Old 08-30-2012, 05:34 PM   #7516
madmag
Oddometer: 12
Re 2 strokes: good points.
Agree about texting. It's prob time to speak with one another.
Re the missing parts: I could be going hyperbolic. Stupid stuff like the bash plate, looks like the tail light is wrong for the year? I know, I know, for my 1K offer (if he even takes it) I'm focusing on silly stuff. He texted me a couple pics. The ignition keyhole looks bigger than normal. But he says it works, and there's a key, so I guess no prob there.
Here's the ad:
http://reading.craigslist.org/mcy/3218756242.html
You're right. It's an hour away. I should just check it out. This is prob a Q for another thread but: what's doing a 4-stroke top end entail? Just buying parts and installing? Or does it have to go out to a specialist?
madmag is offline   Reply With Quote
Old 08-30-2012, 06:25 PM   #7517
deodom
Old Racer
deodom's Avatar
Oddometer: 98
Wink
Originally Posted by The Cameraman View Post
Hi Brian,
mines just passed 55,000 miles with no problems. Just a minor oil seepage from a gasket.
My 250 did over 75,00, before being written off in an accident and had no engine work done at all.
Both were still on their original clutches.
Regards
Reggie
Reggie, I heartily agree with you. My '07 is approaching 26.000 miles, runs better than new, and uses no oil at all, no smoke, and starts on the first revolution of the engine. With good maintenance, i expect to get a LOT more miles out of her before touching the engine for any kind of repair, except for maybe stator failure, which has happened once, but covered under the extended warranty, which was cheaper than the repair would have been. Still under that warranty till 4/13.
Doug
2007 XT225 / Z1 mod / re-jetted / short-snorkled / uni filter / barkbusters / Re-padded seat / modified footpegs / Load Lord rear rack / Chase Harper Dual Sport Saddlebags
deodom is offline   Reply With Quote
Old 08-30-2012, 07:21 PM   #7518
nuggets
Fries with that?
nuggets's Avatar
Oddometer: 1,826
Doug
Yep, a well cared for and non abused XT should go for a long long time with no top end needed. I did my top end as I already had to get the jug off to fix an oil leak and my compression was a bit low. I also ended up getting a new cam and rockers as the old ones were worn.
My XT lives a hard life. I do the maintenance as specified by the manual, (I even repacked the head tube bearings at 15k), but the bike gets a mercilous thrashing. I am amazed I have not had to do more to mine considering the hard life it leads. My bike gets more beatings than a red headed stepchild. If the bike had a rev limiter I would be hitting it all the time. So if my XT needs more care than some other XTs, it is just because it gets used hard.
2001 400 EXC "Punkin" | 2005 Sherco 290 "Tree Climber" | OSET 16.0 | OSET 16.0 hard tail
nuggets is offline   Reply With Quote
Old 08-31-2012, 05:57 PM   #7519
Drtyfun
Here and There
Drtyfun's Avatar
Oddometer: 1,376
I have read the manual, and it sounds straight forward, but are there any details about a clutch change that I should be warned about? I have had the top end apart and a stator change, but never messed with a clutch. What kind of surprises are in store for me?
Drtyfun is offline   Reply With Quote
Old 08-31-2012, 06:07 PM   #7520
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,291
Its relatively straight forward. It was our first time on ours and we survived. My wife did snap one of the bolts holding a spring in, so we replaced all 4. The clutch we got had one plate that was smaller inside diameter and the directions showed this piece we didn't have. I think it was for an earlier year XT, but it still worked on our 06 model. Have a gasket on hand because you will probably be scraping off the old one.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 08-31-2012, 06:59 PM   #7521
Drtyfun
Here and There
Drtyfun's Avatar
Oddometer: 1,376
Okay, thanks! I am ordering a new gasket in the morning, was already planning on that. Thanks again.
Old 09-01-2012, 06:29 AM   #7522
KamperBob
Recreation Engineer
KamperBob's Avatar
Oddometer: 254
Nuggets, thanks for clarifying the loss of compression motivating teardown. Very helpful for tracking longevity.
Doug
Doug, rock on!
Here's the ad:
What does "top end" mean to the SELLER is the question. I just pulled the cylinder to replace a jug bottom gasket that started leaking. More details in these two blog posts.
http://kamperbob.com/blog/?p=1841
http://kamperbob.com/blog/?p=1866
Note the factory settings have these critters running lean and therefore hot. For me that means the exhaust valve cover O ring has a life expectancy. Fortunately, that's a cheap fix easily addressed at valve adjustment time. ;)
Kamper Bob
(read about Half Pint's adventures at Recreation Engineer)
KamperBob is offline   Reply With Quote
Old 09-01-2012, 02:24 PM   #7523
TTRPaul
Oddometer: 39
head
I seriously doubt the head was replaced or even removed, probably a spark plug or something else minor. I've been thinking of pulling my head on my TTR225 to replace the exhaust seals. It smokes like a clowns bike in a parade when 1st starting when its cold otherwise it runs great. What else should I check/replace if I do pull the head?
TTRPaul is offline   Reply With Quote
Old 09-04-2012, 06:55 AM   #7524
gbacque
gbacque's Avatar
Oddometer: 75
Thanks, Blue. The owner texted me and said "No receipts. The prev owner was just doing it to keep maintenence on motor, no issues, just wanted to keep it fresh."
I don't know that much about engines, but this seems like a lot of work, and not something you'd regularly do. (Though I still haven't confirmed whether it was a full top end, or just gasket). Still, I'm leary.
Yea but you also see those adds where someone has a DS and states that they change the oil after every single ride. I know it doesn't take much oil but I'm not changing the oil every day. It seams like some people like working on bikes more than riding them. They are easy to point out by unnecessary maintenance with no miles.
"I ride a lot, put 500 mile on this bike over 5 years. Changed the oil 10 times, adjusted valves 3 times, rebuilt top end last summer"
gbacque is offline   Reply With Quote
Old 09-04-2012, 12:32 PM   #7525
J5k
Oddometer: 60
first post!
Hello fellow XT'ers (and ADV'ers!). This is my first post here, I was hoping to have my xt225 in time to start page 500 but I missed the boat there :)
Anyway, I picked up what looks to be a very gently used 2002 XT225 last Friday. I had to drive 4hrs into Vermont from NY to get it but well worth it.
I'll post pics once I get them online, but so far I'm pretty happy with the little beast. This is my second bike, my first being a wee little TTR125 that I bought early this spring. I've been trail riding a good bit with my wife's uncle, who bought an XT250 this summer.
After reading the first 50 or so pages of this thread, I'm a bit confused as to the success of the popular mods. AFAIK, this bike is bone stock.
First, yesterday I started it up for a little ride around the yard, just trying to get used to the size difference between the XT and the TTR. Once moving, it's really not that different at all.
But, when I started it, I think I let it idle a minute or so too long. While I was riding around the yard at the knuckle-whitening pace of 11mph, I could feel a good deal of heat on my legs. I'm reading that these things are lean from the factory. The only time I experienced something similar was when I was playing with jets on the TTR and had it running very lean (I replaced the PITA stock carb with a much better Mikuni, and I believe started with jet sizes meant for a different model of the same carb).
I just read through a nice thread over on xt225.com about re-jetting:
http://www.xt225.com/forums/ubbthrea...r=33365&page=1
Can anyone here confirm that the '3 turns on the pilot screw' will enrich the mixture, and hopefully cool the bike down a tad? Also, could someone take one of the pictures from that post and point out where the plug is for the pilot screw?
Thanks a ton for any help! I'm amazed at the helpfulness and friendlyness of the community around these cool little bikes, as well as the friendlyness of the entire ADV community. Looking forward to becoming a useful member. Hell, by this time next year, maybe I'll be able to get a ride-report up!
J5k is offline   Reply With Quote
Old 09-04-2012, 12:47 PM   #7526
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,755
It's in here, sorry don't have time to find it, but take the time to learn how to search the site--go to ask Baldy, blame AceRph forum and find the "how to search" thread. Good luck!
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 09-04-2012, 01:18 PM   #7527
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,524
Originally Posted by J5k View Post
..... pictures ... plug ...for the pilot screw?
4th post
http://www.xt225.com/forums/ubbthrea...=100905&page=1
Tom S is offline   Reply With Quote
Old 09-04-2012, 05:32 PM   #7528
J5k
Oddometer: 60
Originally Posted by Tom S View Post
Awesome! Thank you, exactly what I was looking for. As for the high heat I mentioned above, I think it had to be related to my unintentional, extended warmup time. Tip for noobies to air cooled machines, don't answer your phone while waiting for it to warm up :) I did the warmup properly today at tooled around the yard a bit. Aside from a fall trying to do turn 180 in a really small space at 1mph (forgot to clutch, bike stalled and stopped abruptly) the bike is running and riding quite well. The wet grass tought me a thing or two as well, mainly that my rear tire is ready to be replaced.
Quick question related to riding in general....my driveway is loose gravel. It feels alot like the sand I've been getting used to in the woods (stand up!). It always felt squirrely on the little ttr but not as bad on the XT. Is this just a matter of weight?
Old 09-04-2012, 07:44 PM   #7529
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,183
J5K,
Are you planning to ride on the streets or just ride trails with it? I have an 02 myself. They're the best ones and they pretty rarre, because they were only made one year.
3 turns out made mine start much easier.
It's a great bike on the trails. I run 50/50 dual sport type tires. They last a long time and I can go about 90 % of the trails that I could with a knobby.
GlennR is offline   Reply With Quote
Old 09-04-2012, 08:00 PM   #7530
jspringator
Oddometer: 458
Pics of my Russell Day Long.
If it ever stops raining I'll give it a good test.
2006 Yamaha XT225 (TM33,Wiseco 10.25 to 1 piston, Webcams 89A cam, beehive racing springs, RDL seat)
2000 ST1100 ABS, RDL seat
jspringator is offline   Reply With Quote
Times are GMT -7.   It's 01:37 AM.
