Old 04-18-2013, 02:05 PM   #8761
goodburbon
Oddometer: 111
Just picked up an 08' with 500 miles on it, a set of luggage, and a pair of sena radios in trade for my Buell.
It doesn't even remotely compare to my buell, but it should be a better toy, and get my wife into riding. If it doesn't, it's still a toy for me.
06' Buell Ulysses...gone
13' BMW F700GS factory low.
07 XT225
00' TTR125L
09' Buell Ulysses
goodburbon is offline   Reply With Quote
Old 04-18-2013, 02:11 PM   #8762
ER70S-2
ER70S-2's Avatar
Oddometer: 6,127
Cry
Kalirado: It's so sad that I know exactly what that means.
2004 DR650: 62,402 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 04-20-2013, 07:08 PM   #8763
heirhead
Oddometer: 527
Tough to start cold??????????
Hello,
06 xt, 5,000 miles. rode hard and put away wet.
Bitch to start cold, really tough, stars have to align. Sometimes on full choke then starts or no gas at all, tried everything! No system to this one. Lots of starter.
Starts great hot and runs great. Good wheelies! Plug looks good, stock jets, 2.5 turns out, clean air filter. Bump starts so easy, as soon as you dump clutch in 3rd. To fat and old to bump. Sea level and above.
Could this be the dreaded stator??????
Thanks for any clues,
heirhead
worlds worst mechanic
heirhead is offline   Reply With Quote
Old 04-20-2013, 08:06 PM   #8764
moterbiker
Gypsy diver
moterbiker's Avatar
Oddometer: 1,475
Originally Posted by heirhead View Post
Hello,
heirhead
First I really don't think it has anything to do with the stator.
My bike was like this as well, when I rebuilt the carb last summer I paid attention to the choke setup when I put it back together, the choke cable is split under the tank, it was not correctly setup.
When I got it all back together the bike now starts perfectly. Basically the cable wasn't under the right tension, so when I pulled the choke lever it might have only been operating the choke about 1/2 way.
Some random stuff for sale
http://www.advrider.com/forums/showthread.php?t=988511
moterbiker is offline   Reply With Quote
Old 04-20-2013, 11:55 PM   #8765
redninja
Will ride 4 scenery
redninja's Avatar
Oddometer: 429
Hello,
heirhead
Turn the petcock off and run it a bit when you're done riding. Works like a charm for us. I read someplace that the volatile parts off the gas evaporate quickly so when you run some of the gas out of the carb, this allows fresh gas to come in when you go to start it up again. Been doing this ever since we first got the bikes; it's the only trustworthy way to start them (ours, anyway).
ADV relay rider CO/NM
redninja is offline   Reply With Quote
Old 04-21-2013, 12:22 AM   #8766
heirhead
Oddometer: 527
hard to start
Hello,
Will try both responses, thanks. Last xt started and ran so great thought everyone was cookoo including my friend. He had to replace stator. Have owned many bikes and on the vintage ones there is always a ritual to starting but the newer ones always just hit button. Looks like my last one was an exception to the rule.
Thanks again, will update as I really want to ride this one, its fun.
heirhead
Old 04-21-2013, 06:50 PM   #8767
Dirt2Street
Oddometer: 53
Originally Posted by redninja View Post
There are no names or trademarks at all on the mirror. I've had it for quite awhile; I've bought a lot of stuff from Dennis Kirk, but I just looked there and don't see it. I do remember it was less than $25. I see I had to bend the arm a lot to get it to fit, but I am no metalworker...just a vise and pliers!
Looks real nice! Hows it do with all the vibration?
"Live for nothing or die for something...your choice." -Sylvester Stallone
Dirt2Street is offline   Reply With Quote
Old 04-22-2013, 08:20 AM   #8768
heirhead
Oddometer: 527
Tried on one from friends bike. ok but could not see any better.
Would be torn off in crash SOON. Ken Sean are easy to see, as I ride lots of street and they fold out of the way completely in 1 sec, on the fly easily.
heirhead
Old 04-24-2013, 06:23 PM   #8769
vabuckaroo68
Gnarly!
vabuckaroo68's Avatar
Oddometer: 1,169
Carb Issues
I have put the jet kit on my daughter's TTR225, opened the air cleaner and muffler. It runs great right after I pull the carb apart and clean it, but if it sits for a few days, it runs like crap. The only 2 speeds it has is off or WFO. Won't idle without the choke. I also use fuel treatment. My guess is the jets keep corroding. Is this a common issue with the 225?
"Over the Mountains Of the Moon,
Down the Valley of the Shadow, Ride, boldly ride,"
The shade replied- "If you seek for Eldorado!" E.A.P. 1849
04 KTM 950ADV ~ "BEASTIE", '13 KTM 300XCW, '76 Husky 360WR/CR,
vabuckaroo68 is offline   Reply With Quote
Old 04-24-2013, 07:44 PM   #8770
TwilightZone
Oddometer: 2,956
>"My guess is the jets keep corroding. Is this a common issue with the 225? "
IMHO: Likely some contaminants in the gas are plugging the jets.
Have you flushed out the fuel tank, petcock and lines?
Maybe you should put an inline filter in before the carb ?
"I don't really know, I've been too busy falling down."
TwilightZone is offline   Reply With Quote
Old 04-25-2013, 01:34 AM   #8771
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,411
That won’t happen in days or even years. Check your work & what TZ said, dirt in the gas.
Tom S is offline   Reply With Quote
Old 04-25-2013, 09:01 AM   #8772
greasespot
Oddometer: 42
(Crappy running)
I learned years ago with a choked down GPz 305. The idle jets looked like there wasn't a hole in them. Needed a very good fuel filter. 4th thing I did to my Xt.
NEW TOPIC:
Hey, I know everyone uses those DMO footpegs, but I don't want anything that wide (thick? Talking front-to-back) because I have trouble shifting and hitting the brake with anything much wider than stock (yes, very small feet).
Anyone know of a longer (out-to-the-side) footpeg that fits? From another bike maybe?
M.
greasespot is offline   Reply With Quote
Old 04-25-2013, 09:33 AM   #8773
Speedo66
Transient
Oddometer: 6,700
+1
Doing this is the only way I can get my bike to start reliably.
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 04-25-2013, 11:23 AM   #8774
Mole-Man
Mole-Man's Avatar
Oddometer: 5
Originally Posted by greasespot View Post
(crappy running)
i learned years ago with a choked down gpz 305. The idle jets looked like there wasn't a hole in them. Needed a very good fuel filter. 4th thing i did to my xt.
M.
+1
Mole-Man is offline   Reply With Quote
Old 04-26-2013, 09:39 AM   #8775
Dirtmonkey8
VA is for Riders
Dirtmonkey8's Avatar
Oddometer: 1,107
Originally Posted by T!Mster View Post
I bought a Pelican 1400 case the other week. I did a little modification to make it just like I want it. I attached it to the rear rack with rubber lined clamps. A 1gal RotoPax is mounted to the top.
The elastic net is made for the door of a Jeep Wrangler. I secured it to the lid for my electronics. I have 2 USB ports mounted to a piece of angled aluminum. The back of the net also protects electronics from the RotoPax hardware.
I installed a cig outlet for my Slime pump.
Power from the bike. The wiring is tucked up and out of the way and the fuse box is underneath the side panel.
Built a shelf and lined it with foam. The Slime pump slides underneath the shelf.
Tool bag fits in perfectly.
What I couldn't fit in the Pelican case went in here.
Wolfman side racks for my dry bags. They are modified racks for a WR250R. Did a little welding and powdercoating.
I also powdercoated the heat shields. I hate chrome! Also installed bark-busters, foldable mirrors and moved the rear turn signals to allow room for the side racks.
I knew the bike went to a good home, but DAMN! You get her broken in yet?
A little dirt don't hurt.
Dirtmonkey8 is offline   Reply With Quote
Times are GMT -7.   It's 12:30 AM.
