Old 10-27-2006, 09:48 PM   #1
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,282
Question Twinmax hook up
I've just bought a twinmax and I want to synch the carbs on my R80GS Basic. I've found some good info on the procedure, but I have no idea where to hook up the vacuum hoses on the Bing. It must be so obvious that they haven;t bothered to mention it. Could someone please make it obvious to me as well.
Thanks.
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 10-27-2006, 11:57 PM   #2
woodgrain
In-Dented Savant
woodgrain's Avatar
Oddometer: 757
Wink
I have a 1983 R80G/S, and I think the Basic uses the same carb set up.There should be two biege coloured hoses coming out of the air cleaner, between the air cleaner cover and the actual block-towards the rear. These are connected to the carbs(vacuum tubes). Just follow the hoses until you find where they connect to the carbs and pull off that hose and replace with the hose from your Twin-Max.Voila! I hope this is what you were looking 4.
Woodgrain
woodgrain is offline   Reply With Quote
Old 10-28-2006, 12:28 AM   #3
rowansride
recreational menace
rowansride's Avatar
Oddometer: 164
look on the bottom of the carbs, there should be a little metal tit on the bottom of each carb with a vacum cap or a tiny machine screw capping it. If You still have the PAS system, You should shitcan all of it. Easy to do, and The easiest weight you'll ever shave.
rowansride is offline   Reply With Quote
Old 10-28-2006, 03:01 AM   #4
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,282
Thanks you guys, I suspected that might be it, but I wasn;t sure.
R1150GS
R80GS Basic
Old 10-28-2006, 05:34 AM   #5
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,451
If it helps with the help of a fellow whose thing is carbs and induction we worked up a twinmax procedure. It's here. JT
http://wisconsin.airheads.org/content/view/33/51/
jtwind is offline   Reply With Quote
Old 10-28-2006, 12:25 PM   #6
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,282
JT, thanks for that. I had found this procedure after a search.
3. Hook up the twin max, turn it on and increase sensitivity to max and
adjust the needle to center. You can then turn down the sensitivity back
down all or part way and turn unit off.
It didn't say where to hook it up to . There was no email address for me to ask. I will follow it now that I know where the hoses go.
R1150GS
R80GS Basic
Times are GMT -7.   It's 09:06 AM.
