Old 03-04-2013, 12:26 PM   #8626
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 3,513
Originally Posted by carlclaflin View Post
it appears that the intake valve nut is missing. shitonastick
Hope you can find it. Met a !#$%&! Suzuki DR200 that swallowed one. It’s engine locked up & the cam chain & remains of the nut were found in the bottom of the case. Never found out if the valves hit the piston. May be a good idea to look in to where the cam chain runs.
Tom S is offline   Reply With Quote
Old 03-04-2013, 02:00 PM   #8627
nuggets
Commutator
nuggets's Avatar
Oddometer: 1,174
I am pretty sure that the way the head is designed, the nut would have no way to work it's way over to the cam chain. I think if you take both valve covers off, and fish about with a small magnet, you might get lucky.
2007 xt225
2004 KX250 - Soil Sampler
Nuggets' free bike tech clinic.
nuggets is offline   Reply With Quote
Old 03-04-2013, 03:09 PM   #8628
GI_JO_NATHAN
GI_JO_NATHAN's Avatar
Oddometer: 1,166
Originally Posted by SantaFeTrailer View Post
Got it! Yeah!
2007 with 650 miles on the clock!
let the farklng begin (oh, OK, I have already installed a tool tube)
Wow! Awesome!
Jonathan
Originally Posted by Bueller View Post
Someone quote me so he can see my response
Originally Posted by POLLOCK28 (XDTALK.com)
From what I understand from frequenting various forums you are handling this critisim completely wrong. You are supposed to get bent out of shape and start turning towards personal attacks. Get with the program!
GI_JO_NATHAN is online now   Reply With Quote
Old 03-04-2013, 03:09 PM   #8629
GI_JO_NATHAN
Oddometer: 1,166
Originally Posted by GI_JO_NATHAN View Post
Wow! Awesome!
Just wanted to be the next one to quote myself..
Jonathan
Old 03-04-2013, 07:27 PM   #8630
woofer2609
woofer2609's Avatar
Oddometer: 217
Laugh
1+ or I guess you could always turn the bike upside down and shake vigorously
woofer2609 is offline   Reply With Quote
Old 03-04-2013, 08:39 PM   #8631
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 5,559
I just posted the other day in the DR650 thread how we did that years ago at Loudon.
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is offline   Reply With Quote
Old 03-04-2013, 09:26 PM   #8632
carlclaflin
Oddometer: 88
Well fellows, i got lucky!! And yes, Nugget is correct, the way the head is designed, it seem almost impossible for that nut to go down into the engine. But as we all know, nothing is impossible. As soon as i pulled the head and tilted it to look at the matting surface, the nut fell out into hand!! i fished and fished for it with two different size magnet tools and NO LUCK! O'well, i found the nut, got the bike back together and got the valves adjusted.
carlclaflin is offline   Reply With Quote
Old 03-08-2013, 10:23 PM   #8633
GuitarDave
Freezing his a** off
GuitarDave's Avatar
Oddometer: 14
Hello, I'm blowing a little oil from behind my Cam timing Chain adjustment bolt
Hello, I'm blowing a little oil from behind my Cam timing Chain adjustment bolt.
Is this "normal"?
It's a 2007 XT225, bone stock with under 4,000 miles.
I usually run the YamaLube.
My left boot now shines a little more than my right one.
Thanks in advance,
David.
GuitarDave is offline   Reply With Quote
Old 03-09-2013, 06:41 AM   #8634
nuggets
Commutator
nuggets's Avatar
Oddometer: 1,174
I think you are talking about the cam chain tensioner. Maybe you just need to replace the gasket?
Is this "normal"?
Thanks in advance,
David.
2007 xt225
Old 03-10-2013, 02:38 PM   #8635
T!Mster
Lets Ride!!
T!Mster's Avatar
Oddometer: 130
Send a message via Skype™ to T!Mster
A few mods.
I bought a Pelican 1400 case the other week. I did a little modification to make it just like I want it. I attached it to the rear rack with rubber lined clamps. A 1gal RotoPax is mounted to the top.
The elastic net is made for the door of a Jeep Wrangler. I secured it to the lid for my electronics. I have 2 USB ports mounted to a piece of angled aluminum. The back of the net also protects electronics from the RotoPax hardware.
I installed a cig outlet for my Slime pump.
Power from the bike. The wiring is tucked up and out of the way and the fuse box is underneath the side panel.
Built a shelf and lined it with foam. The Slime pump slides underneath the shelf.
Tool bag fits in perfectly.
What I couldn't fit in the Pelican case went in here.
Wolfman side racks for my dry bags. They are modified racks for a WR250R. Did a little welding and powdercoating.
I also powdercoated the heat shields. I hate chrome! Also installed bark-busters, foldable mirrors and moved the rear turn signals to allow room for the side racks.
T!M
"And because it gives me a little chubby every time I get on the thing." -crowe2815
T!Mster is offline   Reply With Quote
Old 03-10-2013, 04:34 PM   #8636
GI_JO_NATHAN
Oddometer: 1,166
Wow!
Good work!
Jonathan
Old 03-10-2013, 05:11 PM   #8637
LisaS
Dubious Adventurer
LisaS's Avatar
Oddometer: 552
finished my rebuild project this morning:
I'm pretty happy with how it turned out
Lisa
2007 xt225; 2008 yamaha wr250, 2003 Suzuki SV650;
tent space
LisaS and shoein's Maine Adventures
LisaS is offline   Reply With Quote
Old 03-11-2013, 07:26 AM   #8638
tuna101
Oddometer: 101
Way to go Lisa, have been watching your build on the XT forum, looks like all your hard work has paid off, looking good. I see all your snow has melted, ha, ha. That's the way to get out of it.
tuna101 is offline   Reply With Quote
Old 03-11-2013, 07:54 AM   #8639
KamperBob
Recreation Engineer
KamperBob's Avatar
Oddometer: 226
Nice electrical work. Is that lamp cord. What gauge wire and where did you source it? TIA
Kamper Bob
(read about Half Pint's adventures at Recreation Engineer)
KamperBob is offline   Reply With Quote
Old 03-11-2013, 12:32 PM   #8640
T!Mster
Lets Ride!!
T!Mster's Avatar
Oddometer: 130
I used 2 USB ports and the cig outlet from BurnsMoto.com. The wiring is just some odd pieces I had laying around. The connections are all soldered and heat-shrinked for water protection. The power supply is a standard SAE plug. The power plug on the bike is a tank bag connection from Powerlet.com that I mounted on the rear fender. The fuse block is secured under the side plastics.
T!M
Times are GMT -7.   It's 06:36 PM.
