Old 11-03-2013, 06:28 PM   #9691
SteverinoB
EstebanarinoB
SteverinoB's Avatar
Oddometer: 560
Laugh Correctamundo!
Originally Posted by woofer2609 View Post
...or you could drain and reuse the oil.
New filters are a mm or so taller than the space allotted them in the filter housing. tightening the filter housing covering plate to the correct torque crushes the filter a bit and creates a good seal. There is the possibility that if the rubber on either end of the filter wasn't lubed it stuck to the inside of the filter housing, and with the latest filter removal, the rubber ends of the filter stayed inside the housing, sorta like what TomS said.
I don't recall any rubber either, apart from the o-ring
Woofer...I'm driving my truck down the road today thinking about this filter thing and low and behold, this is exactly what I'm thinking. Looking at the inside of the recommended Yamaha filter I can see that the two rubber prongs of which I spoke, are the means by which the rubber donuts are attached to the front and rear of the filter itself? Duh!...Thanks a heap for chiming in.
Thanks to all for responding to my post and my apologies for not being a little more observant.
Steve
Any day on the bike is a GOOD day!
R90...CT90...Wee...DR650
SteverinoB is offline   Reply With Quote
Old 11-03-2013, 08:18 PM   #9692
alonzo
Misadventurer
alonzo's Avatar
Oddometer: 419
Originally Posted by BIG ED XT FAN View Post
Hi, All XT 225 Fans!! Check out the XT 225 for sale. Its on CL Buffalo. Its under Oct 30 section.
Good Luck!!!! BIG ED XT&TT 600 FAN!!!!
Big Ed --
What did it take to put the YZ forks on the XT?
-- alonzo
alonzo is online now   Reply With Quote
Old 11-03-2013, 08:46 PM   #9693
BIG ED XT FAN
BIG ED XT FAN's Avatar
Oddometer: 1,234
Thumb XT 225 with YZ Forks.
Originally Posted by alonzo View Post
Big Ed --
-- alonzo
All that is needed is a XT225 fork stem. Press out the YZ forks stem and install the xt one. I never have try it on a XT 225. You may have to get a shim made, not sure. Theres a web site just for XT 225 , I think i read about it there too. Good Luck!!! BIG ED XT FAN!!!!
BIG ED XT FAN is offline   Reply With Quote
Old 11-04-2013, 05:57 AM   #9694
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,431
Steve
I just can't get no respect.
http://www.advrider.com/forums/showp...postcount=9688
Tom S is offline   Reply With Quote
Old 11-04-2013, 07:34 AM   #9695
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,719
I noticed that...
I'll send you $1 too
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 11-04-2013, 07:56 AM   #9696
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,431
Originally Posted by HardWorkingDog View Post
I noticed that...
I should send you one for noticing.
Geez, ya send the guy pix of the right filter after somebody told him not to use it, figure out the problem & wadda ya get... ?
Old 11-05-2013, 05:44 PM   #9697
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,785
I got parts in yesterday and fixed the bike last night. The stator was fried. It even had some sizzle at the base of the ignition pole. I replaced the pulse generator at the same time.
The plastic connector was broke in shipping so I had to install what was left and electrical tape it tight. I cant figure out how to get the gray connector off of the old stator and reuse it.
Edit. I got the connector switched over.
Hate gets you nowhere.
Reposado1800 screwed with this post 11-05-2013 at 07:41 PM
Old 11-05-2013, 08:20 PM   #9698
woofer2609
woofer2609's Avatar
Oddometer: 742
Don't point the finger at me! I gave you credit!
On another note, the temperature here has been in the low 30's -low 40's here, and I have begun to plug the bike into a battery maintainer. After sitting 3-4 days it seems to start on the second or third crank now, whereas if left unplugged for a few days and then cranked, it doesn't fire. I think the battery loses just that much voltage sitting in the cold for a few days, enough to not create a great spark.
I suppose I could put in that new battery I have in the basement as well, seeing as the current one came with the bike when I bought it almost 3 years ago...
woofer2609 is offline   Reply With Quote
Old 11-06-2013, 05:35 AM   #9699
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,107
Woofer,
Sounds like you know what to buy the XT for X-mas.
That reminds me....Santa needs to get his but in gear. (Nothin' like saving all year so the fat man in the red suit can screw ya' each Decenber....BaHumbug!!!)
GlennR is offline   Reply With Quote
Old 11-07-2013, 01:38 AM   #9700
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,431
Emm ... I'm not ... I didn't.
Oh, the original batt in my 2005 Xt is still working. Poor little bike hardly gets used though.
Old 11-07-2013, 05:09 AM   #9701
Speedo66
Transient
Oddometer: 6,743
I changed the battery on my '05 this past season, and what a difference in starting it made. Before it would crank, but need charger help to start when the temps were cold. Now it cranks and starts easily, big difference.
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 11-07-2013, 08:02 AM   #9702
woofer2609
woofer2609's Avatar
Oddometer: 742
Laugh
Just havin' fun Tom S
Old 11-07-2013, 04:18 PM   #9703
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,107
Ditto. Big difference. 20f no problem with a new battery.
Old 11-07-2013, 04:22 PM   #9704
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,107
I just got a pair of Tusk grip warmers for the little XT. I'm thinking about getting her a pair of folding mirrors too. Tis' the season.
Old 11-07-2013, 09:39 PM   #9705
rhollamby
Oddometer: 333
Does any one run a heated gear setup on their xt? Would like to run a jacket and set of gloves but it seems that the alternator can't take it in these bikes, true?
-wr250r
rhollamby is offline   Reply With Quote
Times are GMT -7.   It's 09:14 PM.
