Old 10-09-2012, 06:19 AM   #7756
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,226
I've never fiddled with my suspension...scared of it I guess.
But, all this talk about it has me thinking I should try firming it up a little.
There's nothing you can adjust on the forks of an 02, is there? Mine seems a little weak in the front, maybe just looks weak because the rubber boots sag. Will the Cogent springs raise the bike any?
Btw, I just mounted a new Skinko 277(?) on the rear last night. Went pretty easy. Got a new IRC front knobby to mount on the WR450 today, hope it isn't too frustrating....I still have nightmares from the 606 front I mounted on a DRZ a couple of years ago. It was a "finger pincher"!!
http://www.firedancersglass.com/ PM me for "ADV discount"
GlennR is offline   Reply With Quote
Old 10-09-2012, 08:46 AM   #7757
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,798
I did the. 42 front springs from Cogent and the heavier rear spring. Along with the race tech emulators. It works really good.
Hate gets you nowhere.
Old 10-09-2012, 05:34 PM   #7758
kewlbyme
Occasional Partaker
kewlbyme's Avatar
Oddometer: 228
Originally Posted by Speedo66 View Post
Have you considered a shock off a TTR225? They came with heavier springs. I got one cheap off of Ebay, and it doesn't bottom with me on it, 180 before gear, plus another 25 or so in accessories.
Which color spring does yours have? I see orange and red on ebay. Different years? Different rates?
Is it a direct bolt on replacement?
Other than not bottoming out, what are your overall impressions of the xt with the ttr shock?
2001 XT225
2003 XT225
2005 DL650 - Sold
2002 KLR 703.5 - Sold
1999 Valkyrie IS - Sold
kewlbyme is offline   Reply With Quote
Old 10-09-2012, 06:00 PM   #7759
Crazy Canadian
All who wander r not lost
Crazy Canadian's Avatar
Oddometer: 2,028
Called Yamaha, red is stiffest, then orange, yellow and black.
I've learned to give "impossible" the finger as I pass it by.
The only way to get through life is to laugh your way through it!
Day by day, nothing seems to change. But pretty soon, everything is different.
Crazy Canadian is offline   Reply With Quote
Old 10-09-2012, 06:25 PM   #7760
J5k
Oddometer: 60
Installed this today. So far so good, cranks as hard as the stocker.
J5k is offline   Reply With Quote
Old 10-09-2012, 06:28 PM   #7761
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,881
That's tiny!
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 10-09-2012, 06:33 PM   #7762
Crazy Canadian
Oddometer: 2,028
Originally Posted by a1fa View Post
That's tiny!
That's what she said!
Old 10-09-2012, 06:39 PM   #7763
J5k
Oddometer: 60
Actually, the first crank feels weak but then it feels just like it always does.
Old 10-09-2012, 06:48 PM   #7764
Crazy Canadian
Oddometer: 2,028
First twist is always always the hardest.
Old 10-09-2012, 07:33 PM   #7765
woofer2609
woofer2609's Avatar
Oddometer: 812
Cooool!
So what do you figure the weight savings is? I saw these and will be buying one when I need a replacement battery.
The real question is, what are you going to put in the new space you've created in the battery box?
woofer2609 is offline   Reply With Quote
Old 10-09-2012, 07:38 PM   #7766
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,544
You might tell us exactly WTF it is.
Tom S is offline   Reply With Quote
Old 10-09-2012, 07:40 PM   #7767
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,226
J5K,
Is that a Lithium Iron battery? What brand is it?
I recently installed a Turn Tech on my 450. I think they said it gets stronger after you use them a while. Mine is in the same size case as the OEM battery, but the early models were about 1/2 the size. It works great, but so would a new stock battery. The main reason I paid the few extra bucks was because they are so much lighter. I think it's about 16 oz (maybe less) and the OEM battery was about 5 lbs. Seems like the cheapest way to shed 4 lbs.
Old 10-09-2012, 08:05 PM   #7768
J5k
Oddometer: 60
The listed weight for the ballistic evo2 4 cell lithium battery was something like 0.9-1.0 pounds. I haven't weighed the stock one. I'm going to guess a weight savings of about 4+ pounds, but those 4 are in a nice spot to reduce ;). For now ill probably fill the gaps with pieces of the foam that was holding the battery in its packaging.
Old 10-10-2012, 04:01 AM   #7769
airborndad
airborndad's Avatar
Oddometer: 2,517
J5K,
good deals here
Ultra Light Batteries http://advrider.com/forums/showthread.php?t=629665
airborndad is offline   Reply With Quote
Old 10-10-2012, 06:01 AM   #7770
Speedo66
Transient
Oddometer: 6,863
I just checked, the spring is red, original was yellow. It's a direct bolt on, and not that difficult to do. Nothing but the seat, as I remember, had to be removed, but it's been a while. Maybe the rear tire, but not sure.
I am not a fast rider, and have a relatively unsophisticated bottom, so no real "feel" difference to me. I just thought the back felt soft, and now it doesn't.
They're available relatively inexpensively on Ebay, for the price it's a no brainer. Not sure if the shock itself is any heavier duty, I just swapped out the complete unit.
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Times are GMT -7.   It's 11:25 AM.
