Old 11-08-2006, 11:13 AM   #31
the_gr8t_waldo
Oddometer: 2,107
i was at a local motorcycle dealer about two weeks ago, and out in the used bike herd was a klr650 with a pair mounted! i've always been interested in them as hard pantires. i have to say they looked great! imho, they look much more adventuresome that the zega boxes i now have. now i'm toying with the idea of buying a pair and modifying them, with an eye to selling my current ones- guys please don't contact me about buying them..thanx. as for the small internal canisters, camping stove and some food or maybe have them caped off and use them for extra fuel canisters( maybe straped on the rear?)
the_gr8t_waldo is offline   Reply With Quote
Old 01-13-2008, 12:01 AM   #32
hoyks
Tightass KLR rider
hoyks's Avatar
Oddometer: 810
I have seen those boxes around at disposal stores too, never thought of turning them into panniers. I will have to see if I can get my hands on some.
I hated the sight of the things as it always indicated that we would get crappy 1/2 cold mess food while out bush .
In the Australian Army, they are generally known at 'Hot Boxes'.
hoyks screwed with this post 01-13-2008 at 01:43 AM
hoyks is offline   Reply With Quote
Old 02-22-2008, 04:11 PM   #33
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,231
I just sent for a rough pair of these. If they're aluminum, as they appear to be, I'm going to sandblast and clearcoat them. I'll post with updates when I get them and start the gutting process. In the meantime, can someone tell me where I can get the mounting hardware that makes these secure yet removable? I need both the part that goes on the box, and the part that goes to the rack since I'm going to be fabricating my own rack. I'll document the whole process for your viewing pleasure.
1982 4x4 longbed, a rolling daily driver work-in-progress...
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 03-15-2008, 11:21 PM   #34
LMJ
Faceplant in progress
LMJ's Avatar
Oddometer: 822
Pilot, thank you for posting this. My pannier hunt just got much cheaper and more interesting.
LMJ is offline   Reply With Quote
Old 03-16-2008, 09:50 AM   #35
Zombie_Stomp
Aspiring human
Oddometer: 2,231
Glad we have another participant in the home fabricated pannier thread. I thought this thread had gone dormant. Good news, I got mine in. I got what I paid for at $50+ shipping, they're pretty dented but it's good that you can easily exchange lids. I'm going to gut mine this weekend.
Old 03-16-2008, 10:18 AM   #36
Zombie_Stomp
Aspiring human
Oddometer: 2,231
Then I need to fabricate a rack using some ideas from the post your pics of xr650 L racks and bags thread.
I like forrestbault's rck on page 3. Check out the thread^.
Old 03-16-2008, 12:52 PM   #37
oio
oio's Avatar
Oddometer: 498
Here are some more ideas for penny-tech panniers.
Note the innovative soft-bag hanging off the handlebars!
Triumph Tiger 800
oio is offline   Reply With Quote
Old 03-16-2008, 01:19 PM   #38
the_gr8t_waldo
Oddometer: 2,107
as far as securing then to a rack, i liked my klr mountings. the rack had threaded holes on the rack. all i did was put 4 bolts from the inside of the box into the threaded holes each side. i placed a large square washers on the inside to spread out the load. useing one of the wrenches in my tool kit, it was tightened down. no one could get to the bolt heads with out opening the boxes. and the protruding bolt heads were not a problem, like you'd think they would be.
Old 03-17-2008, 12:09 AM   #39
Zombie_Stomp
Aspiring human
Oddometer: 2,231
I gutted mine today. I used about 4 fiberglass reinforced Dremel cutoff wheels and one and a half 4-1/2" angle grinder wheels. I cut the inner lining about an inch and a half below the inner gasket lip to preserve the strength of the gasket/lip watertightness when clamping the cans shut. Then, after the perimeter cut, I cut the inner can into 4 pieces and they pried out easily. then, scraping the foam out took for ever and was a huge pain. You only do this once, I kept thinking. The foam leaves a residue on the inside that must be scraped out, and can't quite all be scraped clean, as you can see in the photos. I'm going to see if the last of the residue can be sandblasted off when I go to get the outsides of my cans blasted. I'm going to then clearcoat them as I said earlier. The first guy I gave them to for blasting only got one side of one of the cans done, and said it took 2-1/2 hours to get that far, so he stopped before billing me at that rate. He says they're sprayed with some kind of chromate etching primer that is super hard to get off. So now it's off to the othe guy he recommended with an actual SAND blaster as opposed to the fine glass bead he has in his blasting cabinet. I might go back to the first guy just for a finish blast before the clear coat.
Zombie_Stomp screwed with this post 03-17-2008 at 12:14 AM
Old 06-05-2008, 04:59 AM   #40
Air0ne
Adventure reader
Air0ne's Avatar
Oddometer: 163
BMW F800 GS 2009
Ckeck out my ride reports
Air0ne is offline   Reply With Quote
Old 06-07-2008, 08:00 PM   #41
interceptorpilot
Modern Nomad
interceptorpilot's Avatar
Oddometer: 13
Puke
oh BTW I was a food Svc specialist in the US Army and mermites should have a few holes on the outside to prevent the insulation from swelling and ruining the can...
Where I lay my head is home...
interceptorpilot is offline   Reply With Quote
Old 06-08-2008, 12:22 AM   #42
RSL
Oddometer: 4,360
Perhaps you guys should look into ultralight backpacking, or read and heed the words of Ray Jardine. Google for such. It seems that some in the backpacking crowd have whittled their gear down to a total of 5 or 10 lbs.
Adaptation of such weight savings and compact equipment would obviate use of all of this clunky stuff on a motorcycle.
More aerodynamic packaging would not hurt, either. Some of the pics posted seem to be in a contest for who can make the heaviest, draggiest motorcycle on the planet. Just sayin.'
All that extra weight and bulk cannot be helping your handling or fuel economy, either.
RSL is offline   Reply With Quote
Old 06-08-2008, 01:30 AM   #43
Zombie_Stomp
Aspiring human
Oddometer: 2,231
Which is the clunky stuff? I think the Mermites, when fully gutted including the insulated lid, are pretty damn light. Have you ever held one? The main point is CHEAP. I CANNOT afford a $700 set of hard panniers. Or $200 for that matter. That said, I'll look into your suggestion of looking up that guy's writings, as I can always look forward to new info.
Old 06-08-2008, 04:19 AM   #44
Grinnin
Forever N00b
Oddometer: 2,713
So show us your camping setup on the MC and off.
Ray probably doesn't spend all day with 70mph winds. I can easily hit 10 Lbs on a day trip if the weather starts cold, turns hot, and may rain at any time. I'm including the tools in that weight. For camping, my gear is fairly bulky but not heavy. That said, my next trip will see me carrying 30 or 35 Lbs for camping plus a city visit.
EDIT: Oh, and I'm taking a quart of Maine maple syrup to my Dad and bringing home a few yards of that really heavy coated nylon that's been in his basement. Sounds like about 40 Lbs.
Motorcycles are magical.
Grinnin screwed with this post 06-08-2008 at 04:45 AM
Grinnin is offline   Reply With Quote
Old 06-08-2008, 09:42 AM   #45
Zombie_Stomp
Aspiring human
Oddometer: 2,231
These stick out too far, but worth posting. He's got a nice shine on them. Mine are in a rough finish, having been recently blasted with real sand. I need to bead blast and then polish or clearcoat, most likely trhe latter. Then I gotta build a yoke to throw over my rack to put them on that is as close in board, forward, and low as possible. Pics to follow.
Times are GMT -7.   It's 01:38 AM.
