05-02-2012, 10:19 AM
#6901 |
Befuddled Adventurer
Oddometer: 256
Anyone running a Pelican 1450 as a top case with the TCI quick release system?
Hey Everyone,
I scoured the thread, but couldn't find much on anyone using one of the smaller-sized Pelican cases as a top case on their XT (except for the photos from GauloisUSA, thanks!) I have the TCI Borrego rack and was curious if anyone was using their Borrego rack with TCI's "Top Box Hard Case Adapter kit" and a Pelican or other brand of dry case. Here's a photo (courtesy of TCI's website) of the quick release plate: I really like the idea of having a waterproof, lockable top case (that also locks to the rack) that is quick release for the times I want to take the case inside with me, or to take it off for trail riding etc. Thanks in advance for any info on this setup! |
05-02-2012, 12:16 PM
#6902 |
Oddometer: 218
Twin Duro, I don't have the TCI system, but the Moose Expedition rack system with identical lockable quick releases and similar mounting plates for the side racks. I'm using Pelican brand 1550's (huge, a little heavy, but really strong) I love the set up for overnight jaunts or commuting. The cases keep my laptop and camera equipment dry in rain. I can take the case in, or leave it locked to the bike. It's as close to an actual trunk in a car you're going to find. Don't know how much the TCI lockable plate setup is, but I'm very happy with mine. I have a non waterproof lockable metal case as well that's a little lighter and smaller I sometimes use as well.
woofer2609 screwed with this post 05-02-2012 at 12:31 PM Reason: added photo |
05-02-2012, 04:13 PM
#6903 | |
Bronze Age Fall Guy
Oddometer: 5,125
My bike was running great on a 117.5 main and had to go up to a 120 due to ethanol content. You may find the 125 main is all the rich you can handle.
Hate gets you nowhere. |
05-02-2012, 04:22 PM
#6904 |
Oddometer: 789
what should i look for?
Hello! I'm going to look at a 2001 XT225 for the first-time and wanted to know what I should be looking for. I heard about wheel bearing issues, hard starting issues, spokes... Are there any other issues with this model year that I should be concerned about? I will have more questions on jetting and performance upgrades if I buy it. thanks in advance.
I wanted to buy one of these to keep in my tank bag of my XT1200 |
05-03-2012, 10:37 AM
#6905 |
Oddometer: 39
Mods
It has been my experience to attempt one modification at a time that way if it makes it run worse you can quickly resolve the problem. If you do several mods to the carb at one time it may be tricky to determine what the problem is. That being said I would put the old carb back on (if possible) or make the aftermarket as close to stock as possible. Good Luck and keep us posted. Your misfortune now may save another rider from similar frustrations late. Thats why we are on this To help one another.
05-03-2012, 11:01 AM
#6906 | |
Oddometer: 256
05-04-2012, 08:04 AM
#6907 | |
Oddometer: 218
woofer2609 screwed with this post 05-04-2012 at 08:07 AM Reason: added info |
05-04-2012, 08:53 AM
#6908 |
Oddometer: 39
used bike
When considering any used bike I look at chain/sprokets/adjustment, tires, wheels, spokes, handlebars, carburator. Also will it idle for 3-5 minutes, clutch adjustment/slippage. Hope this helps. I don't know any xt specific problems other than the wrong oil filter which causes seizure.
05-04-2012, 02:13 PM
#6909 |
Oddometer: 78
Problem Solved!...?
Hey again folks, I'm reporting back on my '92 Serow's new carb. Installing the Tecoparts Ebay Hong-Kong knock off of the Mikuni VM-32 has been a hell of a chore, no doubt about it. I finally got it dialed in where I think it needs to be. Running a 130 main jet, 42.5 pilot jet, with one tiny shim under the needle. The thing that did it was the air flow. Even kicking the MHJ up to 145, she was still starving for fuel. This is, I'm assuming, because the float bowl is too small to refill fast enough to make full use of the larger jets. So, fuel flow is a fairly set rate provided you don't restrict the MJ too much.
Here's the kicker: Restricting the air flow was simple. All I had to do was button up the air box nice and tight (the cover was held on with 1 of 3 screws and some tape) and ta-da, she ran like a dream (after getting the jets in place) The verdict: $110 carb (with shipping!), minus a $10 refund for a slightly damaged diaphragm cover, is a whole hell of a lot cheaper than either a used one off god-knows-what, or a new one, which must be made of gold for what they're asking for it. If you've got the time, tools, and ingenuity to modify it to fit properly, it's a damn good deal. One note to prospective buyers: the diaphragm was covered in a white powdery gunk that seems to be an anti-condensation measure. The carb was shipped via a very moist route, so it's packed with powder to prevent moisture build-up. Clean 'er out and call it good. |
05-04-2012, 02:25 PM
#6910 |
Dodgin' the Ditches
Oddometer: 1,159
That's great that you got her running right. It's also great to know you can get an affordable replacement carb.
My daughter has a CRF150F and there's knockoff carbs for it on ebay for under $20! That's unbelieveable. I FINALLY learned to post photos this afternoon, so here's one of my two favorite Yamahas. ![]()
05-04-2012, 05:07 PM
#6911 |
Oddometer: 218
Good for you, now get out riding! When the time comes, lots of us will be seeking advice from you...maybe a "how to" with pics?
05-04-2012, 05:23 PM
#6912 |
Oddometer: 39
carb
Good news on the carb and bike.
05-04-2012, 08:10 PM
#6913 | |
Oddometer: 78
I think some flying debris (way-overgrown powerline roads) and rocks from gravel roads must have taken their toll on the delicate touches of the bike, cause after some poking and prodding, I found that my idle adjustment screw got knocked in about half a turn, making my Serow "Idle" at arund 4,500 rpm. This new carb is incredibly touchy on the idle adjustment. 1/16th of a turn equates to several hundred RPM. I'll need to do something about that soon, maybe some LokTite or similar thread sealer. Got a ride planned for tomorrow morning but before I can go I need to replace the crankcase cover gasket (left side) since it's puking oil now. Got a gasket, but ran out of steam tonight. I'll attack that first thing in the morning. I'd also like to replace the shift-lever oil seal, but none of the shops around here carry them. There's a Kaman Bearing not too far away, they supplied me with my Counter-shaft Sprocket Seal, so I'm sure they'll have one of these as well. Just a matter of time, running around! As for the making of a how-to on this carb, I'll be happy to document the steps I took in installing it, but I'm afraid that I didn't take any pics during the process. Maybe I'll get a wild hair some day soon and rip it apart and document all the mods done, as there were several.
05-05-2012, 06:10 AM
#6914 | |
Foamy
Oddometer: 42
2009 XT250 Tire recomendations
Thanks Glen... let me know about the road noise. Your right about the raves on the MT-43, I will definitely lean towards that tire.. Thanks, Foamy |
05-05-2012, 06:35 AM
#6915 | |
Oddometer: 2,318
You'll need a longer chain though, I can't remember how many more links? and its still a tight fit between the front of the tire and the swingarm, did approx 450 miles in Death Valley March/April about 150 - 175 was pavement talked to a few people that have tried all of the different brands of Trials tires and they said the Pirelli MT 43 is the one to get ( in their opinion) for best performance and high milage so I got it and LOVE it ![]()
