Old 05-08-2013, 12:26 PM   #8806
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,134
Originally Posted by GI_JO_NATHAN View Post
You Sir are correct on all accounts.
I decided to not spent any extra time or money on this venture. So as to keep it fun...
I did start with the badass dirt bikes, however, I was racing myself and the course.
Didn't see any other dual sports, but there was a kid on some sort of vintage honda, wearing overalls and a fanny pack. Finished the whole thing, it was pretty awesome.
I will for sure be trying it again. Not sure If I will go with full nobbies, or DOT nobbies. Depends on if i pick up an extra set of wheels.
The main failure in all of this however was my fatigue after struggling up some obstacles and many falls. The little XT could have done great with the right rider.
Maybe next time the course will be dryer and tires won't be an issue. IMO, if you don't get hurt you're a winner!
GlennR is offline   Reply With Quote
Old 05-08-2013, 07:38 PM   #8807
Adelphos
Adelphos's Avatar
Location: Nebraska or South Dakota depending on the season
Oddometer: 106
Originally Posted by Adelphos View Post
I need a hand narrowing down tire choices. I have found three reputable tires that come in the sizes I need for front and rear. From what I've read my preference is in this order:
1.) Bridgestone Battlax BT45
2.) Michelin Pilot Activ
3.) other
4.) Avon Roadrider AM26 ?
It's pretty much down to the Mich vs Stone thing again haha
This will be my first time purchasing new tires for my 06 xt225 and could definitely use the help of some experienced riders. Price is close enough to not really be a factor.
Sizes: 130/80x18 rear & 110/90x18 front
Terrain: Street/commuting mostly, prefer wet performance followed by longevity and finally fuel economy.
Thanks for any insights, this is the last decision I need to make to finish my bikes transformation.
For whomever cares I've decided to go with the Michelins
Adelphos is offline   Reply With Quote
Old 05-08-2013, 07:46 PM   #8808
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,134
I bet the XT is fun with street tires. I'll probably never mount them since there's so many trails here, but if I lived in a city they'd be great. I'm sure the bike will handle a lot better on the streets with street tires. They probably will last a long time, and I'd expect you gas mileage will improve a bit too.
Old 05-08-2013, 08:09 PM   #8809
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,237
I have two sets of XT rims, one has Kenda 244's and the other full knobbies. When the kenda's wear out I will probably put full street tires on it. I just need to which ones at some point.
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is offline   Reply With Quote
Old 05-08-2013, 09:07 PM   #8810
Adelphos
Adelphos's Avatar
Oddometer: 106
Injured spine and hands (to say the least) has taken me out of the off-road stuff (excluding going in my 1993 Toyota Pickup ) so since I'm going to be commuting with it anyways I figured I may as well do this thing right haha it's fun in the process as well.
Might I suggest considering the few I was deciding between above :
This is my off roader now
Topper is off for the first time since I've owned the Pickup:
Bike is loaded up:
Took it to the shop for more room to work:
Man, Truck, Bike:
Cleaned off my dusty gear:
Finally broke 88,000 :cool:
And one for the road:
Old 05-09-2013, 04:25 AM   #8811
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,134
I can definitely understand the injuries keeping you away from the trails. When I get there I'll mount street tires too, to make sure I stay out of the mud & rocks.
Btw, I also have an ATV. It is much easier on the body (assuming you don't roll it!). I can go almost anywhere a bike can go, actually it can go some places that the bike can't. It crawls over bolders & through mud, and extremely steep hills that the bike can't. The bike's more agile of course, and can fit through tighter spots. I have fun on both.
Old 05-09-2013, 08:39 AM   #8812
gbacque
gbacque's Avatar
Oddometer: 75
Okay, I'm getting a little frustrated with a cutting out problem. When the bike is cold it runs GREAT! But once warmed up it runs very rough in the low throttle position. Around 1/4 throttle it keeps cutting out. Thinking it was a jetting issue I got the jet kit from Pro Cycle. Tried both the jets provided and adjusted the a/f mixture in every suggested setting as well as burning the hell out of my hand looking for that point where it speeds up as I adjust it. On the plus side I can get the carb in and out of the bike in about 2min now. The carb has been cleaned about a dozen times and nothing I do seams to make any difference.
Last night I noticed that when I set the idle high in an attempt to adjust the A/F again that the bike would not settle down into a steady idle. It races up a little bit then cuts out, then races up a bit. At no point in the adjustment did this go away.
The question I have is what else BESIDES the carb could cause this? Bad stater, pulse generator, CDI? Not sure where to start.
Bike mods:
Z-mod and modified the snorkel.
Thanks for the help.
gbacque is offline   Reply With Quote
Old 05-09-2013, 09:57 AM   #8813
Captain Caution
Captain Caution's Avatar
Oddometer: 118
Bike mods:
Have you removed the intake between the carb and the head to make sure it is not cracked or separated? A vacuum leak could cause the symptoms you are having.
Hope it helps,
Captain Caution
Fight cancer, not war.
Captain Caution is offline   Reply With Quote
Old 05-09-2013, 10:20 AM   #8814
gbacque
gbacque's Avatar
Oddometer: 75
Good point. I'll pick up some starting spray on the way home and try spraying it around the boot area while it's running. That should revile any leaks.
Old 05-09-2013, 11:40 AM   #8815
Captain Caution
Oddometer: 118
You could try that, but it isn't always conclusive. I think it's probably better to remove it and examine it and it's gasket. You'll find pictures of the boots on my XT350, which caused me some grief:
http://advrider.com/forums/showthrea...0#post16770910
Also check the plastic cover on the side of the carb for breaks. Check the slide valve diaphragm for holes/tears as well.
Cheers!
Old 05-09-2013, 11:58 AM   #8816
jna
Oddometer: 72
XT 250 Thread
Does anyone know if there is an XT 250 thread on ADV? Wife has a 225 but is looking at the 250
thanks
jna is offline   Reply With Quote
Old 05-09-2013, 12:14 PM   #8817
gbacque
gbacque's Avatar
Oddometer: 75
Cheers!
Thanks for that link. I sure hope that is the problem. It would explain why the problem as been getting progressively worse the more I ride the bike.
Old 05-09-2013, 12:42 PM   #8818
ER70S-2
ER70S-2's Avatar
Oddometer: 6,469
thanks
http://advrider.com/forums/showthread.php?t=403156
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 05-09-2013, 04:34 PM   #8819
toomeymd
Oddometer: 49
Clarke 4 gal tank for xt225. 1 month old. $150 obo plus shipping. According to UPS shipping will be about $20-30.
2001 Yamaha xt225
toomeymd is offline   Reply With Quote
Old 05-09-2013, 07:24 PM   #8820
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,134
Post it in the "flea market" and tell what color it is too. Btw, why don't you want it? Seems like ever'body wants a bigger tank, especially out West.
Times are GMT -7.   It's 12:03 AM.
