability, but most of the bases covered I thought it would be a good idea to have a thread in the index including all the parts for our 610s.
Please add parts you feel other owners might be interested in with supplier info if possible. Thanks
Fuel Tank:
http://www.imsproducts.com/index2new.html
Luggage:
Rear Rack
http://www.promotobillet.com/shop/item.asp?itemid=120
Panniers
http://www.moto-sportpanniers.com/dirtbagz/index.html
Protection:
Radiator guard
http://www.cycle-analyst.com/DR.htm
Skid Plate
http://www.utahsportcycle.com/utahscFC.htm
Handguards
http://www.brpit.com/pages/products/cycra_hand.html#
Hardware Kits
http://www.desmoparts.com/husqvarna/te610.htm#
Supporting Dealers:
Axle Bolt, Throttle Tube/bearing ,Skidplate/watertank
http://uptiteracing.com/
buffallodan screwed with this post 12-26-2007 at 02:54 PM
buffallodan is offline   Reply With Quote
Old 11-08-2006, 07:49 PM   #2
buffallodan OP
Oddometer: 1,709
Could you guys add your favorite aftermarket parts with a link that I can add to the list? Thanks,
Dan
Note: the IMS tank is not yet available but the Dirtbag panniers are ...
Old 11-08-2006, 08:06 PM   #3
offroute
Oddometer: 357
Dan
My Dirt-Bagz should arrive tomorrow! I don't know if you want a link for OEM parts and special items, but I have been very happy dealing with Dan at MotoXotica.com in Vacaville, CA. He seems to have all the little stuff and has been helping me from stock almost every time. My local dealer stocks nearly nothing, so it was great to find him as a knowledgeable and dependable resource.
2007 KTM 990 Adventure
2008 KTM 450 EXC-R
2005 Honda Elite (just because)
If we don't change direction soon, we'll end up where we're going.
offroute is offline   Reply With Quote
Old 11-08-2006, 08:50 PM   #4
rickf
oldfatguyMAN
rickf's Avatar
Oddometer: 1,695
Anybody know of a large tank for a '01 TE570?
Thanks,
2005 KTM 525EXC, 2006 Triumph Sprint ST, etc., etc.
"Begin at the beginning and go on till you come to the end: then stop."
Originally Posted by rickf
Oh no, Robby's still a pendejo, but he's OUR pendejo!
rickf is offline   Reply With Quote
Old 11-08-2006, 09:27 PM   #5
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,407
A spare engine will be nice, just in case.
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn is offline   Reply With Quote
Old 11-08-2006, 09:39 PM   #6
Fred
Fred's Avatar
Oddometer: 1,051
A spare final drive in your case
Fred is offline   Reply With Quote
Old 11-08-2006, 10:02 PM   #7
Ricardo Kuhn
Oddometer: 12,407
well... I blow up two engines in less than 10,000 milles on my 1998 husky 610
so far i have 300,000milles on the original final drive of the gs
I just hope Italian metalugics got better with the years..
Old 11-09-2006, 03:55 PM   #8
buffallodan OP
Oddometer: 1,709
Well Ricky all I can say is we have a 1year warranty and I will go over 10,000 miles by its experation, so we will know by spring if they hold up any better...
Dan
And Ricky the first 5,000 have been an absolute blast so heres to the next being just as fun without any unwarranted explosions ...
Old 11-10-2006, 03:16 PM   #9
Countdown
Oddometer: 5,772
Any one have a picture of the new IMS tank for the 610?
Jerry Counts
Countdown is offline   Reply With Quote
Old 11-10-2006, 03:42 PM   #10
buffallodan OP
Oddometer: 1,709
There has not been one posted as yet...
D
Old 11-11-2006, 08:04 AM   #11
Fred
Fred's Avatar
Oddometer: 1,051
I saw one at the Dealer's the other day but never thought to take a picture of it. Actually, not sure if it was for the 610 or 510. Nothing spectacular about it. Opaque and bigger.
My riding buddy took out a new 525KTM and then rode the TE450. He bought the TE immediately. This should be fun when I get my 610 as we both own 950 KTMs. Will be interesting to see which bike has the best quality.
Fred screwed with this post 11-11-2006 at 08:13 AM
Old 11-11-2006, 06:33 PM   #12
BikePilot
BikePilot's Avatar
Oddometer: 11,251
averaging 5k miles on a 98 TE610 motor is actually quite good. Its got nothing to do with metals, but rather what the motor is intended to do. The '98 models were still the race style motor, no real oil pump, just relied on the movement of the crank to splash/send oil around. Was light and efficent but didn't lube stuff up all that well. Also the oil wasn't really filtered. The newer and even older dual sport/super moto (first came out in '01 IIRC) were/are totally different - 2 oil pumps are used as well as a sophisticated filtration system.
have fun
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 07-04-2007, 06:01 AM   #13
Magus
Never grew up...
Magus's Avatar
Oddometer: 96
Steering Damper -Sock Tank
I'm a little confused: is there a steering damper option available for the TE610 with the stock gas tank or do you have to go down the IMS route to make one work? Thanks
'13 Honda CBR500
'09 Aprilia RS 125
'06 Ducati Sport Classic
Magus is offline   Reply With Quote
Old 07-04-2007, 07:00 AM   #14
buffallodan OP
Oddometer: 1,709
At this time there is no way a Tower Pin will mount on the 610's if you have a stock tank mounted. We have not confirmed, but think that with the IMS tanks mounted, you should have close to 15mm's of space between the tank and the Top Triple Clamp, that should be enough to get a Scotts Tower Pin installed.
Because the IMS tanks mght allow the Scotts Tower Pin to work, we have tabled the fabrication of a special tower pin that would allow the use of any tank.
We are working on getting precise measurements and also confirming if the PTenduro Subclamp will fit to complete a "kit" for the 610's.
Dan
p.s. I hope thats clear
disclaimer: I stayed up way late partying on the river and am just a bit foggy
buffallodan screwed with this post 07-04-2007 at 07:10 AM
Old 07-04-2007, 07:17 AM   #15
Magus
Never grew up...
Magus's Avatar
Oddometer: 96
Thanks a lot Dan - that was very clear (river partying or not)!
I'd really like to find a damper solution, but don't see myself going to the IMS tank for some time so will need a "stock "solution.
'13 Honda CBR500
'09 Aprilia RS 125
Times are GMT -7.   It's 09:05 AM.
