Old 07-14-2013, 10:28 PM   #9121
alonzo
Misadventurer
alonzo's Avatar
Oddometer: 419
Originally Posted by Reposado1800 View Post
Keep these settings but go a bit leaner on the fuel screw setting. It is very sensitive and will help clean up the mixture.
k
Do you mean the (external) pilot air screw?
-- a
alonzo is online now   Reply With Quote
Old 07-14-2013, 10:41 PM   #9122
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,785
-- a
It is a fuel screw. It is very sensitive and turning it in a quarter turn can be enough to lean it up just enough to run smooth. A couple months ago I went through the same drama, cleaned the carb and found all it needed was a slight adjustment.
Hate gets you nowhere.
Old 07-16-2013, 04:00 PM   #9123
alonzo
Misadventurer
alonzo's Avatar
Oddometer: 419
Originally Posted by TwilightZone View Post
>"127.5 main"
Anyone here have a part number and ordered from?
Actually, If you haven't bought a jet yet here's a good place to get one (and many other carb parts as well.):
http://www.moto-lab.com/inventory/vi...bclass3=Mikuni
This is Derek's (Motolab) site and he's a major contributor to ADVrider.
Click the "contact" tab on his site to get his phone # or e-mail or PM him here.
http://www.advrider.com/forums/member.php?u=23775
I'm pretty sure you need this one:
MIKUNI MAIN JET, LARGE ROUND, 127.5, N100/604
-- alonzo
Old 07-16-2013, 08:42 PM   #9124
norvegicus
waiting for spring...
norvegicus's Avatar
Oddometer: 220
Selling my trusty XT. Makes me a bit sad, but I realized that I've spent more time putting it away each fall and getting it out again each spring the last two years than riding it.
http://www.advrider.com/forums/showthread.php?t=904240
200? XR100/1985 CB700s/1982 CT110 (in pieces)/1982 C70/1979 CT90/1969 CB350
norvegicus screwed with this post 07-17-2013 at 12:10 AM
norvegicus is offline   Reply With Quote
Old 07-16-2013, 11:04 PM   #9125
motolab
motolab's Avatar
Oddometer: 2,579
-- alonzo
Hello Alonzo,
Thanks for the plug!
Regards,
Derek
motolab is offline   Reply With Quote
Old 07-17-2013, 12:27 AM   #9126
BlueRidgeKat
Daily Commuter
BlueRidgeKat's Avatar
Oddometer: 241
Is there a specific XT 250 (08-13) thread or do they share this one.
BlueRidgeKat is offline   Reply With Quote
Old 07-17-2013, 01:01 AM   #9127
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,429
Ever use a search function? XT250, not XT 250
http://www.advrider.com/forums/showthread.php?t=403156
Tom S is offline   Reply With Quote
Old 07-17-2013, 07:24 AM   #9128
BlueRidgeKat
Daily Commuter
Oddometer: 241
Nope, its easier to let you do it.
Old 07-17-2013, 07:35 AM   #9129
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,429
You're welcome. Think it will happen again?
Old 07-17-2013, 02:02 PM   #9130
BlueRidgeKat
Daily Commuter
Oddometer: 241
No, I'll get someone else to do it for me next time.
Old 07-18-2013, 05:20 AM   #9131
dav_dman
dav_dman's Avatar
Oddometer: 824
Originally Posted by motolab View Post
Hello Alonzo,
Regards,
Derek
hey I had no idea...always gone to jetsrus. Motolab will be my next parts purchase.
dirt bikes, vstrom, cruiser, etc.
"what hurts, instructs" - ben franklin
dav_dman is offline   Reply With Quote
Old 07-18-2013, 11:56 AM   #9132
maverick1
maverick1's Avatar
Oddometer: 31
I have a 2001 XT225 and feel like my front fork sags too much.
Are the front forks air sprung, use a coil spring or both?
If air sprung where would I find the valve to check the pressure and add air if necessary?
Cheers
maverick1 is offline   Reply With Quote
Old 07-18-2013, 05:32 PM   #9133
rextec
rextec's Avatar
Oddometer: 40
Cheers
Coil spring. Some of the older ones had schrader valves on top of the fork but i believe air pressure wouldn't raise the front end regardless, they were there to tune the "bottoming out" characteristics of the fork. You can make preload spacers and add them to your forks to adjust sag.
rextec is offline   Reply With Quote
Old 07-18-2013, 05:53 PM   #9134
jspringator
Oddometer: 447
Originally Posted by jspringator View Post
Re-drilled the 1/4 inch holes with a 1/2 inch bit. Added 1 hole because some of the 1/4 inch holes were close together and overlapped. I'm only at 800 feet above sea level, so this should do it. It sounds great.
Thanks for your help Alonzo. I never understood the difference between diameter and area.
Given your experience, I may skip shimming the needle.
It's a shame you can't get the pumper carb kit for this bike any more.
After redrilling the muffler I had a little high speed stumble. I then replaced the air filter with a Unifilter, and now it runs perfectly.
Formula: remove snorkle, rejet main to 130, drill muffler, add unifilter. A shop already turned the pilot screw out. I don't really like the noise, but the performance is there. 800 feet above sea level.
2006 Yamaha XT225 (TM33,Wiseco 10.25 to 1 piston, Webcams 89A cam, beehive racing springs, RDL seat)
2000 ST1100 ABS, RDL seat
jspringator is offline   Reply With Quote
Old 07-18-2013, 08:11 PM   #9135
JerryH
Oddometer: 5,069
How to pack up an XT225 for cheap
Already had most of it, just had to buy about $20 worth of bits and pieces to put it all together.
Not worth the climb.
I have a Z1 modded pipe. It was done by the PO of one of the three XT225s I have. I left the snorkel in, and use a stock filter. Here in the AZ dust, you need all the protection you can get. I also have it jetted just a little rich, to help keep it cool in the 110+ temps here. Plenty of power for a trail bike, even with my 230 pounds on it.
JerryH is offline   Reply With Quote
Times are GMT -7.   It's 06:58 AM.
