Old 10-15-2006, 09:18 PM   #1
Gimpdiggity OP
Gimpdiggity's Avatar
Oddometer: 86
KLR650 Performance Numbers...
Alright everyone, I've searched and looked for a while now, and I'm not finding exactly what I'm looking for.
Does anyone know, or know where I can find, the performance numbers for the KLR650.
Things like horsepower, torque, quarter mile times, 0-60 times, wet weight, dry weight...basically just all the "numbers" that anyone would ever want to know about a bike.
I'm trying to compare it to some other things that I am looking at, but I'm not having alot of luck, ESPECIALLY with the performance things like acceleration, power, top end, and braking and such.
Thanks,
Jeff
In Life, Try to be the Kind of Person Your Dog Thinks You Are...
Gimpdiggity is offline   Reply With Quote
Old 10-15-2006, 09:49 PM   #2
Kbetts
Kbetts's Avatar
Oddometer: 1,259
The KLR is not quantifiable by numbers. The uniqueness of it's frame configuation, it's torquey but reliable motor, and it's compliant but high load suspension combine to make the whole greater than the sum of it's parts as the old saying goes.
The best I have available..
The weight is 336 dry, about 370 wet.
0-60 is about 5.4 sec corrected, quarter mile will be in the 15's, top speed is must over 100mph but it takes forever to get there. Horsepower at the rear wheel is around 35 stock at 5000, 38 tuned at 6000. Torque is 35ish at 4000
from Bikez.com
Model:Kawasaki KLR 650
Year:2005
Category:Enduro / offroad
Rating:78.3 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement:651.00 ccm (39.72 cubic inches)
Engine type:Single cylinder
Stroke:4
Compression:9.5:1
Bore x stroke:100.0 x 83.0 mm (3.9 x 3.3 inches)
Fuel system:Carburettor. Keihin CVK40
Fuel control:DOHC
Ignition:Electronic CDI
Cooling system:Liquid
Gearbox:5-speed
More detailsConsult a Kawasaki repair manual.
Physical measures
Dry weight:152.9 kg (337.0 pounds)
Seat height:889 mm (35.0 inches) If adjustable, lowest setting.
Overall height:1,346 mm (53.0 inches)
Overall width:940 mm (37.0 inches)
Ground clearance:239 mm (9.4 inches)
Wheelbase:1,496 mm (58.9 inches)
Chassis and dimensions
Frame type:Semi-double cradle, high-tensile steel
Rake (fork angle):28.0°
Front suspension:38mm leading axle, air-adjustable fork
Rear suspension:UNI-TRAK® single-shock system
Front tyre dimensions:90/90-21
Rear tyre dimensions:130/80-17
Front brakes:Single disc
Rear brakes:Single disc
Speed and acceleration
Other specifications
Fuel capacity:23.08 litres (6.10 gallons)
We're all sheep gone astray
Originally Posted by TrashCan View Post
Hey, this is ADVrider, where facts are not real important.
Kbetts is offline   Reply With Quote
Old 10-15-2006, 09:53 PM   #3
Lizrdbrth
Wackjob
Lizrdbrth's Avatar
Oddometer: 865
Always remember this, Kemosabe....
Kawasaki speak with forked toungue.
Lizrdbrth is offline   Reply With Quote
Old 10-15-2006, 10:01 PM   #4
crazybrit
crazybrit's Avatar
Oddometer: 8,552
Acceleration: poor
Top End: poor
Braking: holy jesus, where is the underwear store.
Fortunately you can mostly solve the last one.
crazybrit is offline   Reply With Quote
Old 10-15-2006, 11:26 PM   #5
elgreen
Crotchety Contrarian
elgreen's Avatar
Oddometer: 436
They don't exist as such, because "performance" and "KLR" don't go together in the same sentence.
A stock KLR puts 34-36 horsepower out the rear wheel. Wet weight is a tad under 400 pounds. Quarter mile times are... uhm, it gets there. 0-60 times are... uhm, it gets there fast enough, that's all I know or care about.
Let's face it, with 34 horsepower, you just aren't going anywhere fast.
As far as competitors go, the Suzuki DR650 has the same power, but is about 40 pounds lighter wet weight. The BMW F650GS is about 50 pounds heavier wet weight, but has about 44 rear-wheel horsepower (a significant improvement). I have never even looked at KTM and etc. because they traditionally have been barely street legal dirt bikes and I haven't had a need for a dirt bike, living as I do in the middle of a metropolitan area of 5,000,000 people where the chances of dirt erupting through the middle of the intersection of El Camino Real and Castro Street is, uhm, nil.
If you need a KLR, there is nothing to compare it to, except perhaps the DR650. At that point physical size becomes the issue -- the DR650 looks like a toy alongside the KLR650, which is why security-sized folks like the KLR650, while runts tend to migrate towards the DR650.
2002 KLR650, 2005 Concours (sold), 2008 Suzuki V-Strom 650 ABS
elgreen is offline   Reply With Quote
Old 10-15-2006, 11:43 PM   #6
crazybrit
crazybrit's Avatar
Oddometer: 8,552
The KTM LC4 640enduro is a fine dual-purpose bike. I wouldn't describe it as a barely legal dirt bike. It reminds me of a more fun more powerful DR650 (well, once well-broken-in so the vibes are tamed). The DR650 is an excellent bike, much better than the KLR. I owned a heavily modified KLR for several years. Utterly unimpressive motorcycle. I sold it and bought a KTM 625 SXC.
Old 10-15-2006, 11:55 PM   #7
Speaker
What's an estart?
Speaker's Avatar
Oddometer: 888
Funny, I sold my DR650 to buy a KTM 620 SX.
Speaker is offline   Reply With Quote
Old 10-16-2006, 02:37 AM   #8
Royal Tiger
Pz VI B, Sd Kfz 182
Royal Tiger's Avatar
Oddometer: 1,383
Kbetts, can you find the "numbers" for my KLX650? Thanks.
2013 Yamaha XT250 * 2005 BMW R1200ST
Royal Tiger is offline   Reply With Quote
Old 10-16-2006, 05:52 AM   #9
Kbetts
Kbetts's Avatar
Oddometer: 1,259
Sorry, couldnt find them available online. There is a reprint service available for little that will give you all the articles on the model at.......
http://www.mcreports.com/Pages/Indivbikes/Kawasaki/KLX650.html
Data shows the HP/kg for a KLR at .25 , 93 KLX at .331, 95 KLX at .294. Compare with the KTM LDC4 Adv at .3182 which makes better power at the top end. There are lots of other factors, but hp/weight seems to be the closest in my experience. Any way you look at it, the KLX is a fast bike.
I did find some info that made the magazine test numbers worthless because the performance will be much better after the modification that the magazine 0-60 and quarter mile times wouldn't reflect the bike....
http://www.off-road.com/dirtbike/rick/dntask0599.html
May 99
DON'T ASK!
YOU GOT QUESTIONS? WE'VE GOT ANSWERS, BUT DON'T SAY WE DIDN'T WARN YOU
BY RICK "SUPER HUNKY"SIEMAN
** KLX650 Rick, I have just bought a 93' Kawasaki KLX 650 R and have some questions re: exhaust. I want to be able to ride in the National Forests of Colorado and we are required to have a USFS approved muffler. I don't believe the stock exhaust is compliant, or at least it doesn't have the USFS stamp on the muffler. If I can use the existing exhaust, that would be great, but do not know how to find out if the stock exhaust is compliant or not. If it is not, I would like to increase the horse power and lighten the bike by adding an after market exhaust. Any recommendations? Brian Wells Here’s the deal on the ’93 model of the 650. It came with a legal spark arrestor, but there was a small baffle in the pipe that absolutely strangled the power. Everybody removed the baffle, and it made the bike run great. With that baffle in place, and the lid on the air box, the bike was a real pig. Note: if you do have a bike with the baffle removed and the airbox lid off, it must be re-jetted, or it’ll run way too lean. Try a 158 main jet, and a 01B38 needle jet nozzle, and while you’re at it, move the needle position to the fourth slot from the top. I don’t know if removing the exhaust baffle destroys the legality of the spark arrestor, (I suspect it does not), but it does make the bike a bit louder, though not objectionable. All things considered, the stock muffler is heavy, and replacing it with a White Brothers unit is probably the way to go. Forget hopping up this bike, as it had tendency to run hot at slower speeds. Spend the hop-up money for later model (larger) radiators before you do anything else to the machine. **
Bikez has the following:
General information
Model:Kawasaki KLX 650
Year:1993
Rating:79.4 out of 100. Show full rating and compare with other bikes
Stroke:4
Power:48.00 HP (35.0 kW)) @ 6500 RPM
Torque:51.98 Nm (5.3 kgf-m or 38.3 ft.lbs) @ 5000 RPM
Valves per cylinder:4
Gearbox:5-speed
Physical measures
Dry weight:145.0 kg (319.7 pounds)
Seat height:885 mm (34.8 inches) If adjustable, lowest setting.
Power/weight ratio:0.3310 HP/kg
Fuel capacity:12.00 litres (3.17 gallons)
Numbers are different for the 95 (because of the R model ???)
General information
Year:1995
Rating:72.7 out of 100. Show full rating and compare with other bikes
Stroke:4
Power:45.00 HP (32.8 kW)) @ 6500 RPM
Torque:52.00 Nm (5.3 kgf-m or 38.4 ft.lbs) @ 5000 RPM
Gearbox:5-speed
Transmission type
final drive:
Chain
Physical measures
Dry weight:153.0 kg (337.3 pounds)
Power/weight ratio:0.2941 HP/kg
Kbetts screwed with this post 10-16-2006 at 06:31 AM Reason: add info
Old 10-16-2006, 06:13 AM   #10
Hannda
Short, fat, bearded, slow
Hannda's Avatar
Oddometer: 28,147
Run a search in KLR Stories. Some of the information you seek has been posted there - top speed per gear, results of dyno tests, etc.
Hannda is offline   Reply With Quote
Old 10-16-2006, 07:08 AM   #11
Royal Tiger
Pz VI B, Sd Kfz 182
Oddometer: 1,383
When I bought mine, the PO said it was around 55 or so as it has a stage 2 Mikuni on it and a supertrap. I wasn't sure when I saw the KLR at 35. Thank you.
Old 10-16-2006, 10:18 AM   #12
nashopolis
nashopolis's Avatar
Oddometer: 716
another source for klr #'s
I don't have it handy, but MC consumer news did a KLR review a month or two ago ....it had all the numbers you seeks...
I'll look and see what issue it was tonite
nashopolis is offline   Reply With Quote
Old 10-16-2006, 11:40 AM   #13
swjohnsey
Oddometer: 3,568
Some of the figures posted aren't very accurate. Weight of a stock KLR650 with full fuel is around 415 lbs. A stock KLR650 will probably never see 100 mph unless it is down hill and with the wind because of the gearing.
swjohnsey is offline   Reply With Quote
Old 10-16-2006, 01:29 PM   #14
elgreen
elgreen's Avatar
Oddometer: 436
??? Where do you get this? I know a guy who has a full tricked out KLR with all the heavy engine guards and stuff, who works at a commercial trucking company. He put his bike on the scale with a full tank and it weighed 405 pounds. I'd suspect that without the 10 pounds of guards and stuff it'd be around 395 pounds. Hmm, maybe he took the stock muffler off and replaced it with an aftermarket muffler, that'd be 10 pounds right there :-).
-E
Old 10-16-2006, 02:45 PM   #15
ADVMax
Sporting Foole
ADVMax's Avatar
Oddometer: 32,712
Simplest explination - it's a 650cc, twin cam, 4 valve Briggs and Stratton!
There is absolutely NO EXCUSE for what I'm about to do!
The Second Amendment - it ain't about duck hunting.
You heatherns needs some churchin up - http://www.landoverbaptist.org/
ADVMax is offline   Reply With Quote
Times are GMT -7.   It's 12:34 AM.
