Old 10-25-2006, 06:16 AM   #1
boother OP
Oddometer: 227
Factory lowering a DR650
Has anyone performed the factory lowering themselves. Looking at the service manual, it does not look difficult. There are several special tools listed but the only one I think you would have to have is the "T-handle" to loosen the bolt down in the forks. Can anyone tell me what that tool really is? What is on the end of it? Square drive? Torx? PN 09940-34520. The rest of the "special tools" look like I can find an alternative.
boother is offline   Reply With Quote
Old 10-25-2006, 07:46 AM   #2
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 3,946
Thumb
I did it for my buddy last week and I'll be doing it to my new to me '05 DR650 that I pick up tommorow.
I have a 1/2" x 1/2" x 20" piece of square steel rod that I tapered on one end and it works great. Sure you could buy the Suzuki special tool but mine works on any damper rod type fork and yours could too.
I've also made one by grinding down a 1/2" drive impact extension. Just use a damaged or cheapie 1/2" drive impact extension and grind the part that goes into the socket down to a tapered end. I've heard of people using broomsticks but I've never tried it myself. Easy and cheap enough to try if you dont have any other materials available.
Loosen the top fork cap before you remove it in case you dont have a vise.
Remove the fork leg from bike, then try to loosen the bolt (8mm allen) on the very bottom of the fork. This bolt holds the damper rod in place. It might come loose with the tension of the fork spring holding the damper rod but dont count on it, there isnt very much tension in these forks.
If the lower bolt just spins & spins but doesnt start coming out, then remove the upper fork cap, preload spacer, washer, then fork spring. Lay those to the side on a clean surface then dump out the fork oil. Now it's time to stick whatever tool you fabricated down the fork tube into the damper rod and your tool will hold it in place while you remove the 8mm damper rod screw. Pretty easy.
Now if you're going to lower the front, slide the top out spring off the damper rod. Take the preload spacer you remover earlier from the top and slide it onto the damper rod. Now put the top out spring back onto the damper rod. Insert your fabricated tool into the damper rod and slide it back into the fork. Attach & tighten the damper rod, then fill your forks with fork oil.
I used ATF and filled it 5 & 1/2" from the top of the tube with the fork fully collasped. This was purely experimental and works great according to my buddy who owns the DR I'm talking about. Use whatever oil you prefer, and what fork oil height suits you.
Extend the fork, drop the spring in, then the washer & cap it off. Done. Now you get to do it to the other side.
Note: you can add another preload spacer, or washers for additional preload if you wish. I added 3 flat washers I had laying around. That was maybe a 1/4" of additional preload.
My buddy says the front feels great, and it made the soft rear that much more noticeable.
Lowering the rear is easy enough, choose the bottom bolt hole on the lower shock mount. If it's not low enough, remove the shock, remove all the preload from the shock spring, remove the spring, then remove and flip the shock spring seat and this will provide you with the complete Suzuki lowering option.
Dont forget, you're going to need a shorter kickstand. I cut 2" of it and had it welded back up. Works great.
HTH
Lil' Steve is offline   Reply With Quote
Old 10-25-2006, 08:19 AM   #3
boother OP
Oddometer: 227
So it is a square drive tapered down from about a 1/2". Cool! Thanks from the help.
Old 10-25-2006, 08:44 AM   #4
slideways
permanent ex-pat
slideways's Avatar
Oddometer: 5,626
If you have an air impact wrench you can normally spin the bolt out of the bottom of the fork tube without having to use a tool to hold the dampner rod.
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
Upper Italian Lakes report.
http://www.advrider.com/forums/showthread.php?t=160841
South Africa, Swaziland, Botswana ride report
http://www.advrider.com/forums/showthread.php?t=454490
Great CanAm Tour
http://www.advrider.com/forums/showthread.php?t=476605
slideways is offline   Reply With Quote
Old 10-25-2006, 12:15 PM   #5
FatChance
Road Captain
FatChance's Avatar
Oddometer: 10,229
Just move the fork tubes up about an inch in the triple clamps. Much more easier.
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance is offline   Reply With Quote
Old 10-25-2006, 12:31 PM   #6
street rider
Grow old not up
Oddometer: 295
I slid the fork tubes up an inch and 1/4, changed bolt holes on the rear then added Suzukis lowered gel seat. I'm short and it worked great. It was easy too.
[U]His 11 G650GS, 14 streetglide
Hers 12 Burgman 400, 14 Switchback
Project 78 FLH
Before you can be old and wise you must first be young and foolish, and live thru it.
street rider is offline   Reply With Quote
Old 11-13-2006, 10:55 AM   #7
DLdeano
Ridin' all I can
DLdeano's Avatar
Oddometer: 949
Is there any trick to lowering the back?? It looks straight forward, but I do not have a manual as of yet, but want to get the bike lowered by the weekend.
There is a small metal tab partially covering the second rear shock hole...how do I get it out of the way?? When I ordered the sidestand this morning, the guy at the shop said there were a few other parts with it...so if somebody could briefly outline this process for kme that would be awesome. Thanks.
DLdeano is offline   Reply With Quote
Old 11-16-2006, 10:35 PM   #8
Basher
Basher's Avatar
Oddometer: 152
I picked up an 06 DR650 Friday and with a 27" inseam there was no way I was touching even a toe to the ground. So my buddy and I brought her into the living room and took the bolt out the bottom of the shock. Then we had a hell of a time getting it back in the higher hole(Lower setting) but finally got er back together but still a little on the high side. Loosend all 6 bolts on the fork and lowered the front end a good 1-1/4. Hudge differance I actually felt allot better bout the bike. Like street rider said, it works great and easy. Just ordered the Gell seat and with that I just may be able to put a heel down. I'm currious what he did about his kickstand. VFR870 said cut 2" I'm only cuting 5/8" out and am concered it will be too much. It will stand up right on flat pavement so don't THINK it needs much.
Basher is offline   Reply With Quote
Old 11-16-2006, 10:56 PM   #9
viverrid
not dead yet
Oddometer: 30,482
Originally Posted by Basher
...I'm currious what he did about his kickstand. VFR870 said cut 2" I'm only cuting 5/8" out and am concered it will be too much....
Can you bend the kickstand instead? That's what I did when I lowered a different bike for my wife. Would have been smoother to heat it, but I just did it cold. Removed it from the bike, layed it between two somethings, and hit it with a 2-lb. hand sledge. Then later when we sold the bike and it had been returned to stock height, I straightened the kickstand in a similar way.
Advanced pancreatic cancer found 04/2010. Have outlived +/- 97% of patients with this diagnosis, but 08/2013 cancer now in liver, vascular system and lungs with 20+ lung tumors. Sick/weak sometimes, not riding much. No more treatments & now under Hospice care.
viverrid is offline   Reply With Quote
Old 12-03-2006, 08:08 AM   #10
drnova
Oddometer: 120
Has anyone had the front wheel hit the fender on full compression after lowering the front end by sliding the fork tubes up in the clamps? I am curious why the factory recommends removing the pre load spacer and placing it on the top-out spring position if it would be easier to just drop the front on the clamps.
drnova is offline   Reply With Quote
Old 12-03-2006, 09:01 PM   #11
ram1000
ram1000's Avatar
Oddometer: 1,832
I ride my wifes DR lowered by sliding the forks up and have not noticed a problem hitting the fender. It really doesn't make sense that it would clear though. You can measure the travel left after lifting the front end off the ground measure from the top of the wheel to the bottom of the fender. If there is 10" or so your ok. I would guess the travel is actuallu a little less than advertised.
ram1000 is offline   Reply With Quote
Old 12-03-2006, 09:59 PM   #12
doger300
kiwi adventurer
Oddometer: 21
I use a 1"x1" wooden stick. Mine is a piece of rough sawn 1" garden stake. Cost - about 50 cents. It will slide comfortably (without a lot of clearance) inside the fork tube. A few taps on the end pushes it into the socket on the top of the damper rod.
doger300 is offline   Reply With Quote
Old 06-08-2010, 09:18 PM   #13
basketcase
lifelong reject fixer
basketcase's Avatar
Oddometer: 1,414
I've been reading all this with some interest and wonder if anyone has an exploded view of the damper rod and other components?
A picture is worth a thousand words ... ect. et. al.
'00 BMW R1100RT, Gone away: 5 previous BMW's, 3 Honda's, 2 Suzuki's
"The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." - Marcus Aurelius
basketcase is offline   Reply With Quote
Old 06-09-2010, 04:52 PM   #14
GetYourOwn
Oddometer: 790
I am looking to take my 06 DR650 back to stock height and before I take my forks apart does anybody know what the size of the spacer is that you remove when lower the forks. I don't think the previous owner included it in the box of parts he gave me.
On a related note anybody have standard height forks and want to trade for lowered forks.
GetYourOwn is offline   Reply With Quote
Old 06-09-2010, 06:51 PM   #15
basketcase
basketcase's Avatar
Oddometer: 1,414
I have a set of Eibach springs to install when I get around to it, so after a good bit of reading and meditating I think I'm going to just raise my forks 1.25 inches in the triple clamps.
The spring swap is simple and straight forward, and the stiffer springs will lessen the chance of me bottoming out the front suspension. So I'll be electrical about it and flow in the past of least resistance.
Times are GMT -7.   It's 04:01 AM.
