Old 11-04-2006, 02:04 PM   #1
snaggleXR650 OP
Oddometer: 244
counting chain links?
I need to determine the length of chain on my '04 625 SXC. Do you count the rollers or side plates or what? Thanks for the information.
snaggleXR650 is offline   Reply With Quote
Old 11-04-2006, 02:15 PM   #2
dirtypumpkin
"Monster Truck Bike"
dirtypumpkin's Avatar
Oddometer: 13,972
Side plates.
Give big space to the festive dog that makes sport in roadway.
Avoid entanglement of dog with wheel spokes. - Old Honda Manual
If you wish to travel far and fast, travel light. Take off all your envies,
jealousies, unforgiveness, selfishness, and fears. -- Glenn Clark
dirtypumpkin screwed with this post 11-04-2006 at 04:45 PM
dirtypumpkin is offline   Reply With Quote
Old 11-04-2006, 04:01 PM   #3
OldRider 125
OldRider 125's Avatar
Oddometer: 571
Originally Posted by kawidual
Side plates.
One rule of thumb someone from sprocket specialists
told me was add your sprocket teeth total then x2.
Stock DRZ for example
ie - 15+44=59, 59x2=118 links
Count your sprocket teeth and multiply by 2.....I think they were bullshiting you !!!! The sprockets don't know how far it is between them.
To get the proper chain, count the rollers or I think it's easier to count the plates (master link too) then multiply by 2.
A 120 link chain has 120 rollers.........
OldRider 125 screwed with this post 11-04-2006 at 05:25 PM
OldRider 125 is offline   Reply With Quote
Old 11-04-2006, 04:45 PM   #4
dirtypumpkin
Oddometer: 13,972
To get the proper chain, count the rollers or I think it's easier to count the plates (master link too) then divide by 2.
I remember them emailing me that Id need one link per tooth as a starting point.
I was asking about making a gearing change when I emailed them for length.
After looking it up the stock DRZ chain in 112, so that method isnt that great.
Last I fit was a 116 to run a larger rear sprocket.
Forget the method they told me, going to delete that bad advice...
This is in their chain info on the site, no mention of that other advice they emailed me.
HOW TO COUNT LINKS
Every pair of sideplates (both inner and outer) counts as one link. Chains always have an even number of links.
Old 11-04-2006, 05:01 PM   #5
Bayou Boy
Bayou Boy's Avatar
Oddometer: 1,685
The above is incorrect. Every sideplate is one link. The reason you can only have even length chains is because you can't connect a wide link to another wide link.
Your best bet is to count the rollers.
Bayou Boy is offline   Reply With Quote
Old 11-04-2006, 05:15 PM   #6
SPEEDSMITH
Sh!t Disturber
SPEEDSMITH's Avatar
Oddometer: 508
Okay, here is the actual way to do it.
Count all the outer plates (including the master link), and multiply by 2. (Only on one side of the chain, of course.)
Each plate (inner & outer) is considered 1 link, so, if you only count the outer plates, you must X2.
SPEEDSMITH
"It's not what you ride - It's how you ride it."
"Bite my shiny metal ass!" ~ Bender
"Racing makes heroin addiction seem like a vague wish for something salty." ~ Peter Egan
"Travel is fatal to prejudice, bigotry, and narrow-mindedness, and many of our people need it sorely on these accounts." ~ Mark Twain
SPEEDSMITH is offline   Reply With Quote
Old 11-04-2006, 05:33 PM   #7
OldRider 125
Oddometer: 571
Anyway you want to look at it or count it, if you order a 100 link chain, your going to get a chain with 50 plates on each side and 100 rollers. I see your point that 50 plates on each side equals 100 total, but I think the mfg's are referring to the number of pins in the chain.
I edited my first post, I typed divide when I had multiply on the brain.....
Old 11-04-2006, 05:33 PM   #8
jehu
∩HƏſ
jehu's Avatar
Oddometer: 3,752
Oh yes you can! It' s called a one roller or half link.
jehu is offline   Reply With Quote
Old 11-04-2006, 06:03 PM   #9
OldRider 125
Oddometer: 571
Hree's the offical answer from EK's website. Each outer and inner pair of sideplate on the chain count as a link.
How do I count chain links?
Every pair of sideplates – both inner plates and outer plates – counts as one link when determining chain length. If your bike is supposed to have a 110-link chain, count every single inner and outer plate on one side of the chain until you reach 110.
Chains will always have an even number of links. If your uninstalled chain has inner plates on both ends, or outer plates on both ends, you’ve miscounted.
Every pair of sideplates – both inner plalinks. If your uninstalled chain has inner plates on both ends, or outer plates on both ends, you’ve miscounted.
Old 11-04-2006, 06:29 PM   #10
snaggleXR650 OP
Oddometer: 244
It's amazing how such a simplistic idea can get so complicated. I've been riding bikes forever, and I'm a decent wrench, but I never really knew 'for sure' how to count links in a chain. I'm used to Honda specifying the # of links in the manual. Now, with my KTM, the manual doesn't state the # of links, so I'm lost ;)
I counted rollers, and came up with 114 links. I'll redo my count with sideplates X 2 and see if I come up with 57 links. Thanks.
Old 11-04-2006, 06:35 PM   #11
Bayou Boy
Bayou Boy's Avatar
Oddometer: 1,685
I can't think of a single motorcycle (or bicycle) that I would feel comfortable riding with that tiny pin in the chain link.
Just because it's possible doesn't make it a good idea.
Old 11-04-2006, 06:57 PM   #12
Lone Rider
Registered User
Oddometer: 25,130
Originally Posted by crankpin
I have always just sat down at the rear of the bike, taken a drop of whiteout or paint, and mark a pin. Now count the sprocket teeth holes in the chain in one full revolution. ie number of teeth holes = number of link chain.
Can also mark that pin and the forward or rear tooth ....turn and count until she comes back around. You know how many teeth are on the rear. A 20 second deal.
Lone Rider is offline   Reply With Quote
Old 11-04-2006, 07:29 PM   #13
jehu
∩HƏſ
jehu's Avatar
Oddometer: 3,752
I've seen them in use on vintage bikes. I've never really understood why anyone would need or want one but it's an old technology.
Old 11-04-2006, 07:59 PM   #14
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,752
+1
Half links or offset links are nothing but trouble. They may be OK in something really low speed or really hard to adjust.
katbeanz is offline   Reply With Quote
Old 11-05-2006, 10:25 AM   #15
viverrid
not dead yet
Oddometer: 30,482
Wow, that is the very first time I ever saw one of those!
Advanced pancreatic cancer found 04/2010. Have outlived +/- 97% of patients with this diagnosis, but 08/2013 cancer now in liver, vascular system and lungs with 20+ lung tumors. Sick/weak sometimes, not riding much. No more treatments & now under Hospice care.
viverrid is offline   Reply With Quote
Times are GMT -7.   It's 03:53 PM.
