Old 02-23-2013, 07:20 AM   #8581
carlclaflin
Oddometer: 248
Originally Posted by Speedo66 View Post
Perhaps your vest by itself didn't pull too much power, also I believe your year had a 35 watt bulb, rather than a 55 as the later years did. I know the earlier models had a less powerful charging system, but maybe it was enough with the lower wattage bulb.
If I ride with my full jacket liner and heated gloves on, they will eventually kill even a new battery. If I shut them both off a few miles before I stop, the battery will fully recharge itself, so I don't see any issues with the charging system or battery.
I believe the system is adequate for it's intended purposes, but not sufficient for additional heavy power uses.
yeap, mine is 1994 w/ 35watt headlight. the charging system is WEAK! hopefully yamaha fixed that in the newer models. when weather is nice and no snow on the ground, i'm always on my bike. i work graveyard 7pm-7am; riding to work and home with dimming headlight when stopped, me no like. that is why i would love to upgrade all my lights to LEDs and a H4.
carlclaflin is offline   Reply With Quote
Old 02-23-2013, 07:32 AM   #8582
WayneJ
LFC/CCCCC
WayneJ's Avatar
Oddometer: 5,616
Well DUH!
That's why I only used a vest and didn't run heated grips, gloves, pants, socks, and a coffee maker.
You keep using more power than the bike can provide, you'll eventually be replacing the stator.
AMA-563452 - AW-6274 / '98 ST1100 - '01 DRZ400s
I got a chill standing outside wiggling wieners.. - LadyDraco
There is no odometer when it comes to pie - VACommuter
20% Smug Mug Credit
WayneJ is offline   Reply With Quote
Old 02-23-2013, 07:42 AM   #8583
WayneJ
LFC/CCCCC
WayneJ's Avatar
Oddometer: 5,616
Believe what you want to believe.
I guess I had the only good one Yamaha ever made.
I'm done wasting my time here.
20% Smug Mug Credit
Old 02-23-2013, 10:01 AM   #8584
dav_dman
dav_dman's Avatar
Oddometer: 818
Originally Posted by Mayapis View Post
Greetings, Fellow XT225 riders.
I hope someone can help me with my 2003 XT225 which has only 12000 kms.
It starts up after 2 or 3 cranks, idles normally and revs up normally. But after a few kilometers of riding, the idling speed drops when stopped in traffic and then dies. It starts up again, idles normally but then the same thing happens again: idling speed drops and engine dies. There is no problem when running at high revs. Only when stopped in traffic and the engine is idling. After several carb overhauls and really thorough cleaning using an air compressor and carb cleaner, the problem is still there.
I have checked fuel flow from the tank and there is no problem there. I visually inspected the rubber intake manifold which has been reported to crack up and leak after 5 years but mine still looks very good. When the engine was idling normally in the garage, I sprayed WD40 on this intake manifold to see if some of the WD40 would be sucked in and if the idling would be affected but it did not.
I have ruled out any ignition problems because if it was, the problem would affect the entire rev range. But I could be wrong, of course.
Anyone experience the same problem? I am running out of ideas for a possible solution. Would appreciate hearing your thoughts.
spray the boots with starting fluid and if it idles up then you have a leak.
but that is not your problem. I like the coil suggestion. Is float adjusted properly to allow the bowl to fill and idle off the low speed circuit only? pop the tank top and if it idles then theres not enough tank venting? just tossing them out there
dirt bikes, vstrom, cruiser, etc.
"what hurts, instructs" - ben franklin
dav_dman is offline   Reply With Quote
Old 02-23-2013, 11:42 AM   #8585
maverick1
maverick1's Avatar
Oddometer: 31
I recently bought a new OEM Yamaha foam replacement air filter.
After examining it, I can't tell if it was oiled from the factory, or if I need to oil it?
Does anyone know if they come pre-oiled?
If it is oiled, it is only very lightly.
thanks
maverick1 is offline   Reply With Quote
Old 02-23-2013, 11:54 AM   #8586
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,712
Originally Posted by maverick1 View Post
I recently bought a new OEM Yamaha foam replacement air filter...
I bought one as well. It did have a light oil coating but I wouldn't trust it. Since I use NoToil I went ahead and cleaned it with solvent and then applied my oil. If you're using a petroleum-based oil I'd just apply the new oil without cleaning.
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is online now   Reply With Quote
Old 02-23-2013, 02:18 PM   #8587
Keithert
Oddometer: 844
Is cleaning the new filter element prior to putting the no toil on necessary? My new Yamaha element felt dry.
2007 Yamaha Royal Star Tour Deluxe
2005 Suzuki V-Strom 650
2005 Yamaha XT225
1998 Ural Deco
Keithert is online now   Reply With Quote
Old 02-23-2013, 02:32 PM   #8588
HardWorkingDog
Harvey Mushman
Oddometer: 1,712
Should be fine.
"Coffee first..."
Old 02-24-2013, 01:37 PM   #8589
DerekC
DerekC's Avatar
Oddometer: 8
Rode 125 miles today, mostly dirt roads. And, broke the elusive 100 mpg barrier, 100.2 mpg :)
DerekC is offline   Reply With Quote
Old 02-24-2013, 11:38 PM   #8590
carlclaflin
Oddometer: 248
Originally Posted by WayneJ View Post
You need a volt meter. All voltage checks should be done with a fully charged battery. If it's a wet battery, make sure the electrolyte is over the plates.
Remove the side cover so you can get to the battery terminals. Check voltage at the battery terminals with the key off, it should e 12.4-12.6 volts. If less than 12.4, your battery may be failing.
Start the bike and check the voltage again. With the bike running, it should be 13-14 volts. You might have less voltage than this when idling. If you increase the RPMs a little, it should come up to 13-14 volts. Mine would have have 13.4 volts even at idle with my heated vest on.
If your readings are less with the bike running, there is a problem somewhere. It could be anything from a bad stator to a loose or corroded connection.
Faulty grounds/loose and corroded connections are a fairly common problem, especially on a bike that's been stored outside or exposed to other wet conditions.
Your headlight dimming when the flashers are used could very well be a faulty ground in the lighting circuit. Finding faulty grounds and loose/corroded connections can be a very difficult thing to do.
Good luck.
Thank you. I have seen some wires that look as if electrical tape has been used for some reason or another....i am the third owner. I shall do some investigating, hopefully it wont be to painful.
Old 02-25-2013, 02:27 PM   #8591
Crazy Canadian
All who wander r not lost
Crazy Canadian's Avatar
Oddometer: 2,028
Your right wrist is gentler then mine... I only get about 60 at best.
I've learned to give "impossible" the finger as I pass it by.
The only way to get through life is to laugh your way through it!
Day by day, nothing seems to change. But pretty soon, everything is different.
Crazy Canadian is offline   Reply With Quote
Old 02-25-2013, 04:44 PM   #8592
DerekC
DerekC's Avatar
Oddometer: 8
I think the worst I've ever gotten is around 70
Old 02-25-2013, 05:32 PM   #8593
GI_JO_NATHAN
GI_JO_NATHAN's Avatar
Oddometer: 2,372
I wish I knew what I get on mine. I'm normally filling it with a gas can.
Jonathan
If guns are outlawed, only outlaws will have guns.
Originally Posted by POLLOCK28 (XDTALK.com)
From what I understand from frequenting various forums you are handling this critisim completely wrong. You are supposed to get bent out of shape and start turning towards personal attacks. Get with the program!
GI_JO_NATHAN is offline   Reply With Quote
Old 02-25-2013, 05:41 PM   #8594
Crazy Canadian
Oddometer: 2,028
I think my problem is how hard I crank it to get there... I crank it too hard off the line I think. Not to mention having to carry my fat ass up the hills!
Old 02-26-2013, 10:51 AM   #8595
NesquikNinja
Oddometer: 303
Hey guys
I currently ride a 2013 Honda CRF250l. I am bike shopping for a friend, and came across an old XT225. Just wanted to consult you guys and see if it fits the bill. I did some research, but mostly found info on the new ones.
The bike in question is a 1992 XT225 with roughly 3,000 miles. Asking price 1,200 USD, but I know how to negotiate.
If will be his first bike. He wants the following
-Reliable
-Parts available
-Highway capable (Doesnt mean it has to be good at it. Just able to cruise 60mph without hurting the bike)
That's honestly about it. As long as he can cruise 60 mph, it doesnt need frequent repair or service, and he can repair/service when it needs it, he will be happy.
Thoughts?
EDIT: Just to add, I can find some roughly ten-twelve years newer for $400-$600 more.
Originally Posted by Sparrowhawk View Post
More stuff will clutter your life and make you poor. More adventure will richen your existence. Make do and make tracks.
NesquikNinja is offline   Reply With Quote
Times are GMT -7.   It's 08:55 AM.
