Old 05-10-2013, 12:32 PM   #8821
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,583
Originally Posted by duanew1 View Post
If I remember correctly the large cam tensioner bolt only covers the hole where you stick a flat head to hold the tensioner.
Tom S is offline   Reply With Quote
Old 05-10-2013, 02:47 PM   #8822
Wilder
Wilder's Avatar
Oddometer: 254
Talking Manhandled XT
Went for a little trail ride wendsday evening with the trust XT225. Dont' ask where
http://youtu.be/N81Ap3AvDz8
Wilder is offline   Reply With Quote
Old 05-11-2013, 06:24 AM   #8823
tuna101
Oddometer: 247
Originally Posted by toomeymd View Post
Clarke 4 gal tank for xt225. 1 month old. $150 obo plus shipping. According to UPS shipping will be about $20-30.
Does the Clarke tank bolt right up with no mods?
tuna101 is offline   Reply With Quote
Old 05-11-2013, 06:54 AM   #8824
JerryH
Oddometer: 5,069
Pretty much. You do lose the plastic wing/grille things on the stock tank, but the Clarke tank takes up that space. You have to put some more foam over the top frame tube, but it comes with the tank. I have 2, one blue and one black. Using the blue one, but keeping the other. I've had 2 stock Honda XR plastic tanks destroyed by ethanol. Hope this doesn't happen to the Clarke tank.
JerryH is offline   Reply With Quote
Old 05-11-2013, 10:03 PM   #8825
rextec
rextec's Avatar
Oddometer: 40
UNI air filter
So i got a UNI filter for my "new" '02 XT225 and went to install it and noticed the wire mesh plate that comes stock in the airbox on these is missing. Is this a problem? Anone running thier UNI without the mesh?
P.S. Im in love with my new bike! Pics and proper intro soon to come
rextec is offline   Reply With Quote
Old 05-12-2013, 04:55 AM   #8826
GI_JO_NATHAN
GI_JO_NATHAN's Avatar
Oddometer: 2,574
Mine is pushed into the box so it's not sealed anymore. I tried to take it all apart to fix it, but it just opened up a whole can of worms.
Jonathan
If guns are outlawed, only outlaws will have guns.
Originally Posted by POLLOCK28 (XDTALK.com)
From what I understand from frequenting various forums you are handling this critisim completely wrong. You are supposed to get bent out of shape and start turning towards personal attacks. Get with the program!
GI_JO_NATHAN is offline   Reply With Quote
Old 05-12-2013, 06:12 AM   #8827
tuna101
Oddometer: 247
Where are you in the desert? I'm in Joshua Tree
Old 05-12-2013, 07:13 AM   #8828
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,245
I'd replace the part. It probably wouldn't cost much. Riding in a desert I'd be especially concerned about the air filter being perfect & maintained very often. Sand is silica, and is very abrasive in an engine.
GlennR is online now   Reply With Quote
Old 05-12-2013, 10:41 AM   #8829
rextec
rextec's Avatar
Oddometer: 40
IM IN YUCCA VALLEY!!! One town over!!! hahahah
Old 05-12-2013, 06:51 PM   #8830
rextec
rextec's Avatar
Oddometer: 40
So here is my project: '02 XT225
-checked valve adjustment (in spec)
-checked spark plug gap (in spec)
-greased all suspension zerks (green grease)
-changed oil and filter (castrol 4T 20w-50)
-adjusted and lubed cables
-fresh gas with seafoam treatment
-adjusted tire air pressure
-conditioned seat (aerospace 303)
-full detail :)
-rebuilt light/horn switch: cleaned contacts and added dielectric grease
-bled front brakes and flushed with fresh DOT4 fluid
-installed new scott grips
-installed 90/90 21" pirelli scorpion pro front tire
-installed 100/100 18" kenda k760 rear tire
-installed Tusk mini high bar handlebars
-installed UNI air filter
-installed D.I.D. o ring chain
Before:
After:
Old 05-12-2013, 07:18 PM   #8831
rextec
rextec's Avatar
Oddometer: 40
Well, heres my '02 XT225 project. I spent alot of time lurking and learning before this purchase, and i thank you all for the info! I've had several bikes in the past and currently but this is my first "dirt" bike. I've already had so much fun working on it and riding! Looking forward to many great adventures with this little machine :).
-full detail :)
Before:
After:
rextec screwed with this post 05-12-2013 at 07:29 PM
Old 05-13-2013, 05:52 AM   #8832
tuna101
Oddometer: 247
Looks good Jaber, will give you a call when I hear from you. Sent you a PM.
Old 05-13-2013, 01:58 PM   #8833
woofer2609
woofer2609's Avatar
Oddometer: 830
Clean Bike!
Holy Crap Rextec! It looks like you replaced the Phillips style screws holding the right side engine case. That is CLEAN!
As a side note, has anybody changed their exhaust out? I want to treat and paint mine (after a harsh winter with some road salt making rust spots on it.) how difficult is it to get it sealed again? I'm looking at taking it apart just past the stainless steel header.
woofer2609 is offline   Reply With Quote
Old 05-13-2013, 02:57 PM   #8834
moterbiker
Gypsy diver
moterbiker's Avatar
Oddometer: 1,475
The later bikes didn't use the phillips screws.
The exhaust comes off and goes back easily, you *may* need to replace the donut gasket at the connection
Some random stuff for sale
http://www.advrider.com/forums/showthread.php?t=988511
moterbiker is offline   Reply With Quote
Old 05-13-2013, 03:11 PM   #8835
rextec
rextec's Avatar
Oddometer: 40
Thank you! I went through every inch of this bike, i like to get well acquainted with my machinery :P. And yes, the engine case bolts are stock on this one. Now time to get her dirty!!!!
Times are GMT -7.   It's 05:22 PM.
