Old 10-20-2006, 06:24 PM   #16
BikePilot OP
BikePilot's Avatar
Oddometer: 11,251
Looking great
I like what you did with the seat, I need to do something similar to mine. Did you replace the entire foam section or add another layer to the top of the stock stuff?
Thanks,
Josh
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 10-20-2006, 06:43 PM   #17
Twistir
Must have plow experience
Twistir's Avatar
Oddometer: 42
Originally Posted by BikePilot
Looking great
The foam came from the local fabric store. Its a dense foam used for seat cushions.
I took that and the exisiting seat foam...sprayed them both with adhesive and got a good bond. Then I just trimmed off the new foam to match the seat.
The difference is night and day, I have not had any saddle sore yet
The seat really does not sit much higher, but for me having long legs it still helps. That combined with the bar risers make for a comfortable ride.
Nice ride report BTW!
Twistir is offline   Reply With Quote
Old 10-20-2006, 06:46 PM   #18
BikePilot OP
BikePilot's Avatar
Oddometer: 11,251
Awsome, I might have to look around for some of that dense foam myself. I'm not worried about adding height, in fact I'd like to (I'm used to MX bikes that are a good bit taller) add a bit of seat height to make for a bit less of a bend in my knees.
Old 10-20-2006, 07:06 PM   #19
Twistir
Twistir's Avatar
Oddometer: 42
Here's a link to the foam that I used. and it is available from less than an inch to 3" thinkness, I believe.
http://www.joann.com/catalog.jhtml?C...6&PRODID=81585
Old 10-21-2006, 01:20 PM   #20
Rotor-head
Oddometer: 51
Thumb
Long time lurker and now finally joined so I can chime in on some of this fun stuff.
Several months ago, I decided to look for a DR650 to join my Weestrom in the garage. After searching for what seemed like forever and only finding old worn out bikes or ones with top dollar prices I was about to give up on an inexpensive dual sport. Just then, I stumbled upon a '97 DR350SE with low miles and a brand new set of tires for really cheap. Seems that an older guy bought one for his married daughter to ride with him, but unfortunately he passed away, so the bike was pushed into the garage and hadn't been riden in the past 2 years. Price was low so I bought it and took it home. Needless to say it really didn't run too well. Carb was gummed up and the gas was old.
I decided to tear the bike down short of removing the engine from the frame and clean, lube and replace as required as much a I could. It was actually kinda fun doing all the work and witnessing the change in the bike. Here is what I did:
  1. Kientech carb (new main jet, needle and idle screw) and muffler mod, absolutely the best $100 spent on the bike!!!
  2. Opened up the airbox and new filter to go with 1
  3. 14T countershaft sprocket
  4. EBC brake pads and flushed the brake system
  5. Pro Taper bars with Tag grips
  6. Acerbis ralley guards
  7. Seat recovered in black Carbon FX by Sargent (they did a great job and price was good, about $100)
  8. Sandblasted the muffler after Kientch did the mod and painted it with high temp stove paint-black
  9. Rebuilt the forks with 15wt oil and new black boots
  10. Removed the stickers from the side plates and cleaned all the plastic
  11. Luggage rack from the guy in Ohio (Brian S) who mods the stock fender support - nice work...
  12. Cleaned and lubed everything that moved including the cables
It is now back on the road and running great. The carb and muffler mod are a must do, the bike repsonds much quicker and smoother to throttle inputs and muffler is still civilized. HIGHLY RECOMMENDED! I bet the DR250 will benefit from this also.
Not sure how to post pics yet, but if I figure it out I'll post before and after pics.
Must go out tomorrow for a little shakedown ride......
Rotor-head is offline   Reply With Quote
Old 10-22-2006, 07:05 PM   #21
BikePilot OP
BikePilot's Avatar
Oddometer: 11,251
Sounds awsome! I would like to add the pumper carb to my 250 sooner or later, have never liked CV carbs.
have fun with it and post up some pics
Old 10-26-2006, 06:51 PM   #22
walkingbear
walkingbear's Avatar
Oddometer: 3,501
DR 350..noob
just purchased my DR350S for $200..figure I need to put a little work on it.
It was a theft recovery.. kids next store stole bike.. sprayed painted it alum. so I'm gonna take some steel wool to get the paint off.
Need a new battery/spark plug/ oil change and clean the air filter.
ANYTHING ELSE>>>> is there a manual online anywhere?
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is online now   Reply With Quote
Old 10-26-2006, 07:00 PM   #23
Hannda
Short, fat, bearded, slow
Hannda's Avatar
Oddometer: 28,041
Originally Posted by Twistir
Next comes the rear rack from happy-trails and either a tailbag or case from JCWhitney.
http://www.all-pelican-cases-4-less....ican_1450.html
Hannda is offline   Reply With Quote
Old 10-26-2006, 09:25 PM   #24
Pumpkinhead
Professional Azzhole
Pumpkinhead's Avatar
Oddometer: 562
My bike came with this manual. It covers just aboout everything.
http://www.themotorbookstore.com/suzdr19.html
Clarke tank
RMX swingarm and RM 125 forks...soon to be installed.
My DR is more fun than my FZ.
Dave
1994 DR350
1996 DR650
2012 Triumph Tiger 800 XC
Pumpkinhead is offline   Reply With Quote
Old 10-28-2006, 01:05 PM   #25
steve gs
steve gs's Avatar
Oddometer: 375
Picked this pup up about a month ago. Received airbox mod, FMF Power Core IV, and previous owner followed Jesse"s instrctions and had it jetted spot on. Noise is a bit too high so I have the OEM exhaust piece on the way to Jesse for rework.
Nothing like that 6spd trans to expand the flexiblity of the machine. So far I prefer this bike to my F650GSD in being over 100 lbs lighter, and lower tech with less to go wrong and easier to service. Just need to add a larger tank to extend the range.
Any other DR riders here in SE Michigan?
steve gs is offline   Reply With Quote
Old 11-10-2006, 10:10 AM   #26
H2OKarensa
Free Range Chick
H2OKarensa's Avatar
Oddometer: 48
My old DR350
Me and My DR350 on our recent Copper Canyon adventure.
Mods? 2 inches lower for my short a$$ legs. Pink handlebars. Silly welded rear rack for last minute tailbagging. That's about it.
This bike will take me anywhere!!!
H2OKarensa is offline   Reply With Quote
Old 11-10-2006, 10:30 AM   #27
BikePilot OP
BikePilot's Avatar
Oddometer: 11,251
Awsome Shot
Old 11-11-2006, 04:14 PM   #28
PK
Oddometer: 491
I picked up my 93 DR350S almost 2 years ago. $800. Stock as stock could be.
With a whopping 2500 miles!
PK is offline   Reply With Quote
Old 11-11-2006, 04:19 PM   #29
PK
Oddometer: 491
It needed help in a few areas, so it got the following:
Clarke 4.2 gal tank
Pingle petcock
Eibach springs front and rear
Kouba links
Jet kit and Jesse modified muffler
Still needs:
Some newer and smaller front and rear fenders
Pumper carb if I can find one
It's a really fine older DS bike. Cheap, reliable, crashes into trees and other riders quite well!
Old 11-13-2006, 02:44 AM   #30
Oaters
Oaters's Avatar
Oddometer: 650
Cool2 new to dr 350's - from new zealand
hi - here's my '99 dirt model - 'kicker' with the pumper carb - completley stock from what i can tell - travelled 11,000kms. Rode it home from a town some 400km from where i live. Have ridden it in a forest near my home and had lots of fun. A lot easier to ride than my 1150GS which I find is a great gravel road bike but a handful in tight off road stuff. Cheers Aslan
Oaters is offline   Reply With Quote
Times are GMT -7.   It's 03:50 PM.
