Old 02-15-2013, 06:09 AM   #8521
KamperBob
Recreation Engineer
KamperBob's Avatar
Oddometer: 254
Originally Posted by Tom S View Post
Never done it but Im sure it would be a PIA to do it with the tank on. Cant be very hard & gotta be way easier than the other stuff youre gonna do.
Pull it & clean any dirt away that might fall into the engine after you open it up to adjust the valves.
+1
Half Pint's due for valve adjustment. I got a square drive screw to turn into a wrench for the screw. That should help.
Kamper Bob
(read about Half Pint's adventures at Recreation Engineer)
KamperBob is offline   Reply With Quote
Old 02-15-2013, 06:09 AM   #8522
BroncoDave
BroncoDave's Avatar
Oddometer: 4,572
The tube dos cum out and should be clean'd and the top is half round no hole I think that's what we are talking
Aboot
BroncoDave is offline   Reply With Quote
Old 02-15-2013, 08:25 AM   #8523
Keithert
Oddometer: 941
Originally Posted by KamperBob View Post
+1
Can you elaborate on this. How will it look and work?
2007 Yamaha Royal Star Tour Deluxe, 2011 Suzuki V-Strom 650, 2005 Yamaha XT225, 1998 Ural Deco Classic
Keithert is offline   Reply With Quote
Old 02-15-2013, 08:33 AM   #8524
KamperBob
Recreation Engineer
KamperBob's Avatar
Oddometer: 254
IIRC it was posted here a year or so ago. The basic idea is this. Start with a square drive screw several inches long. Heat and bend the head end about 90 degrees. The rest is your handle. The square drive fits close enough (if not perfect ... so I've read) to the square ended valve adjuster bolt sticking up through the jam nut. Holding that bolt separate from the jam nut with two wrenches lets one set the valve clearance with less trial and error. That's the plan...
Kamper Bob
Old 02-15-2013, 11:13 AM   #8525
WayneJ
LFC Nobody
WayneJ's Avatar
Oddometer: 6,072
A 4" adjustable wrench worked fine when I did mine.
AMA-563452 - AW-6274 / '98 ST1100 - '01 DRZ400s
20% Smug Mug Credit
WayneJ is offline   Reply With Quote
Old 02-15-2013, 11:58 AM   #8526
Crazy Canadian
All who wander r not lost
Crazy Canadian's Avatar
Oddometer: 2,028
Originally Posted by carlclaflin View Post
does anyone know if it is possible to adjust the valves without removing the fuel tank? I have a Haynes and that is what it suggest. This is the first time every working on a motorcycle, so my knowledge is none. i do have to replace the right side engine cover, that is leaking. so i'll just change the filter/oil while i'm at it. Got to get the bike ready, spring is coming and i'm itching to ride.
anyone out there have some tip/tricks for me?
Pulling a tank is easy, might seem daunting at first but it is simple and quick.
I've learned to give "impossible" the finger as I pass it by.
The only way to get through life is to laugh your way through it!
Day by day, nothing seems to change. But pretty soon, everything is different.
Crazy Canadian is offline   Reply With Quote
Old 02-15-2013, 01:57 PM   #8527
Keithert
Oddometer: 941
Thanks KamperBob. I did the valve adjustments several years ago on a Virago which uses a similar system without any special tools. I'll try this and see if it works better.
Old 02-15-2013, 04:16 PM   #8528
KamperBob
Recreation Engineer
KamperBob's Avatar
Oddometer: 254
That's basically what I did previously. Until I saw this which looked and sounded slick.
No problem. Be sure to report back. BTW, I tried the site thread search but it kept barfing. (shrug)
Kamper Bob
Old 02-15-2013, 04:25 PM   #8529
hooligan-in-idaho
hooligan-in-idaho's Avatar
Oddometer: 9
New XT225 owner
Hello all,
I thought I should introduce myself on the official xt225 thread. I'm the proud new owner of a 2001 Yamaha XT225 and I love this thing. It's my first "dual sport" and I've been dying to get into the adventure riding scene for a few years. I'm riding it every chance I get and am eager to get some experience riding in the dirt (nothing too extreme, I'm a noob).
I'm glad there's a thread for this bike because I know I'm going to have some questions about the bike and some upgrades I'm contemplating. Thanks in advance for your patience.
Here's a pic from a ride last week. Some of you may have already seen it on another post but I like the pic so I'm gonna use it.
Current Bike: 2001 Yamaha XT225
hooligan-in-idaho is offline   Reply With Quote
Old 02-15-2013, 06:22 PM   #8530
Roadrunner
(Negativus Supersonicus)
Roadrunner's Avatar
Oddometer: 23,376
Originally Posted by hooligan-in-idaho View Post
Hello all,
Congratulations....and welcome to the XT'rs, compliments of the OT - wickerman777.
The more the merrier!
"System change is not for the conceptually or interpersonally fainthearted." - Sarason
Roadrunner is offline   Reply With Quote
Old 02-15-2013, 07:32 PM   #8531
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,051
I can't imagine even trying to adjust the valves with the tank on.. And why? It takes less than 5-10 mins. To pull seat and tank. If Haynes suggests doing it with the tank on(impossible) throw it away and get a Clymer's....oops! Wrong bike.... Sorry,disregard my post. Duh.
"Where ever you are, there you go..."
SkiBumBrian screwed with this post 02-15-2013 at 07:38 PM
SkiBumBrian is offline   Reply With Quote
Old 02-15-2013, 09:11 PM   #8532
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,541
Disregard? Why? It's all true & applies. Except that I wouldn't use either one of those manuals.
Tom S is offline   Reply With Quote
Old 02-16-2013, 05:37 AM   #8533
carlclaflin
Oddometer: 249
alrighty, thanks for the tips/help. i shall order my parts and attempt the valves.
carlclaflin is offline   Reply With Quote
Old 02-16-2013, 06:51 PM   #8534
alonzo
Misadventurer
alonzo's Avatar
Oddometer: 432
Aboot
WTF does this mean???
alonzo is offline   Reply With Quote
Old 02-16-2013, 09:01 PM   #8535
Spank
Spank's Avatar
Oddometer: 64
Add me to the list of owners.
WR gets a little brother
Super clean '04 with 2000 miles on the odometer. Cool little bike.
John E.
'08 Yamaha WR250R
'04 Yamaha XT225
My SPOT
Spank screwed with this post 02-18-2013 at 08:19 AM
Spank is offline   Reply With Quote
Times are GMT -7.   It's 08:32 AM.
